Question about Toshiba 27A45 27" TV
Television Toshiba 27A45C, chassis M3S226: There are some retrace lines in the first 4 inches in the top of the tv. I hoped to find some adjustments on the board and the only 4 adjustments I found didn't help. I was told by JAIME867 that these lines are cause by defective capacitors in the vertical section of the TV. No adjustment will work unless the capacitors are replace. He told me also to check the circuit board and try to find an IC with the following markins LA7847. I found a chip that is a LA78041 and I have the schematic on hand. He said that the values of the capacitors are between 1uF, 10uF or possibly a 47uF. There are 7 capacitors but they don't have the numbers he gave me so I presume he's using a schematic close to the model I have. I'll need to know more about the capacitors he suggest to change so I can spot the good ones to change.
  • 2 more comments
  • Andre Taillefer Jun 17, 2009
    I have the necessary skills for changing the capacitors. Your comments are mainly pointing the electrolytic capacitors. Are those the ones to change first? Could my problem be caused by non-electrolytic caps?
    I'm pleased of the answer but have a few more:
    The solution is mainly pointing the electrolytic capacitors. Are those the ones to change first? Could my problem be caused by non-electrolytic caps?
  • Andre Taillefer Jun 19, 2009
    after changing C407 and C408, the problem was solved. Thanks for the good advice!
  • 10,594 Answers
Usually electrolytic capacitors create problem after certain time and you need to check those capacitors that are located near big resistors (1w or 2w) that generate heat and electrolytic capacitor gets dry due to resistors heat. It is my personal experience in TV repair.
I would be in better position if you could email me schematics of this TV at welcomejee@yahoo.com to help you more.
Thanks.
Posted on Jun 17, 2009
  • Shahid Electronics
    Shahid Electronics Jun 17, 2009
    Thanks for schematics email.
    Please replace C406 (1uf 50v) C704 (100uf 35v) C408 (1000uf 25v) and C409 (10uf 50v) in vertical section that is mentioned in schematics page-30 Deflection Schematics.
    Hope that will help you to solve TV problem.
  • 483 Answers
replacing each of the electrolytic capacitors one by one until the problem has gone away. Sometimes the gassy electrolytic will have a bulge in the side - which helps you identify it. If you have any electronic skill and a soldering iron and know how to disconnect the wires from the electrolytic and solder in the new one, you could do it. Identifying the electrolytics is easy because they are polarized and have their capacity and voltage rating written on the side of the can, making it easy to find a replacement.
So, let me know what you think and if I can give you any further assistance.
thanks
Fame !
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
40wh08b convergence problem
Convergence IC's need replacement = STK392-110 original #...
Use name brand Toshiba, NAP, or upgrade to STK394-160E
Hitachi part # CZ 01341...no cheap generics..they won't hold up..
Chassis pull and some precision soldering will be needed....let me know if you need further info...........................T.
Dec 27, 2007 | Toshiba 40H80 40" Rear Projection...
Retrace lines in top of tv...
These lines are cause by defective capacitors in the vertical section of the TV. No adjustment will work unless the capacitors are replace. The values of the capacitors are between 1uF, 10uF or possibly a 47uF.
I do not have the service manual at this moment but you can google it by the model number of your TV.
Let me know if you need further assistance.
Jun 16, 2009 | Toshiba 27A45 27" TV
Red an green lines across the tv about every two
Sounds like you have retrace lines in your picture. It may resemble something like window blinds, but slanted to the lower right. You most likely have a bad crt or the AKB circuit is bad. This most likely needs a technician to adjust the G2's to see if it can be balanced.
Apr 29, 2009 | Sony KP-51WS500 51" Rear Projection...
Toshiba 52WM48 - Dark line across top of screen about 4 inches
replace the vertical ic, LA 7833 and four capacitors near it, i encountered this last two days.change the parts and it ok now.
cost of this parts is about $20.00
Jan 22, 2009 | Toshiba 42H83 42" Rear Projection...
Toshiba theaterview 50in rear projection tv
Look at it on the QVC channel where you have boxes with straight lines. If any of the 3 colors are bowed and 1 inch off, then it needs parts inside. If the colors are straight and only 1/4 inch off, you can adjust it. Using the remote, in the menus find convergence to adjust. Your user manual will explain it. At WWW.Toshiba.com you can download the manual if you do not have it.
Mar 24, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba TN55X81
Blue Convergence IC is bad = change both for reliable repair..
located on largest heatsink on chassis.............T.
Feb 02, 2008 | Toshiba TN55X81 55" Rear Projection...
Toshiba 36A40 36" TV / Chassis No: TAC 0011
Bad capacitor in vertical circuit + possible vertical output IC
damage.If you can identify part locations and solder.....?
May 24, 2007 | Toshiba 36A40 36" TV
Green arcs from bottom up with darkest one at bottom on dark screens
there is a way to get rid of the lines, you need to enter a code from your remote to access a hidden menu. From there you can adjust the lasers in the tv(green lines)I beleive it is very sensitive though, if done wrong can reck the tv. Not sure of the code or directions on how to exactly adjust the lasers, actually looking for them my self. Hope i was some help though!
Jan 22, 2007 | Sony KP-51HW40 51" Rear Projection...
Bright screen with retrace line. No manual.
You can get that manual at http://www.servicemanuals.net for about $25.00 US. Good Luck.
Jul 14, 2006 | Samsung CXJ1964 19 in. TV/VCR Combo
Toshiba 27A45 27" TV Logo
232 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
