Question about Xerox 8825 Copier
Not printing on edge of paper
The left edge of the paper is not printing. The remainder of the copy looks good. How can I fix this? I tried shaking the toner cartridge to evenly disperse the toner.
    New Friend:
  • 51 Answers
Pls check the developer qnty
Posted on Dec 12, 2010
CANON IR ADVANCE 4035 ALL COPY & PRINT LAST EDGE SHAKING ....
Hello Jana,
Try contacting Canon customer support directly here:
Contact Us
Feb 08, 2018 | Canon Office Equipment & Supplies
I have WC 7535 when I give print or copy from tray 2,3 & 4 printer showing paper jam in tray module
Look carefully on the left hand side. All the paper from those trays pass up the left. ( you probably know that) The last time I worked on one of those machines paper feeding up from those trays can get stuck you've got to investigate where the paper is stuck coming up from the trays. Open the left door and very carefully see how far the media has traveled, does the lead edge get damaged, dented or spoiled in any way. ( look closely there) don't just rip out the paper, investigate why. Just how far has the media moved from the tray selected. I suspect a torn bit of paper stuck inside. If your machine is difficult to get to you must make room to look properly with a torch if necessary. Pull out trays 1 & 2 fully so you can look without being hindered. Good look!
Jan 12, 2015 | Xerox Office Equipment & Supplies
How do I clean toner from machine?
Probably it's the jammed paper that might caused the error. I suggest have it serviced by the technician. Be aware of the paper handling capacity of your machine to minimize jamming:
3300MFPV_X
Phaser 3300MFPV/X, Copy/Print/Colour Scan/Fax, B&W, 28 ppm, A4, 1200 dpi, 50-sheet ADF, 250-sheet Paper Tray, 50-sheet Multipurpose tray, 150-sheet Output Tray, 96 MB, Automatic 2-sided printing, USB/Ethernet, PCL/PS3, Scanning software, 220 V
Apr 28, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Can Lexmark x2470 scan and print a double sided document?
after reading the manual, http://www.lexmark.com/publications/pdfs/2007/2400/ug_en.pdf, yes it is possible - not that it tells you how to do it though so read on.
Until you become familiar with the process just use one sheet of paper at a time in the printer.
As you know, in the scanner the top right of your document goes to the right hand front corner of the scan bed (the clear window), place the page on the scanner and scan.
Pick up the printed sheet of paper and flip it so the left hand side edge is now in your right hand and the right hand edge is now in your left hand and you are now looking at the blank side of the paper.
Insert the page back into the sheetfeeder.
Flip the page to copy in the scanner so the rearmost edge of the paper is now to the front of the scan bed and the front edge of the paper is now towards the rear (you should now be looking at the page you scanned previously).
Scan the page.
you should have now scanned both sides of one sheet of paper to another sheet of paper.
as your printer does not have a sheet feeder for the scanner you have to do the process manually. hope this helps.
Apr 20, 2011 | Lexmark X2470 All-In-One InkJet Printer
Paer prints half the PAGER AND THEN JAMS ... I
The paper must be hitting something to cause it to jam. Take the drum/toner cart out also the paper tray. Unplug it and hold it upside down and see if something shakes out. Do not do this over carpet. If that does not do try a test page. look at the leading edge for dings and bends. If you find a bent spot on the leading edge thats where the problem is. Its almost always a small piece of paper Steven 818-888-0006
Mar 08, 2010 | Dell 1710n Laser Printer
Epson stylus DX3800 All in one printer, scanner Unable to print
Open the printer cover and look closely for tiny paper shreds that might got stuck between the rollers. If you have a canned air, try blowing out the paper path as those tiny piece of paper might be blocking the paper sensor.
Sep 20, 2009 | Epson Stylus Multifunction Inkjet Printer/...
It is printing way to far to the left
Check the paper edge guides on your paper, sounds like the copy paper is too far one way. Make sure the paper is centered and the guides are tight against the paper.
Hope this helps.
Ed
May 07, 2009 | Office Equipment & Supplies
I have a Konica 2223 copier - wont print on edges
check all edge settings .f28 is code for charger corona just clean corona assembly with cerosene oil and change corona wire with new one.
Dec 16, 2008 | Office Equipment & Supplies
Print Unable 34
There might be some paper left in the machine. Check the very edges espacially the left side (seeing from the front).
Another reason could be that the encoder strip isn t in right position or is stained from ink.
Anyway try the first solution first.
If you stll have trouble try to open the printer:
http://www.fixya.com/support/t211210-brother_mfc845cw
and have a close look to the encoder strip + disc (and look out for some paper in the edges... ;-))
Mar 22, 2008 | Brother Multi-Function Center MFC-240C...
65 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
