Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Engine will not start
I have a Cub Cadet LT 1045, I was mowing the lawn, the engine turned off and now I cannot even get the battery to turn on, much less the engine to turn.
    President:
  • 1,111 Answers
You have atleast 2 safety switches on there. one under the seat and one one the brake. if either one would fail, the engine will not turn over! i had to replace mine last yr
Posted on Jun 17, 2009
LT 1045. Why no start, no crank?
you need to replace your battery with a brand new one. because you old battery can not handle anymore the power it needs to crank your engine.
Sep 03, 2015 | Cub Cadet Garden
Cub cadet super LT 1550 will not start. Worked fine when we mower last time, now is dead as a doornail
If you mean that the engine will not turn over when the key is turned, then most likely the battery died over the winter.
Jul 14, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet ltx 1045 wont start, no spark.
remove the top cover from the engine and remove the small wire from the coil if still no spark the coil is bad
Aug 07, 2012 | Cub Cadet Garden
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
Cub cadet riding mowe
is the mower making any sounds when u crank it or nothing at all?
Feb 07, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Motor will not turn over by the key switch on my cub cadet lt 1045 but it will if i run a jumper from the battery to the starter post
When you jump the starter, you are bypassing the safeties.
Check the neutral/brake safety and the blade disengagement safety.
Gary
Jul 18, 2011 | Cub Cadet Garden
Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter manually...red to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I have a cub cadet LT 1045 and every so often the blades will stop cutting even though it remains in the engaged position.
There are a few possibillites: a bearing is starting to go on the quill assembly or idler pulley; the PTO on the engine is heating up and quitting to work until it cools off; or you may have a switch going bad. I would look at this first.
HTH
Good Day
Nov 10, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet dead as a door nail
I have the same mower. The wires do need to be connected. It is a safety feature on the cubs. The engine will not start if the electric PTO is engaged. I just went into the garage, pulled the pto lever out to engage, pushed down brake, tried to start and it would not start. I suggest reattatching the wires and trying it. Hope this helps.
Apr 24, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
974 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
