Question about Brother HL 5140 Laser Printer
Toner light How do I trick the toner cartridge to print more when the toner light comes on?
    Problem Solver:
  • 4 Answers
I taped a very small white piece of paper over the sensor eyes on either side of the cavity where the cartridge fit. I read that coloring in the actual "windows" that are on either side of cartridge also may help so I did that too.
So open the front, remove cartridge, look on the cartridge for a small circle and color them with black marker (or use electrical tape), look where they would have aligned inside the cavity, tape a small piece of white paper over those sensor eyes.
I just did this and it stopped the blinking. Don't know how long but based on my reading, one of these was the trick.
Posted on Jul 03, 2009
  • seahors Feb 02, 2010
    A follow-up:
    It has been six months since I did the white piece of paper trick described above. It is still working fine.
  • 499 Answers
What do u mean by the toner light turn on
Posted on Jun 17, 2009
SOURCE: Toner Light stays on after new cartridge installed
@Shortcutls
Thanx a lot. my printer problem is solved by following your steps.
Thanx again.
Posted on Feb 25, 2008
  • 848 Answers
SOURCE: Toner light on, replaced toner
provide details about make and model no ..............
Posted on Oct 30, 2008
  • 526 Answers
SOURCE: i have a brother 2140
When it says to clean the corona, on the drum there is a purple tab that moves from one side to the other. run it back and forth a couple times that should solve the problem.
I dont recommend refilling the cartridges, we have had several issues in repairing those printers with refill. if you must use refills, i would recommend getting 2nd or 3rd party manufacturers.
if you need help, you can contact us.
thanks adi
Posted on Dec 31, 2009
  • 22 Answers
SOURCE: Toner light still on with new toner
Is the printer still asking for a new toner..?
If it is the there is a gear that can be reset on the toner cartridge2_bing.gif to tell the machine its a new toner cartridge. This is normally done by an engineer, but is quite easy to do if you know how. And I do :0
Posted on Mar 07, 2010
Printtech
  • 1087 Answers
SOURCE: TONER LIGHT STAYS ON WITH NEW TONER CARTRIDGE
If the main problem is just the toner light on then what you could do after installing the new toner is resetting the printer. You could do that by powering the printer off, open the front cover (as if you were to replace the toner) with the front cover open and the printer off push and hold the two buttons on the printer and turn the printer on while holding down the buttons then once the bottom light stays on solid, release the two buttons and that should reset the printer.
Now if the toner light is blinking that means that you have reached the 30,000 page mark and the Photoconductor needs to be replaced. If that is not the case you can follow this link to a procedure where it will explain how to reset the Photoconductor. http://bit.ly/91SWS3
Posted on Mar 19, 2010
On my Cannon runner 5570/6570 why my printing jobs come out too light?
If it's a reconditioned toner cartridge.. Then it's fine. It won't be as original cartridge ink.
If new check setting there will be option - Save Toner, unselect this option
Nov 13, 2015 | Cannon Office Equipment & Supplies
Tip
Brother HL-2140 does not print even if toner is full
In the Brother HL-2140 printer, it shows the Toner led light is on. Even if there is plenty of toner on the cartridge. It just wont print anything after initiating a print job since the toner light is on.Here is a trick on what you need to do:
1. Turn off the Brother HL-2140 printer.
2. Open the front access door to take out the toner from the carriage.
3. Notice that on both sides of the toner, you will see a small hole which is most probably the sensor.
4. What you do is to cover the sensor holes with masking tape and color the tape with black marker. Or, you can also use an electrical tape to cover them.
5. Shake the toner so that the ink inside will redistribute evenly.
6. Return the toner to the carriage and try to initiate a print again.
That's it!
on Jan 13, 2010 | Office Equipment & Supplies
How to fix printing
As toner cartridges become depleted, it is not uncommon for the cartridge to become empty on one side before the other, especially if it common that there is more printing done on that side of the sheet(s) in your applications. A trick for getting the most out of the cartridge is to remove the toner cartridge, shake it both up-and-down and side-to-side to redistribute the toner inside the cartridge. You may get as many as 500-600 or more additional copies this way.
