Question about Magellan RoadMate 300 GPS Receiver
No programs work in magellan 300 roadmate
No programs work how do you reset it?
    President:
  • 1,111 Answers
Tip
HTC Touch Soft Reset Soft Reset Occasionally, you may need to reset your...
Soft Reset
Occasionally, you may need to reset your device. A soft (or normal) reset of your device clears all active program memory and shuts down all active programs. This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
To perform a soft reset
Use the stylus to press the RESET button found at the bottom of your device. Your device restarts and displays the Today screen.
I hope that helps.
____________________
Download the HTC Touch Manual.
HTC Touch Clear Storage.
HTC Touch Hard Reset.
on Apr 18, 2010 | HTC Touch Cellular Phone
Resets after begin
My Stairmaster unit seems to work in manual mode, but resets when I select a program. What is wrong? It is possible that the console on your Stairmaster unit may not be configured for the appropriate machine. This can result in the console accepting and allowing a manual workout but not accepting or allowing a program. Stairmaster Units Works in Manual Mode but Not in Program
Feb 24, 2014 | Stairmaster Stepmill 7000 Pt
How to format HTC Touch2 t3333?? need help
Performing a soft reset
Perform a soft (normal) reset to clear all active program memory and shut down all active programs. This is useful when your phone is running slower than normal, or a program is not performing properly. If a soft reset is performed when programs are running, unsaved work is lost.
1. Remove the back cover.
2. Remove the stylus to reveal the RESET button that is located at the bottom of the stylus compartment.
3. Use the stylus tip to press the RESET button.
Your phone restarts and displays the Home screen.
4. Replace the back cover and insert the stylus back into its compartment.
Oct 11, 2013 | Cell Phones
How to factory reset
An operating system ? and make of computer ? would be nice to know so someone could give a precise solution.
Reset your desktop computer to make your operating system work better. Reset a desktop computer to its defaults to override unwanted changes. Reset your desktop computer settings to the browser default settings to ensure safe use of the Internet. Always try to resolve your computing troubles by resetting your desktop computer.
Use your desktop computer's recovery system to a time when the system was working better. To reset your desktop computer to a store point, left-click the "Start" menu, point to "All Programs," and "Accessories," and then "System Tools." Click on "System Restore." Click on the option to "Restore," then click the "Next" button. Click "OK." You may also use the feature to "Set Restore Point" for future needs. In the next step you will clean up your file paths and file space to ensure that your computer is running the operating system smoothly. Click on the "Start" menu. Point to "All Programs." Point to "Accessories." Point to "System Tools." Click on "Disk Defragmenter." Click on the "Defragment" button. Close the Defragment program. Your computer will run like new. It is a good idea to restart your computer. Close all programs, then click on the "Start" button. Click "Turn Off Computer." Select "Restart." Click "OK." b> Reset a PC for the Manufacturer, Microsoft, or Non-Microsoft Program Defaults b> Click the "Start" button. Point to "All programs." Click on "Set Program Access and Defaults." Click on "Computer Manufacturer" to reset your desktop computer to the manufacturer's settings. Click on "Microsoft Windows" to reset your Internet Explorer and MSN Messenger settings. Click on "Non-Microsoft" to reset Mozilla Firefox settings. Click "OK." Your browser, email, and instant messenger settings will now be reset to the manufacturer's specifications.
Dec 30, 2012 | Computers & Internet
I need to know how to reset the timer
If you reset ST01C timer using reset button, then all programs are lost, plus current time of day.
Generally this timer needs to be reset if error message appears and as last resort for troubleshooting problem. Timer does not need to be reset after battery goes bad, all you do is set current time of day, and then program remain inside timer indefinitely (or until timer is reset of goes bad)
If setting current time of day does not work, you use reset button.
For ez programming steps with illustrations:
http://waterheatertimer.org/ST01C-program.html
How to reset ST01C using reset button:
Push and hold ON-OFF button and then push reset button using toothpick or paperclip.
Release reset button but keep holding ON-OFF button until INIT displays.
Then release ON-OFF and 12:00 should be flashing.
If timer functionality does not restore, then try replacing timer battery.
If functionality will not restore, then timer is bad.
This timer does not need electric current for setting timer, so timer display is not dependent on circuit breaker.
If you have a different timer, then add a comment with in-focus photo of timer for possible identification. Most other timers do not require 2-button reset procedure.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 23, 2011 | Intermatic Inc. ST01C Digital In-Wall...
How to do factory reset of i-mate JAQ
i-Mate JAQ3 soft reset
Resetting Your Pocket PC Phone
Occasionally you may need to reset your Pocket PC Phone. A normal
(or soft) reset of your device clears all active program memory and
shuts down all active programs. This can be useful when the device is
will be lost.
You can also perform a hard reset (also known as a full reset). A hard
reset should be performed only if a normal reset does not solve a
system problem. After a hard reset, the device is restored to its default
settings — the way it was when you first purchased it. Any programs
you installed, data you entered, and settings you customized on the
device will be lost. Only Windows Mobile software and other preinstalled
programs will remain.
Remove the battery cover and using the stylus, press on the small
button to the left of the battery. Otherwise simply remove the battery,
wait a few seconds and then insert the battery again.
To perform a Hard Reset
Hard reset by pressing device buttons:
1. Turn off your device.
2. Hold down the Send button, End button and Camera button.
3. Do not release Send, End and Camera, press the Power button.
4. After on-screen indication, release all the buttons.
i-Mate JAQ3 hard reset Hard reset using Master Clear
1. Tap Start > Settings > System tab > Master Clear
2. On the System tab, select the Master Clear (!) icon
3. Proceed to enter the confirmation code: 1234 and push reset button,
system will auto reboot to complete the operation.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 02, 2009 | i-mate JAQ3 Smartphone
Program page not working in Windows Mobile on HTC Diamond
u can try factory reset the device like this but all data will be wiped off pls active sync ur device and backup ur data then try this
To perform a hard reset
1. Pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and
ENTER buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
4. Release the VOLUME DOWN and ENTER buttons, then press the
VOLUME UP button to perform the hard reset, or press any other
button to cancel the reset.
if it doesnt help then u can upgrade ur ROM from www.HTC.com and it will also solve ur problem
pls rate me FIXYA
Jan 27, 2009 | HTC Touch Diamond Smartphone
DHG-HDD250 problems when recording
When I'm watching a recording program and recording a program I can't fast forward, pause, stop nothing works until the program that is recording stops.
I reset the machine, but it did not help.
Feb 26, 2008 | Sony DHG-HDD250 200-Hours Video Recorder
Ipaq h3835 froze
Try a soft reset first to allow programs to terminate, then try to delete programs, if that fails to work give the hard reset another try http://www.fixya.com/support/p389721-hp_ipaq_h3835_pocket_pc HP iPAQ H3835 Pocket PC Troubleshooting, Support, Repair & Service
Sep 19, 2005 | HP iPAQ H3835 Pocket PC
Magellan RoadMate 300 GPS Receiver Logo
277 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
