Question about AT&T Lucent Merlin SP 34 Phone
Changing the ring tone on a desktop phone
There are three phones (1 Avaya, 2 Lucent) in one office. We are trying to figure out how to change the ring tone on the phones.
What models are the phones?
Posted on Sep 27, 2009
I need to turn the ringer OFF on my AT&T 210/Lucent TrimLine.....sounds like a fire alarm...!!!
Search Results
FAQs - AT&T® Telephone Store
https://telephones.att.com/product-support/faqs/symptom/1591/89 Tip 1 of 8. If the phone does not ring at all, you may have the ringer turned off. The handset and base have independent ringer programming. To adjust the handset ringer volume: Step 1: Press MENU/SELECT on the handset when it is not in use. Step 2: Press ?DIR or ?CID to display Ringers, then press MENU/SELECT. Missing: lucent
[PDF]TRIMLINE® Memory Telephone 210 - Amazon S3
s3.amazonaws.com/szmanuals/62619bc8d4792f47b6654ed48c3548a3 AT&T and the globe symbol are registered trademarks of AT&T Corp. licensed to Advanced American .... Ringer Volume. The RINGER volume switch allows you to turn the telephone ringer OFF, or set it to ring at LO or HI volume. You can dial or answer calls normally when the ringer is off. Other telephones in your home will.
How to change the ringer tone on the AT&T Trimline 210 - YouTube
? 2:58
https://www.youtube.com/watch?v=xZxexCm7xtk
Apr 30, 2016 - Uploaded by kmbfanofpacman
I just figured out how that works after the day I got the phone and its pretty cool to be honest.Missing: my ‎lucent
[PDF]AT&T 210 User manual - Multi-Link Inc.
https://multi-link.net/wp-content/uploads/ATT-ATT210-Manual.pdf Make sure the ringer volume switch is not set to OFF. You may have inadvertently turned off the ringer. Press. ,. , , . If there are several other phones on the same ... 11. 12. For Customer Service Or Product. Information, Visit Our Website At www.telephones.att.com. User's manual. Part 2. TRIMLINE. Memory telephone 210. Missing: my ‎lucent
Lucent AT&T Trimline 210 Corded Phone Ring tone - Questions (with ...
www.fixya.com > ... > Lucent > Lucent AT&T Trimline 210 Corded Phone
Lucent AT&T Trimline 210 Corded Phone, ring tone related issues. ... If the ringer volume has been turned off, the handset will not ring ? ... ...ring tone im receieveing the voice ring tone but prefer the volume how can i change my ringtone When the phone is sitting in its normal mode hitting the "flash" button toggles through ...
Apr 07, 2018 | AT&T Lands Phones
How to turn off a phone from ringing when the main phone has a call
On the phone you want to change:
1. Press "Feature 0 0"
2. Press the line button to be changed until desired effect below
-- Steady Green - Immediate Ring
-- Slow Flash - Delayed Ring (after 20 seconds)
-- Fast Flutter - No Ring
3. Press "Feature 0 0" again to end.
That's all there is to it.
Jul 26, 2010 | Avaya Lucent Partner 616 Phone
Trying to change number of rings before voicemail
By default individual coverage is set to 45 seconds. Ask your phone vendor to reduce it.
Feb 20, 2009 | Avaya 5400 Series 5410 Phone
Using AVAYA 4610SW IP phone
Answer to the second problem :-
1. The changes in the ring tone has to be made by accessing the Avaya server where the phones are registered.
2. Log in to the avaya server...... enter change station <station number> on the command prompt
3. In the personalized ring pattern field, you can select one out of the 8 available options by typing any digit between from 1 to 8.
4. The ring pattern of that particular station will change accordingly.
5. Keep the personalized ring pattern of all the stations different by assigning different digits against this value
Jan 13, 2009 | Avaya 4610SW
Change ringtone
With the handset on the hook press the conf button (the one with three phones on it).
The phone should ring with your current ringtone. Each press of the conf button will advance to the next tone.
pick up the handset and put it down again to select the ringtone.
I think there are 8 to choose from.
Mar 21, 2008 | Avaya Definity 6408D Corded Phone
Ringer for Lucent Partner18D
Are you trying to change if it rings or how it sounds when it rings?
The phone you have (Partner 18D) can be used on several different Avaya phone systems that all program differently. To change when it rings, this would need to done in the system programming (not the phone) All the manuals are avaialble on Avaya's web site but you need to know which system you have before you can start searching. www.avaya.com
Nov 26, 2007 | Lands Phones
Phone Doesn't Ring Long Enough Before Going To VM
The phone you have can be used on different Avaya phone systems that program differently. It is certainly something that can be changed but you would need to know which system you have first. There is a call-forward no answer timer that send the call to another station or voice mail box etc.. after so many seconds. That is what needs to be changed.
All the manuals are available at www.avaya.com but again, you would need to know which system you have before looking for the manual.
Nov 15, 2007 | Lucent PARTNER18 Corded Phone
All phones ring
I take it you do not want all the phones to ring? You can change what phones ring under different circumstances by programming the main phone system. You can get all the manuals at www.avaya.com I'd start by searching for "Partner R4.1" at Avaya and see what shows up. It will take some time to learn the system and how to program it but it's usually worth the effort for simple changes like this. You will probably find yourself needing to make a few simple changes now and then.
AT&T Lucent Merlin SP 34 Phone Logo
203 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