Sep 18, 2014 | PrintCountry Samsung CLX 2161NK Laser...
HEWLETT-PACKARD LASERJET PRO P1606DN PRINTER
the cartridge in this machine has a chip on it but it should still print if you get a toner low message. the chip counts pages not amount used to print so if you are doing light print jobs it does not no it only counts the cycles
Mar 13, 2013 | HEWLETT-PACKARD LASERJET PRO P1606DN...
I am having print quality issues on a Dell 2135cn MFP - print on the left side of the page is light.
Try removing the toner cartridge and gently rotating it back and forth. Often the toner will bunch up like a snow drift and where there is little toner you'll have light or no print. If that doesn't do the trick try another toner cartridge.
Feb 18, 2011 | Dell 2135cn All-In-One Laser Printer
It ran out of paper and i put paper in but the "toner" light is on. i tried turning it off a few times and it didn't work
AYou're out of Toner! Well, you're actually probably not ALL the way out...how about a little trick that'll make sure you get the most out of that toner? It's as easy as taping a picture to the wall. Almost. Remove the toner cartridge from the printer. You may have to also remove it from the drum to see and access both sides of the toner. You will see on each side a round clear little "window". Cover this (both sides) with tape, masking tape works well, just not anything clear like scotch tape, that won't work. We are tricking the printer into thinkiing the cartridge is full, so it will print you at least a couple hundred more pages this way. When your print quality goes down, then you know it is time to change your toner for real. Enjoy! I also recommend a refurb toner, Brother brand is too much... a waste of money. You can find refurb for about $25.
Sep 08, 2010 | Brother HL 2140 Laser Printer
How do i change the print cartridge?
Replacing the print cartridge
  1. Open the print cartridge door, and remove the old print cartridge. CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light by covering it with a sheet of paper. Figure 1: Removing the print cartridge c01174123.jpg
  2. Remove the new print cartridge from the packaging. CAUTION: To prevent damage to the print cartridge, hold the print cartridge at each end.
  3. Pull the tab until all the tape is removed from the cartridge. Put the tab in the print cartridge box to return for recycling. Figure 2: Removing the sealing tape c01211568.jpg
  4. Gently rock the toner cartridge from front to back to distribute the toner evenly inside the cartridge. Figure 3: Shaking the print cartridge c01211569.jpg
  5. Insert the print cartridge in the device and close the print cartridge door. Figure 4: Inserting the print cartridge c01174125.jpg CAUTION: If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
NOTE: When toner is low, faded or light areas appear on the printed page. You might be able to temporarily improve print quality by redistributing the toner. To redistribute the toner, remove the cartridge from the device and gently rock it from front to back.
Sep 13, 2009 | HP Office Equipment & Supplies
The print comes out light
Make sure you are using an OEM toner not a refurb or compatibly cartridge. If the problem persist your toner is not getting enough voltage or your laser is dirty. Check all contacts and transfer roller(which sits under your toner cartridge)make sure it rotates. You can also raise your toner density level in your configuration menu and make sure you pull your toner strip out of your toner cartridge. If the problem still persist I recommend a service tech.
Apr 06, 2009 | HP LaserJet 4250n Printer
Change of toner
I have a brother mfc 7840w
I first used the electrical tape trick and that worked for a while. Then got the toner low message again. I then tried the *00 trick, which works as follows:
1. lift lid and open front cover
2. press clear/back. "Replace Drum?" will appear on the screen.
3. Press "*00" it will then read accepted and the toner low error (End of Toner Life) should go away.
4. close it all up and your done.
Jun 08, 2008 | Brother MFC 7420 All-In-One Laser Printer
Blank trace appears on printed copy
replace the toner cartridge, this is a case of low toner.
NOTE: you should never clean the drum on the toner cartridge it is sensitive to light and touch.
Jan 07, 2008 | HP LaserJet 1020 Printer
Brother HL 5140 Laser Printer Logo
395 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
