Question about Dell Office Equipment & Supplies
On a dell monolaser 1125, the paper tore off and i cant get it out. is there any way to take off the fuser, or open the back?
  • 52 Answers
Yes there is take a look here show's you how to do it:
http://support.dell.com/support/edocs/systems/PRN1125/en/P1125en/ug_appea.htm#wp1083583
i hope this helps
Posted on Jun 17, 2009
  • chrisxlii Jan 11, 2011
    There, I fixed it:
    I put a piece of card-stock into the regular paper tray. Then I turned it off and then on again, which tricks it into trying to run the topmost piece of paper (in this case, the card-stock) through the feeder. The card-stock was heavy enough to push the crinkly paper out.
Misfeed in copier and total counter 463898
Your information too general. But base on your meter reading counter, I assumed a lot of your copier's parts might worn out.
1) Check any paper jammed remaining in the copier. You might accidentally tore the paper and the other tore remaining paper still in the copier.
2) Open and close all the covers. its all on the right side.
-fuser cover,side cover (T/S block section), duplex cover, drawer 1 cover (just below bypass), optional drawer cover (if there is LCT or LCF)
2) Replaced the feed, separation rollers for the drawers,
3) Check the fuser condition. Replace them if condition is not good.
Mar 08, 2015 | Toshiba e-Studio 350 Copier
My Dell MFP 1815dn has a paper Jam 2. I removed the toner cartridge and pulled the paper out, before I realized that I needed to open the back. I believe I thought I got the paper out, but the printer is...
After a paper jam occurs in the rear cover of a Dell Laser Multi-Function Printer 1815N, the printer will not resume when the jammed paper is removed. This is the normal behavior of the printer as there is no sensor on the rear cover of this printer.
To open the back cover and remove any stuck paper, perform the following steps:
  1. Open and close the front cover.
    The jammed paper may automatically exit the printer. If the paper does not exit, go to the next step.
  2. Gently pull the paper out of the output tray.
  3. If you cannot see the paper in the output tray or the paper does not move when pulled, open the rear cover.
  4. Skip to step 9. If you do not see the paper, go to the next step.If you see the jammed paper, push the two blue pressure levers up and remove the paper.
  5. Release the blue strap, the rear cover stopper, and fully open the rear cover.
  6. Unfold the duplex guide fully.
  7. While pushing the fuser lever to the right, open the fuser door. NOTICE: Make sure to unfold the duplex guide before opening the fuser door, or the fuser door may be damaged.
  8. Pull the jammed paper out.
  9. Return the levers, fuser door, rear cover stopper, and duplex guide to their original position.
  10. Close the rear cover.
  11. Open and close the front cover.
    Printing automatically resumes.
Jun 24, 2011 | Dell 1815dn All-In-One Laser Printer
I have a Dell 3010 that has error msg paper jam fuser 077-104. I cannot find a paper jam anywhere in the printer. I turned it off, unplugged, checked under drum, opened all doors and checked everywhere....
you need to check the fuser, sometimes a small piece of papaer or a label stick on he fuser in order to do this you need to open the back and top cover. or take the printer to service
Aug 21, 2010 | Dell 3010cn Laser Printer
Fuser paper jam
is a stuked paper sensor, or misplaced, check more carefully
Jul 15, 2010 | Dell Office Equipment & Supplies
Paper jam. paper tore at the exit roller. I
FUSER ASSEMBLY NEEDS TO BE REMOVER/REPLACED, THE COST AND LABOR MAY NOT BE WORTH THE REPAIR
Jan 22, 2010 | Canon ImageClass D660 Copier
Dell laser printer MFP 1125 paper tray removal
I just did this 5 min ago. The tabs that hold it on the machine have cams that hold it in. just squeeze the tray lightly at the tabs and it slides right out.
May 31, 2009 | Dell 1125 All-In-One Laser Printer
Paper is torn at fuser area of Dell 1125 and cannot remove
Please double check if all doors, including the paper tray cover, are firmly (repeat FIRMLY !) closed. Seemingly all such are designed as precautionary measures for safe operation.
Mar 08, 2009 | Dell 1125 All-In-One Laser Printer
Fuser paper jam on Dell mono laser mfp 1125
Please double check if all doors --- including the paper tray cover --- are firmly (repeat FIRMLY !) closed --- seemingly all such are designed as precautionary measures for safety operations.
Jan 28, 2009 | Office Equipment & Supplies
Paper jam, Is this the fuser?
I have had the same problem. Changing the fuser is easy (about $85, and must be ordered through Dell) remove the 4 screws from the back, and you'll see the fuser. 2 screws, and 2 wires, and it slides right out.
Jul 16, 2008 | Dell 1600n All-In-One Laser Printer
119 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
