Question about Frigidaire FRS26R4A Side by Side Refrigerator
Its a side by side pure source the freezer part the coils behind the panel keep freezing up solid like a block than the fridge and freezer stop working is there some kind if drain that might be pluged or is it a defrosting element that might have went bad
  • 111 Answers
It can be the timer , element or hi limit
Posted on Jun 18, 2009
Freezer fan only run sometimes
If you nudged the fan and it started working it could be defective and needs to be replaced or it could be freezing up because of freezing condensation. Be sure that all the coils under and behind the fridge, if there are any,
are free from dirt and dust. If this is a refridg/freezer be sure the air vent between them, on the inside, is not blocked by anything. The airflow is necessary for proper temp control.
Apr 20, 2014 | Whirlpool Washing Machines
I have frost on the freezer side and both the freezer and fridge are not keeping the food / frozen items cold. The fridge seems to be running constantly
remove the rear panel in the freezer,and if evaporator coils a solid block of ice,take a hand held hair dryer and melt the ice,then remove the heater located under the coil and test it for continuity,if open replace it with g.e.# wr51x10055 heater element
Aug 07, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Side by side fridge , freezer will not defrost
It is most likely a defrost heater or termination thermostat. they are located behind the freezers back panel
Jul 14, 2010 | Kenmore 57029 Side by Side Refrigerator
Freezer on Bottom; evaprator fan keeps stopping,shuts of fridge
with the unit unplugged you might try coiling a piece of solid copper wire loosely around defrost heating element and into the drain slightly, the radiant heat transferd to the copper may keep the drain open and prevent this from hapening again. hope this helps
Mar 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a Westinghouse WSE6100SA - side by side fridge freezer. Still under warranty. The repair guys have been twice now to temp fix the freezer, to no avail. the freezer is not freezing or I should say...
sound like the air supply baffel is the problem / or if the lower air vent is freezing over then the water is building due to icemaker / the water overflows on the inlet water fill tube to the icemaker and running down the inside behind the panel / they can take the fill tube from a ge icemaker kit and cut it in half and slide over the tube thats in your frig and it will keep it from running over / a problem wgi has had for awhile now / if you havent call sears i would since they should know the same.
Nov 25, 2008 | Refrigerators
Freezer back panel freezes up
hi thanks for the question the problem you have is with either the defrost termination switch or the timer the defrost termination switch is located in freezer a small disc with 2 wires going to it replace this part thanks the appliance doc
Aug 14, 2008 | Frigidaire FRS23KF7AB Side by Side...
Samsung fridge RS2545SH every 7 days freezes fridge coil.
Hey how yo doing? on most refriderator there are two important parts to keeping freezer from freezing over, they are the bimetal thermostat and ice pipe heater. The bimetal therostat is a preset thermostat that ranges from 54degrees farenheit to about 60, when the coils (inside the freezer compartment behind the back panel) reach the preset temp. it closes a circuit and send electricity to the ice pipe heater, to warm the freezer coils preventing from freezing over. if any one of those components fail, your freezer will continue to freeze solid until there is no more space for ice to build on coils decreasing air flow from the evaporator fan blowing air into your fridge.To test you will minor knowledge on using a multimeter.(REMEBER TO UNPLUG REFRIDGERATOR BEFORE SERVICING, IF YOU UNCOMFORTABLE WORKING ON APPLIANCE PLEASE CONTACT A PROFFESIONAL REPAIR SERVICE..) If you'd like to continue please respond.
GOOD LUCK, WORK SAFELY..
Aug 12, 2008 | Samsung RS2630SH Side by Side Refrigerator
Kenmore side by side
Make sure the coils underneath and backside don't have large amounts of dirt on them. Check door seals with a dollar bill, go around the entire door. close the bill inbetween the seals and tug on the bill, if it pulls out to easy the door needs adjusting or seals need replaced. let us know what you found thanks
Dec 08, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Solid ice behind freezer panel door
your refrigerator has something wrong in the def system. the most common problem is the def thermostat.
Frigidaire FRS26R4A Side by Side Refrigerator Logo
125 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
