Question about Sony Playstation 3 (PS3) Console
I get dns error 80710102 and im using wireless i have a 80gb
Playstion 3 and when i check the connection the ip address passes as does internet connection but playstation network failed any ideas thanks
    President:
  • 2,653 Answers
If you're using a router make sure you've got the latest firmware.
Also make sure you have PNP enabled on the router.
If you don't know what I'm talking about please refer to the router's tech support site on how to access your particular router. They're not all the same.
Posted on Jun 17, 2009
I've changed my modem, I have a 100% connection with my PS3 to the router, IP address and Internet Connection is successful. Playstation Network = FAILED ... how can I fix this???
you can try doing a factory reset on your modem/router also try to hard wire it and see if that gets the PSN to pass, you might even have to set your PS3 up as a DMZ host in your modem/router configuration this will put your PS3 outside the Firewall which can sometimes fix the problem. You can also ty this:
On your router settings, open TCP port 80, port 443, port 5223 and UDP port 3478, port 3479, port 3658.
Disable the media server connection option found under the Network Settings menu option on the Playstation 3.
Feb 19, 2011 | Sony Playstation 3 (PS3) Console
Obtain ip address failed !!!! what is ip address ??
IP means internet protocol.
Try turning off your modem and router for a couple of minutes and then turn them back on again and go into the settings menu and reset you internet network settings, see if that helps.
Regards.
Dec 13, 2010 | Sony Playstation 3 (PS3) Console
I have scanned for my internet and connected to it by typing in my wpa key. but when it comes to connecting the connection my ip address fail. do i type in my ip address manually? if so, where can i find...
First, make sure that DHCP is enabled.
Second, Don't use the pass phrase use the key.
  • For example, if you setup WEP to use a pass phrase like ROSEBUD, use the generated key code under it which would look something like AA34578E9...
Mar 08, 2010 | Sony Playstation 3 (PS3) Console
Playstation network failed internet connection
There is a worldwide issue which Sony are fully aware of which is affecting
all old model PS3's, The new slimline PS3's are not affected.
Due to an internal clock failure on the units they are not syncronsing with the
network time on the PSN's end. Causing error-8001050F
There is no official ETA although at 16:58 GMT today (1st March) Sony released a
statement stating they should have the problem resolved within 24 hours and have
advised all PS3 users experiencing issues NOT to use their PS3 until they
advise the issue is resolved as it could result in loss of functionality and
further damage.
For up to date informaton see:
http://uk.playstation.com/games-media/news/articles/detail/item266689/PlayStation-Network-currently-unavailable/
http://community.eu.playstation.com/t5/PlayStation-Network/PSN-Connection-issues-error-8001050F/td-p/10303803
Many thanks
Pete McDowell
Geek2Door Ltd
http://www.geek2door.com
Feb 14, 2010 | Sony Playstation 3 (PS3) Console
Cant connect my PS3 to internet
you can test your internet speed here http://www.ip-details.com/ ,i test my internet speed and got good result, this provides th ep details at free of cost ,i test the ip details here..
Nov 11, 2009 | Sony Playstation 3 (PS3) Console
HELP?
Restore PS3 to factory settings and change your network settings:
Best Results: Reset your router, then give your PS3 a static IP address and go into your router interface, find the DMZ feature and put in the IP address that you gave the PS3, just make sure the IP you give it is within the DHCP pool of IP addresses.
The PS3 will now be sat outside the routers firewall giving you FULL access to internet content and gaming online.
Now test connection settings and you will notice you will now have an open connection to the internet.
Also check your cable connections.
Thanks
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
Internet connection failed
please check the ip configuration using system preferences in network option if its set to automatic or manual if automatic check the cable betwin your system and the network hub switch or wall socket is fine try also using another cable ...
if the status in your left hand side shows green that means cable is fine if have and ip address and is set to manual please check with your network administrator or it guys to check for proper ip address and gateway address..
there is like very rare chance for the network card in the system to go faulty afyter its mac
thanks and regards
thanksan nd
mos
Dec 26, 2008 | Apple iMac G5 Desktop
80710092
dns error, try entering the following in your ps3. Settings - Network Settings - internet connection settings - custom - wired or wireless depending on your internet - manual settings - IP address manual - enter your ip address and your router address and change your dns primary 208.67.222.222 and secondry 208.67.220.220 this will enable you to go online as for the error code 80710092 i have no idea, im experiancing the same problem. its so frustrating. as soon as i find the answer i will let you know.
Apr 14, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
221 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
