Question about HP LaserJet 1010 Printer
Unsupported personlity pcl - HP LaserJet 1010 Printer
PCL XL Error Subsystem: KERNEL Error: Unsupported Protocol Operator: Parent Stream Position: 0
may have wrong printer language being sent from computer to printer. See if you can print out a printer information sheet from the printer that shows the language it uses .
Then find printer driver on line for the printer that uses the same language and install it on the computer ,.
Apr 22, 2018 | Office Equipment & Supplies
Printer worked fine, now suddenly only prints unsupported personality: PCL
Un-install the driver and re-install newly downloaded ones.
Feb 07, 2015 | HP LaserJet 1012 Printer
HP L7680 Error
GOOGLE IS YOUR FRIEND IN SUCH CASES :) Excuse Caps. Your Drivers need updating, but you are seriously hampered because all support for XP ended ages ago. Why are you still running Windows XP leaving your computers open to security breaches? You should be on Windows 8 Pro at the least or Windows 10. What I would do is go to the HP Website and download and install the drivers and software again.
Search Results PCL XL Error. The PCL XL error is most commonly associated with HP LaserJet printers. The error occurs when several pages are sent from a document to the printer's print queue. ... HP has identified the problem printer drivers for most of their printers that display the PCL XL error.Mar 11, 2016
PCL XL Error - The Tech-FAQ
www.tech-faq.com/pcl-xl-error.html Feedback
About this result
How to Fix PCL XL Error ' Techwalla.com
https://www.techwalla.com/articles/how-to-fix-pcl-xl-error Mar 31, 2015 - When attempting to print certain documents on a Hewlett-Packard LaserJet all-in-one printer, you might sometimes end up with a piece of paper with a "PCL XL" error code printed on it. This is due to the printer's inability to process certain parts of the document, such as embedded fonts or images.
Solved: PCL XL Error and other weirdness - Customer Support Forum
forum.support.xerox.com/t5/Printing/PCL-XL-Error-and-other-weirdness/td.../164 Sep 17, 2010 - 10 posts
Hi all,. We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 ...
PCL XL error in printer - Microsoft Community
https://answers.microsoft.com/.../pcl-xl-error.../124223ac-bd82-4758-8d7f-7efe95a04... Nov 11, 2013 - I have a HP LaserJet 4250 PCL6. I was trying to print and all of a sudden I am getting an error message. ... c:\ windows\system32\spool\printer\X64\3 rename the file relating to your printer with the .gpd extension - call it anything you wish and then reboot your pc and it re-creates ... PCL XL error: IllegalOperatorSequence
3 Dec 2016
PCL XL error - Subsystem: IMAGE - Error: IllegalAttributeValue ...
13 Jul 2016
Getting PCL XL error when trying to print.
30 Dec 2012
When trying to print, get a page that has message PCL XL Error ...
28 Dec 2012
More results from answers.microsoft.com
Troubleshooting: PCL XL Error - Customer Support
https://stamps.custhelp.com/app/answers/detail/a.../troubleshooting%3A-pcl-xl-error Next, you will need to install the "PCL" or "PCL 5" version of your printer's driver. This driver should already be available on your computer or the CD that came with your printer. It can also be downloaded from the HP website.
www.tech-faq.com/pcl-xl-error.html Rating: 4 - ‎4 votes
Mar 11, 2016 - The PCL XL error is most commonly associated with HP LaserJet printers. The error occurs when several pages are sent from a document to ...
PCL XL error Google Search
Jul 25, 2017 | Office Equipment & Supplies
Pcl xl error subsystem kernel, errir: unsupported protocol; operator: 0x0; position: 0 on a hp laserjet 4050
First thing to do is reload the drivers from hp.com. Sounds like the PCL drivers are hosed.
Sep 02, 2011 | HP LaserJet 1320n Printer
Not so much a problem but got message printed out while trying to print a document. Unsupported Personality: UNKNOWN. Does this mean something I should be concerned with ??
An error page will print with the words "Unsupported Personality: PCL " in the upper left hand corner. The printers are host-based and do not support PCL printing; therefore, installing an alternate PCL5e or PCL6 printer driver will frequently generate this error condition. NOTE: This error condition occurs by design when an attempt to print with a PCL5e or PCL6 printer driver occurs and is NOT a bug within the product software. SOLUTION: Install the correct HP LaserJet Host-Based Printer Driver or the HP LaserJet printing system software for the product. These drivers are available for download from the HP web site. Click here to go to the HP web site drivers and downloads page. NOTE: There are several programs (such as accounting, invoicing, court documentation applications) that are 16 bit (DOS) programs with a 32 bit (Windows) overlay. Due to the nature of these applications and the associated Windows overlay, the errors may continue with the correct printer drivers. These applications do not typically support a host-based output device, and as such would not be supported in these environments.
Feb 24, 2010 | HP LaserJet M1522n MultiFunction Printer
Cannot print on networked lj1010. Error is "Unsupported personality PCL"
dear please install your printer driver normaly a computer and after another comuter install
  1. click start manu
  2. settings
  3. printer and faxes
  4. add printer
  5. next
  6. select a network printer
  7. then choice your compuer link printer
Thanks
and select printer
Aug 04, 2009 | HP LaserJet 1010 Printer
Hooking up my printer
I am trying to hook up my printer to a different pc and it will not print...on the paper it prints unsupported personality:PCL...does anyone know why it's doing this??
Jun 24, 2008 | Office Equipment & Supplies
HP LaserJet 4240/4250/4350 PCL 6
I think its a virus infected....... run scanning software.. to detect virus... second you need to do is log in as a administrator then go to the printer property and delete pending print jobs...then restart your unit..
gudluck
Mar 25, 2008 | HP LaserJet 4250n Printer
Unsupported personality: PCL on leopard
uninstall and reinstall the printer drivers
Dec 15, 2007 | HP LaserJet 1012 Printer
HP LaserJet 1010 Printer Logo
Clive
Clive
Ekse
Thomas F. Schneider
