Question about Music
No sound from speaker, but works with external speaker plugged in
The oddest thing - my amp just cut out one day when I was playing - checked all the cables, etc. One of my bandmates got the bright idea to plug in a floor monitor to the external speaker jack, and then the amp was putting out sound, as well as the monitor. When we unplugged the external speaker, the amp went back to not working. Any ideas on what might be going on here? This is a solid-state CRATE GT212.
    Sergeant:
    Champion:
  • 223 Answers
It sounds to me like you have blown the internal speaker.
Posted on Jun 17, 2009
My Roland FP8 plays very quietly through its own speakers, through an external amp & speaker and through the earphones. There is a hissing/crackling/static sound too from the speakers. Anyone
A number if things can be wrong with it, from the audil preamp to the the audio amplifier. Even as simple as a bad volume control. Does the actual noise change patterns when you move the volume?
Jan 03, 2015 | Roland Music
My Marshall MG50 DFX Has an awful buzzing sound that comes out of it after startup.
I would check C22 and C24 the main smoothing capacitors. They can fall out at worst or just have bad solder at best.
Mar 20, 2017 | Music
External Speaker hookup problem. I hooked up 2 external speakers (8 ohm, 160 watt) into my Marshall AVT 50 amp (tag on back says 4 ohm minimum). Everything worked fine, then I shut it down and now (next...
If you are competent with electronics, open it up and check the fuse(s). Especially if no lights come on. If you get voltage, then check the jacks you plugged into- they may have dirty interrupt contacts. When you plug the jack in- it opens those contacts that otherwise are closed making the circuit to the cabinet's built in speaker. Contact cleaner should clean them up if that is the issue.
While it is possible there is a power supply issue, you can see that quick with a voltmeter, it is not likely you did much more than blow a fuse.- very possible if you unplugged speakers with the amp operating..
If you think you killed it- you usually still get distorted noise.
Mar 29, 2012 | Marshall Amplification Music
I bought a Fender Frontman 212R back in March of this year. It worked brilliantly for almost six months, until July 26th, when during a jam session, the audio randomly cut out. Upon inspection, it appeared...
Try using your guitar cord to plug in and out of the headphone jack several times while unit is on. There is a circuit that disconnects the speaker when using headphones and the circuit is activated when something is plugged into the headphone jack. This "switch" can get dirty and cause the can get dirty and cause the problem you describe.
Aug 26, 2011 | Fender FM212 Solid State Electric Guitar...
I have a Yamaha GE 112c2 guitar. One day I was playing, and the sound suddenly cut off. The guitar was plugged in, the amp was on, and the volume was on high. I can't find a wiring diagram, or anything...
Sounds like the amp (or speaker) blew. Do you have anything else you can plug into the amp to test? If possible use a different cord to preclude that as a cause, too.
Jul 03, 2011 | Yamaha Electric Guitar
Marshall Mg 100DFX power on no sound it just cut out last time i played it.The fan has issues I wonder if there is a cooling sensor shutting down the amp output.I thought solid state amps were bullet...
Something has probably failed or become a bad joint. If you turn up the gains and volume to max is there any hiss or hum from the speaker? If not there will be a problem in the power amp or power supply. Check fuses at back. The speaker may be open circuit too, that is easy to check with a multimeter. If you can't get far yourself, you'll need a repairman.
Solid state amps are not that reliable these days, there are so many things that can fail due to all the effects that people demand to be built in. Look at how many people are reporting problems with ss amps here.
Apr 02, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
Speaker has become crackly, only when i play certain notes though. I tried a different cord and bass and its definitely the amp. I have never turned the volume over three quarters, Should I just switch out...
Before changing the speaker, check for debris or other things in the cabinet or grill that MIGHT be rattling..
Also, plug in an external speaker to the ext jack and see if it is clean.
Aug 18, 2010 | Fender Rumble 100 Bass Guitar Amplifier
Korg pa-50 no sound from right speaker but has sound from left
Several things to check:
If the speakers are cut off when externaal cables are connected to line outs, possibly the jack sensing switch for the right channel thinks that a plug is in there... you might cycle one in and out to see if that might fix.
Another thing is they LIKELY have a PAN control setting and it might be set full left. The external MP3 would NOT be under PAN control, only the keyboard voices would be affected by it.
Feb 01, 2010 | Music
I have a peavy mixer, 8 channels, 4 ohms, with phantom power when I plug in my guitar, the volume works good for about 2 seconds, and then gets real low, what is wrong, and how do I fix it
Please note that I do not have the schematic for this unit. One possibility is they have "foldback" protection to pprotect the power amps from excessive load. If you drive such a system hard, it will shutdown and stay down till you recycle the power.
Try this: Bring your gain up SLOWLY and see if the unit immediately cuts off at less gain than you have been trying.
If you reach a "trigger point", the unit probably is going into protection mode.
Sometimes people get junky speakers like car speakers and they are so inefficient compared to good music speakers that they overload these amps trying to drive them. You should be using name brand speakers like Peavey, Yamaha, etc.
Also I would like you to check your guitar on another system to make sure it doesn't cut out. MANY guitars have a battery amp in them and if the circuitry is bad or the battery weak, as soon as they are played hard, the battery collapses and the sound diminishes.
Do these tests I have suggested and see what you find out. I am an electrical engineer with lots of troubleshooting experience... If I could only reach out with my test equipment and measure a few things...
Dec 28, 2009 | Peavey 32fx USB 32 Channel Mixer
I have a spider III 15W amp that has worked for a year. plugged in last night and it's getting power but no sound. Not even a hum from the speaker. checked everything and it's definitely the amp....
Try disconnecting the speaker from the amp with the amp unplugged from your power. Never work on an amp when its plugged in unless you know how dangerous it is. Check for resistance across the speaker terminals with a volt ohm meter to see if you have a blown speaker. Thats the first thing to look for. You should here a hiss or a low hum when your amp is on and you plug a guitar cord into the input without the guitar. Check those two things first.
Jul 15, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Music Logo
364 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
