Question about LG WM-2277HW Front Load Washer
Smell while washing only
I have the same problem, my clothes don't stink, the filter and filter water don't smell.... and it is not mildew smell it is a bathroom smell. But while it is washing it smells, the smell goes away after it drains and is done spinning. It happens every time. Although there was one day that I did 4 loads of laundry in a row and the smell went away after the first 3 washes... so water maybe it sitting somewhere and stinky. But the clothes don't stink. WEIRD. Any Help Any one?
  • patty
    patty Nov 21, 2013
    while the smell stays in my clothes it dosent go away
  • 4 Answers
Unfortunately, a fetid smell to the output wash water is pretty common in front-loaders. Why front-loaders? I wish that I knew.
While my Whirlpool "Gallery" model was still in warranty, I had it checked several times without resolution, unhappily.
WHAT TO DO? Well, the idea of having stinking water "wash" my clothes was just too much to bear, so although I've been unable to unmask and solve the root problem, I have at least developed a technique that eliminates the symptom.
Before we get to it though, I want to address (as another writer already has) the matter of having a proper drain "trap," sometimes described as a U-shaped piece of pipe. Every sink and toilet in your home incorporates a trap that makes use of standing water (at the bottom of the "U") to serve as a barrier against sewer smells. It is possible, I suppose, that if your machine's waste water outflow was plumbed directly into a drain by an unlicensed handyman, a proper trap was not installed. In that case, a foul sewer smell might find its way back to your machine. Note: If your machine empties into a sink rather than directly into a drain pipe, the lack of a trap is not your problem.
Now that we've dispensed with that possibility, I offer this more likely scenario:
Washers rarely manage to empty all of their wash- and rinse-water. Some remains in a "sump" at the bottom of the machine---and stagnates there until the machine's next use. Over a period of a few days, a pretty nasty smell can build up--but generally NOT in the washing drum; rather, the smell is confined to the draining water and it's most noticeable if the machine drains into an open sink. And in my experience the smelliness of the effluent is limited to the very first drain cycle.
I suspect that the problem with the odoriferous water in the sump stems from the fact that organic compounds are present in a lot of the laundry chemicals that we use--most notably fabric softener, which contains emulsified vegetable or animal fats. A nice warm, wet, dark sump makes for a great smelly microbe growth environment!
In any case, here's a SOLUTION. I've learned to be practical about this matter. I haven't tried to engineer-out the problem. Then again, neither has the manufacturer, it seems. But here's how to rid yourself of the spooky problem of running a washing machine that smells at times like a toilet:
[1.] If your washer hasn't been used in a while (my rule is 24 hours; decide what works best in your situation), BEFORE you put any clothes in, start the washer so it fills for about 15 seconds.
[2.] Then advance the timer to a "drain" cycle. (Depending on the washer's controls, it may take you a few tries until you get the hang of this; your patience will be rewarded!) At this point you can expect to drain some very smelly water.
You have thus succeeded in clearing the machine of the foul stagnant waste water. You may toss in your laundry, choose your wash setting, and be confident that none of that water has contacted your family's clothes.
The two-step process is simple, takes little more than a minute, and probably consumes about two gallons of water. I view it as a pretty minor inconvenience in view of the benefit!
Note: If you are especially fastidious, in step #1 above, you can add a couple of ounces of any household cleaner that's labeled as being safe and helpful as a laundry detergent booster to the fill water. It will improve the "fragrance" of the effluent. I do NOT recommend using bleach as a sanitizer, as its residue might result in fabric discoloration.
Posted on Nov 26, 2014
    President:
  • 1,185 Answers
Like bad eggs ?
Do you have a U bend in the wastepipe that takes the water away from your machine
If not then any smells from the pipe run can come back up the outlet pipe
Once you have ran the machine it flushes away the old water and the smell goes away
Posted on Jun 17, 2009
  • patty
    patty Nov 21, 2013
    was there a recall on these machines?
