Question about Canon PowerShot S2 IS Digital Camera
I changed the batteries in my S2IS powershot to the re-chargeable canon NiMH and purchased a second set of energizer NiMH batteries. When we changed to the new ones, neither set works! The camera won't turn on.
  • Helen Sanford
    Helen Sanford May 11, 2010
    Did you charge up both sets of batteries before putting them into the camera?
    Sergeant:
  • 321 Answers
Use enolop batt white color
Posted on Jun 18, 2009
Maximum sd card for canon powershot s2is
SD cards max out at 2GB. The S2 will not work with higher-capacity SDHC cards.
Mar 27, 2013 | Canon PowerShot S2 IS Digital Camera
Batteries do not last...using alkalineAA Energizer
That would be expected for alkaline batteries, especially if you are using flash. Try lithium batteries, or even NiMH rechargeable batteries-- those will be significantly better.
Mar 06, 2011 | Canon PowerShot A495 Digital Camera
I lost my power cord. Is there a way to charge the camera just by plugging it into the computer?
The S2is runs on 4 AA batteries. These are removed from the camera and recharged in an external charger. Such chargers can be purcahsed cheaply and Walmart or your local supermarket. Look for NiMH rechargable batteries.
Jun 15, 2010 | Canon PowerShot S2 IS Digital Camera
Display says to change batteries..have done and still says to change batteries
Strange as this solution might sound,m it works; clean the battery contacts in the camera, as well as the battery itself with alcohol. Even a small bit of oxidation, at the current level the camera requires, drops quite a few mvolts, enough for the camera to think your battery is running low.
Anand
Mar 05, 2010 | Canon PowerShot A710 IS Digital Camera
My Canon Powershot A2000 displays a low battery even when I've just replaced with new. I've replaced several times, each time with two identical batteries, each time from a different package. I may be able...
For the best results, I recommend you to use Canon rechargeable (NiMH) batteries. Rechargeable batteries provide the best performance and are the most economical choice.
Else......
AA alkaline batteries such as those from Energizer or Duracell will provide the best performance for non-rechargeable batteries.
Feb 11, 2010 | Canon Powershot A2000 IS Digital Camera
Canon PowerShot A630 power problem: NiMH batteries no longer work
I dont agree, I have tried several different batterie types and the batteries are draining almost instantly with the camera and they are not actually being drained. I think the camera itself is at the end of its life...as I have used rechargeable batteries for the last few years and now they wont even show as being charged on the camera. It stinks Im in your same spot now...no batteries are lasting even the brand new lithium ones...it has nothing to do with the battery "juice" but something with the canon supply power not recognizing/recieving the juice. Im not a canon expert, but I think the problem is more than the battery here Steve and im confused at the solution as well.
Apr 02, 2009 | Canon PowerShot A630 Digital Camera
Canon PowerShot A85
I decided to send you this from the Canon website to see if this helps:
Issue: What are the specifications for batteries that I can use in my camera?
Solution: Recommended AA batteries for your camera.
What types of AA batteries can I use? Canon rechargeable (NiMH) batteries For the best results, we recommend using Canon rechargeable (NiMH) batteries. Rechargeable batteries provide the best performance and are the most economical choice.
battery_charger_kit_cbk4_300.jpgThe Canon Battery & Charger Kit includes a battery charger and four rechargeable AA-size NiMH (nickel metal hydride) batteries. The battery kit can be purchase from the Canon eStore.
AA alkaline batteries AA alkaline batteries such as those from Energizer or Duracell will provide the best performance for non-rechargeable batteries.
  • ALL AA-based PowerShot digital cameras (including A Series and S5 IS / SX100 IS-type):"Never use manganese (non-alkaline) batteries."
  • Since the performance of alkaline batteries may differ according to brand, the operating time of the batteries you purchase may not be as long as the batteries that came with the camera.
Precautions:
  • Camera operating time may shorten at low temperatures when alkaline batteries are used. Also due to their specifications, alkaline batteries may expire faster than NiMH batteries. If you are using the camera in cold areas or for a long time, we recommend using Canon AA-size NiMH Battery Kit (a four piece set).
  • While it is possible to use AA-size nickel-cadmium rechargeable batteries, performance is unreliable and their use is not recommended.
  • Never mix unused and partially used batteries. Always load two or four (depending on camera model) fresh (or fully recharged) batteries at the same time.
  • Be careful to load the batteries with their positive (+) and negative (-) ends in the right direction.
  • Never mix batteries of different types or from different manufacturers. All batteries should be identical.
  • Before inserting the batteries, wipe the battery terminals well with a dry cloth. Oil from ones skin or other dirt may cause a considerable reduction in the number of recordable images or reduced usage time.
  • Battery performance deteriorates at low temperatures (especially with alkaline batteries). If you are using the camera in cold areas and batteries are running down faster than they should, you may be able to restore performance by placing batteries in an inner pocket to warm them up prior to use. But be careful that you don't put the batteries into a pocket together with a metal key chain or other metallic objects, as these objects may cause batteries to short-circuit.
  • If you do not plan to use the camera for a long time, remove the batteries from the camera and store them in a safe place. Batteries may leak and damage the camera if left installed during prolonged periods of non-use.
WARNING
Never use damaged batteries or batteries whose outer seal is completely or partially missing or peeled off, as there is risk that such batteries may leak, overheat, or burst. Always check the seals on store-bought batteries before loading them, as some batteries may come with defective seals. Do not use batteries with defective seals.
Oct 26, 2008 | Canon PowerShot A85 Digital Camera
Canon S2IS " change the batteries" problem
This worked for me after having the persistent "Replace the batteries" problem for about a year straight.
1. Reset the camera, according to the instructions in the manual. (Power on, hold MENU for 5+ seconds, selectOK, wait, turn camera off).
2. Remove the date/time battery for
two minutes (the tiny one in the battery compartment in its own little plastic holder). Replace after 2+ minutes.
3. Important: Insert freshly charged batteries into the camera.
I tried everything short of getting a new camera, and this was the ONLY thing to work for me. Its also simple enough that it takes 3 minutes to do, in case it were to ever happen again while on vacation, etc.
Good luck and I hope this helps.
Eric
Sep 27, 2008 | Canon PowerShot S2 IS Digital Camera
Energizer +AA NIMH Batteries consumed quickly
There are many grades of batteries under the same manufacturers name. They have a different Ah rating. The lower the Ah the shorter the time they will last.
Mar 02, 2017 | Energizer Duo Battery Charger for AA and...
Change batteries message pops up with new batteries
Chargeable batteries usually last for a year or two. Alkaline batteries should only be expected to last for around a dozen shots (as such, NEVER rely on alkaline batteries). Recommend buying another set of NiMH rechargeables. Make sure you get 2500 mah or better power rating (look on the package).
Jun 23, 2008 | Canon PowerShot A85 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
144 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
