Question about Frigidaire Freezers
Rats chewed the wiring in the compressor area and plug cord gone!
I just bought a used chest freezer with a rats nest in the compressor area. Thought I was getting a deal! After cleaning out the rats nest I discovered they had chewed a lot of the wires and the power cord is missing. They accessed the area through a 1 1/2'' hole in the back that looks like something mounted there. This unit was Mfg. for Sears by Fridgedaire and neither has a wiring diagram available. I can splice most of the wires by color coding but there are more wires than the picture Sears shows of the wiring harness they sell, leading me to believe something is missing. Sears parts breakdown does not show any cooling fan on this model. Can that be right? I suspect that something mounts to this hole in the back of the chest feeding into the compressor area but nothing reflects this in the Sears parts book. I don't know where these extra wires go without some kind of wiring diagram. Can anyone help me with a little info and/or wiring diagram. It is a Kenmore Freezer Model # 25311541102 Mfg. 12/01.
  • steve
    steve May 11, 2010
    No fan motor on a freezer compressor. The wires may go to the thermostat and or a start capacitor and or a external temperature sensor or light.
5 Suggested Answers
refritech08
  • 149 Answers
SOURCE: Chest Freezer Wiring
hi mel,
green with yellow are ground wires and usually are from compressor to system chassis from your 3 prong plug use the green wire and just find a point on the chassis to pin to if you can get model number you can find on kenmore website
Posted on May 09, 2008
tborn6
  • 700 Answers
SOURCE: Can I Mount Casters with Screws into Bottom of Chest Freezer?
youyr best bet would be to build a frame that the casters are welded to and there are no holes in the outer shell of the freezer. some L shaped angle would work nicely for this application and then there would be plenty of support for when the freezer is loaded up with product. Be sure that teo of the casters are lockable and two in the swivel freely.
Posted on Dec 27, 2008
  • 68 Answers
SOURCE: missing power lead
did someone chop the lead off it? if so why did they?
this freezer may be electricaly unsafe. If the lead has been chopped off then there should be the tails of the old lead still on the terminals, so just replace them with the new lead.
I would strongly advise you to test it for any potential shorts etc before you turn it on.
Posted on May 02, 2009
  • 117 Answers
SOURCE: freezer fan on compressor off
They make generic "compressor packs" to solve these. Your capacitors and relay and parts that support the compressor operation went out.
If you're really really like just the temp overload switch went and you can jumper bypass it. It usually looks like a piezo electric type of disc connected right onto the comp case itself.
But you're right with the DT, the motors go out on them a lot. They are usually for 4/6/10/12 hours depending on make and model. Sometimes the contacts go So if you could isolate them... they're on the larger side and will go from the power to the compressor. Use a jumper and test for a complete circuit to the plug and through the compressor before trying it.
By law all freezers and ovens have to have a schematic diagram on them. Often it it in a little plastic package and sometimes just wallpapered to the inside of a large piece of sheetmetal in back.
Good that you know how to use a meter!
Posted on Jul 14, 2010
Why My haier model hcm070la Chest freezer the compressor is not kick on
check thermostat, or relay on one side or back cclose to the compressor area there is a removable lid. removed and look for a thermostat disconect the 2 wires and bridge them then plug the the freezer on if runs replace the temp thermostat for a new one should be freezer thermostat
Nov 07, 2016 | Haier 7 cu. ft. / 198 liter Chest Freezer...
CHEST FREEZER NOT FREEZEING
2Possibilities. Some rat/mice may have chewed a wire or supply line to cause a leak or wire disconnect. Most likely you have a seal that has dried out and leaked the Freon out of the system. The compressor will turn on for a short while them turn off. Based on the age of the unit, repair is not advisable.
Oct 29, 2014 | Freezers
Norfrost c6aew chest freezer compressor wiring
What is the make and model of this freezer?
Mar 14, 2013 | Freezers
Kenmore freezer model C10BLEM blows circuits. I just bought it used. At original owners it worked well. I plug it in and after a couple of minutes it blows the circuit. I plugged it into the furnace...
If it is a chest freezer, almost certainly it is the compressor. Only way to check is to pull the power plug out then remove the compressor wires from the terminals then make sure it doesent touch the frame of the freezer, then plug the power back in and see if the power trips again. If not, there is the problem.
Aug 22, 2011 | Kenmore 22.7 cu. ft. / 643 liter Chest...
My GE chest freezer quit working. When I plug it
there is a chance that your over load and starter ptc has gone bad. the worst case your compressor has gone bad.
Feb 13, 2010 | Freezers
Our upright freezer is only freezing halfway up. have had the fan checked and it is ok. When i turn the freezer on, I hear the fan start up, but within five seconds, a click can be heard and it stops. I...
This is a reach here---it sounds like it could be low on refrigerant---but hold it---have you moved this unit from one spot to another--if so it needs set for 24hr before energizing it--also has mice made a nest in the compressor-condenser area---they may chewed on some wires--on some unit there a heater on bottom of compressor to keep the refer in gas so not to slug the compressor with refer liquid since liquid does not compress maybe locking up compressor. GL
Sep 18, 2017 | Freezers
Used chest freezer not cooling
chest freezer operation is among the simplest available. if the compressor is running and its not cooling there are only 2 possibilities. low or no refrigerant and or a bad compressor. so if you have the ability to return the unit I would. could luck peyton
Feb 01, 2009 | Kenmore 14.8 cu. ft. / 419 liter Chest...
hi mel,
May 01, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezers Logo
61 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