Washing machine smelling
First i hope you have cleaned out your filter. For the smell: Switch from liquid to powder detergent, no fabric softner, not necessary. Clean the big gasket with detergent and run a half load (without clothes of course) very hot cycle with 2 cups of vinegar only. Leave the door open whenever possible. This helps in drying out your washer and preventing mildew. Shut your wall water valve after your wash. Actually you can search by clicking on "ask anything" indicating your problem, this site.
Click helped if really helped.
Apr 09, 2013 | Whirlpool Washing Machines
Clothes stink
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Causes of washing machine smell. What will remove the stink?
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 04, 2010 | LG WM1812C Front Load Washer
My GE Adora front loader- our clothes stink!
Clothes washing rules for mildew stink: 1) never leave clothes in machine for more than a few hours 2) never add too many detergent or clothes 3) clean the machine itself. Also if your fabric softener port is gummy there is a good chance you got some funk from that so clean all places where you have fabric softener contact. After all that, if this doesn't help you may need to run an empty load of strong hot bleach water and follow it with a hot empty rinse then a load of whites
to becareful not to ruin your colored clothes
Aug 09, 2009 | GE WSXH208A Front Load Washer
I have sour mildew smell problem with my clothes
Look inside the door to the gray rubber ring gasket thingy. Pull apart the sides and look in. Betcha a dollar to a donut there's mold in there. It's a gross, nasty problem whirlpool customer service doesn't give a damn about.That's where water sets after wash cycles. There are tablets call "Affresh" which can be run with hot water for a cycle to attempt to clean out the mold/mildew. Not cheap, not fair, and probably will only be a start to a maintenance type cure if you've had the washer for awhile. May take some manual labor with bleach as well. NOT a sanitary washer. This is an unbelieveable problem with a washer. Piece of ****.
Aug 06, 2009 | Whirlpool LHW0050PQ Front Load Washer
STINKING CLOTHES front loading mach.
One possibility is to not leave the clothes in the washer overnight or they will have a little foul smell to them. We have a Samson washer and it does the same thing and it ranks close to the top on Consumer Reports. If this doesn't help have you tried going to Lowe's and ask someone in the appliance department to see if they can help. You may have already done this but call the manufacturer to see if this is a common problem and see if they have a solution. If they're not very helpful or cooperative let them know you will do a little "free" advertising for them in a nice way of course. I hope this helps. I'm having trouble with a Bissell shampooer not dispensing the shampoo and also not picking up most of the water. It's really aggravating. Have a great evening.
Jun 12, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Kenmore Super Capacity Washer - Mildew smell
run the washer, with no clothes,
and 2 cups of bleach instead of detergent.
kills any mould in the washer
at least until you find the original cause, it wont stink
Oct 13, 2008 | Kenmore 3.2 cu. ft. Top Load Washer
Stinky clothes
The big door seal is probably the problem. Put on gloves and using a solution of Laundry detregent and hot water and rags, carefully wipe clean all the folds of the seal. It will be icky. Next run a cycle with some detergent and oxyclean or bleach if you have it.
Especially during warm weather, damp clothing left in a front loader mildew slightly very quickly- you can't really see much but you can smell it! So get the clothes in to the dryer immediately. You'll want to relaunder the smelly clothing after you have cleaned the washer.
Good luck to you and Thank You using FiX YA!
Aug 17, 2008 | Kenmore Elite 45986 Front Load Washer
Clothes smell.
Mold, mildew and other fun things use washers as a breeding ground. Clean your machine with a generous amount of white vinegar run through a cycle. Or there is a product called Affresh you can buy at Lowes or Home Depot.
Jun 21, 2008 | Asko W6221 Front Load Washer
New Bosch water not draining
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Apr 01, 2008 | Bosch Axxis WFL 2060 Front Load Washer
LG WM-2277HW Front Load Washer Logo
1,271 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
