Question about Goodman Heating & Cooling
My fan motor runs to slow and needs to be speeded up. The fan motor has been changed to a A O Smith. Air conditioner is a Goodman 3 ton.
  • 614 Answers
AO Smith motor speeds are Red low Blue med. And black high. Just unplug from fan switch plug in new speed. Turn power of first. Rus
Posted on Jun 18, 2009
Noise on high speed
Is it the original size motor? It sounds like it could be to many CFM for the size of the duct causing back pressure when the blower goes into high.
Apr 08, 2014 | Goodman Manufacturing Goodman MBVC2000AA...
Goodman pgb030075-1 low airflow inside house can i change the fan speed.
the installer selected a fan speed that would be a compromise between air necessary for heat and cool. check what color wire he used coming off fan motor. black is usually high speed.
Sep 02, 2013 | Goodman CKL60AR60 Air Conditioner
Goodman heatpump fan runs, condenser wont start
Either the condenser fan has bad bearings, or it has a defective fan capacitor.
Turn off the breaker to the outside unit.
Spin the fan blade by hand.
If the fan blade spins easily and will spin a few revolutions with no problem the fan bearings are good.
If not, replace the fan motor due to bad bearings.
I am pretty sure you fan motor is bad because with a bad capacitor the fan motor will not get up to speed and may just sit and overheat.
I'm leaning toward a bad fan motor.
Sep 27, 2012 | Goodman Manufacturing Goodman GSC130301...
High low fan motor
Your main concern is the temperature difference across the indoor coil for both heating and cooling. When you turn your thermostat from auto to on, you are on high speed.
If you have long duct runs and little return air registers then high speed
would help cool the house better. However in the heating mode, you
could lose up to 10degrees by having the high speed setting.
What they installed is sized for your house and the speeds should not have to be changed unless the ductwork is not sized right for the house.
Cooling should be High-Black wire.
Heating should be Low-Red Wire.
400cfm equals a ton of cooling= 1200 sq. foot, For cooling you need
High speed. For heating it is whatever the temperature rise across the
coil is, which is located on the furnace/air handler.
Jul 13, 2010 | Goodman CLQ36AR49 Air Conditioner
The fan on the bryant high efficient heat pump moves very slow or not at all
Hi, this is a 3 ton unit. It may or may not have a variable speed fan. You are saying it turns very slow or just stops. I believe you either have a problem with the run capacitor, or you are loosing this motor. They are putting variable speed blower motors on some units now, but if you are talking about your condenser fan motor, it may have a head pressure control to speed up this motor when the ambient temperature is higher and slower when cooler, but to stop when running indicates a motor or run capacitor problem. Check the cap. for oil leaks, swollen and deformed, burned terminals. If you find this, replace it. Remove the fan guard and carefully with the power off after it has ran for a while touch to see how hot the body of the motor is. If it is to hot to touch, you are loosing this motor. If you have a clamp around amp probe or know someone who may, you can look at the data plate to see what this motor should be drawing as far as amps and compare your readings to this. You will know for sure doing it this way.
Shastalaker7
A/C, & Heating Contractor
Jun 21, 2010 | Goodman CLQ36AR49 Air Conditioner
Goodman 3 ton heat pump - condenser fan motor gets hot and stops running. Have tried 3 motors. Heat of the day it stops.
did you get a motor with the same amps? did you check to what the amp draw is on the old motor to the new? reason is different amp ratings on motors need dfferent blade pitches, also 2,3 or 4 blades pull different cfm. is the motor a belly band mount or does it hang by studs? also check to see if the capacitor is the correct uF. hope this helps you feel free to ask any question if this does not help you.
Jun 08, 2010 | Goodman CKL60AR60 Air Conditioner
Goodman 3 ton outside unit fan not blowing
Motor, wiring and/or capacitor. If the sticker on the side of the motor isn't burned off you can get the motor info off that. Model numbers from the motor do little for locating the motor but my help. Best thing to do is get the AC motor specs and look up online (cheapest) or go to a motor shop. The specs you need would be as follows.
Horsepower-Such as 1/4 or 1/3
Voltage-Most likely 240/1 (240vac single phase)
Rotation-CW/CCW looking at the shaft end of the motor
Amps
Frame size
Jul 10, 2009 | Goodman CKL60AR60 Air Conditioner
Goodman Evaporator fan runs continuosly
first disconnect the green stat wire wire could be bad if still runs change the board on the indoor unit pull board and take to goodman store with model number and serial number its under warrenty they will give new one hope this helps also look at dip switches and instructions to make sure ok
Jul 08, 2009 | Goodman Heating & Cooling
HELP, A/C wont come on in FL
Stopped up drain line caused float switch to trip. Blow out drain line. Blown fuse in Air Handler. Bad transformer. You have a 3 ton on a four ton air handler. You need to lower fan speed to low dor better effeciency. Could have bad Tstat butchances are control voltage problem.
Jun 06, 2009 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
234 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
