Question about Kenmore HE2 Plus Front Load Washer
I have a Kenmore HE2 Plus front loading washing machine that is about 2 1/2 years old. It just started turning on and then off again, all by itself. Last night we ended up jut unplugging it. And when I plugged it back in today and tried to wash a load of clothes, it turned off in the middle of the wash cycle, and then turned back on. It seems to be stuck in that cycle of turning on and off, so we have it unplugged currently. Any ideas of what this might be? Should we call for repair or is this something we can fix ourselves?
    Problem Solver:
  • 20 Answers
Check the drain plug at the bottom of the washer by removing the bottom panel. Most likely this is your culprit and you will need to drain it.
Posted on Sep 17, 2012
  • 15,935 Answers
Most likely it is the timer/control board.
It is a plug and play swap-out, but the tricky part is getting TO the board :D
Only you can determine if you have the skillset to attempt the repair - however without properly testing the components - you may just end up throwing $$ at the machine replacing good parts and still not find the problem.
This type of repair is best left to experienced repairmen. You will SAVE money in the long run.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Jun 17, 2009
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
I have an F11 code on my kenmore front load washing machine
After years of suffering from random F11 that became a permanent F11, I did the repair as in the video and all is good for 2 years. No more F11. About one load a day (we have kids!)
Aug 22, 2014 | Kenmore HE2 Plus Front Load Washer
What could be the reason that my Kenmore HE2 Plus Front Load Washer won't start?
Hi, Could be the door switch, make sure the door is shutting completly then try to start.
Aug 15, 2014 | Kenmore HE2 Plus Front Load Washer
My Kenmore front loading washer will not open
what is your model number is then we can get started then
Jan 17, 2013 | Kenmore HE2 Plus Front Load Washer
I have a 4 year old Kemore HE2 that isn't spinning the water out of the clothes. I encountered this issue about a month ago and found a fix for cleaning out the hidden pump trap. After removing a large...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 07, 2010 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore HE2 front load. It is blinking F-01. I tried pressing reset twice but it only lets me hit it once then everything goes off. Thanks
I have an old machine almost 30 years old and don't have these problems it is a simple machine with knobs. After all these years still works good.
Jun 29, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore front load washer (HE2Plus)
check to see if you still have a warranty on the washer other than that check the inner door seal if worn or crimped try to fix or replace it
Dec 16, 2009 | Kenmore HE2 Plus Front Load Washer
Blow breaker
I need the model n serial # to better assist you.
Thank you
May 10, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
186 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
