Our printer was working fine, then it made a funny noise and started printing blank pages. Now it won't do anything but give the code L 1. Do you know what that is? I can't find the manual
Sharp dx-c311 multi-function unit with L4-16 error. Fusing unit is thumping as if the rollers...
(More)
Sharp dx-c311 multi-function unit with L4-16 error. Fusing unit is thumping as if the rollers aren't lining up properly....when the fusing unit is in, the motor/fan runs constantly; when I remove fusing unit it stops.
I can send faxes, but can not print at all.
Need help ASAP!!
I have a Zinwell converter box and a Radio Shack antenna, both are properly hooked up to the ant...
(More)
I have a Zinwell converter box and a Radio Shack antenna, both are properly hooked up to the ant connection (only 1) in back of tv-vcr unit and the yellow and white connections in frt of unit are connected via a cable with r-y-w to converter box and y-w to frt of tv unit. At the advance record screen..channel 3 is showing in the selection box, if you insert a different channel it will not record that channel/program. Are there any converter companies that had the foresight to know that there are hundreds of tv-vcr combos still in use? I understand the mechanics for a stand alone vcr and I know how to manually record on the combo..but I want to be able to preset and for more than one channel and recording times. Thanx
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
