Question about Lite On LVC-9015G
Can't close the tray now. (Before couldn't open the DVD tray.)
  • afishel Nov 24, 2009
    I also have teh same problem. I had to open the DVD cover and use a tool to open the tray. Now the tray opens and stays open. I can close it I can close it with the eject button, manually or with the remote, but it opens ans stays onen in about 3 seconds. Since I an not the only one with this problem there must be a fix from Liteon again does anyone know what the fix is?
    Alan
I was able to solve this problem by replacing a slipping belt about 2" in dimeter. on the DVD deck. everything now works OK. I had to "lay aside" a PCB to get accesses to the DVD deck.
Alan
Posted on Dec 27, 2009
I have the similar problem you had about the tray not opening. How did you fix it?
Posted on Aug 13, 2009
5 Suggested Answers
SOURCE: Locked dvd tray.
Press and Hold EJECT Button, While UNLOCK Is Displayed :-)
Posted on Feb 21, 2008
If you keep the open button pressed in for about five seconds it will say unlocked on the display and be back to normal
Posted on Dec 31, 2006
  • 4234 Answers
SOURCE: dvd tray will not stay closed. opens and shuts randomly
I'm not familiar with your exact model, but usually when this happens, the loading belt is at fault. There are microswitches inside which determine the limits of the tray movement. There is one that is activated to indicate that the tray is out and another to indicate that the tray is in. If the belt slips, the inner may not be activated and the system will cause the tray to come out. Try replacing the belt.
Keep us posted.
Dan
Posted on May 12, 2009
  • 6 Answers
SOURCE: DVD PLAYER DISC TRAY DOES NOT OPEN
tap it gently from the side while pressing the button......or with a knife try to open it gently...while pressing the button....after it,s open..clean the side n the belt..
Posted on Jun 26, 2009
How can I change the region on my Toshiba SD K860?
1. Power on the DVD player
2. Press the Open/close button on your remote control to open the drive tray and remove any disk
3. Press 2403960
4. Press 9 for multi-region playback. DO NOT Press Enter button on your remote control
5. You will see a 9 (region-free) on the TV (right corner)
6. Press the Open/close button on your remote control to close the drive tray
7. Power off the DVD player
8. Power on the DVD player and it is region free.
May 22, 2011 | Televison & Video
My DVD tray on my Yamaha DV C6480 (it holds 5 DVDs) got stuck in the half open half closed position. It may have come off the track. I opened the case and reinstalled the DVD Tray. Now the tray...
This happens to us all the time. Here is the note I keep on how to fix it quickly:
When tray gets messed up, the drive wheel (with pegs that interlock with pegs on the tray) needs to be such that the tray slides in and out freely. Push tray all the way in. Turn on.
Hope that gives a hint.
Nov 04, 2010 | Yamaha DV-C6480 Multi-disc DVD Player
Have panasonic dmr-ez485v error message -NO READ- changed disks used prerecorded movie same as my recorded disks, hit reset - still no change
I just saw the date on this message and realize that it was awhile ago. I assume that you have dealt with it by now... So for others who are trying to fix their DVD player:
I have a DMR-EZ485V DVD player and just started getting the error message "No Read." I couldn't find an answer on the internet and finally called Panasonic's customer service, (there is no charge 1.800.211.7262). Since it says "No Read" to everything--store-bought DVDs, burned DVDs, CDs; AND when there is nothing in there (it acts like it is trying to read when the tray is empty), the customer service rep thinks that I am having a lens issue. It either needs to be cleaned (can pick-up a product at Best Buy or Radio Shack) or, if that doesn't work, the lens needs to be replaced.
Aug 09, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Dvd tray not opening properly
You just simply replace the rubber wheel of an open / close motor. how to fix this: open the cover of the DVD and turn it on DVD, press the open button when the DVD tray out, you can see where the location of the rubber. The rubber usually has no more tense, not strong enough to pull and push the DVD tray.
Jul 26, 2010 | LG Televison & Video
The dvd disc tray opens all the time. I press close, or dvd or swith off, the tray closes but presently comes out.
Inside the DVD drive unit, there are a double microswitch on tray drive circuit board. Open this switch very carefully and clean the contacts. Carefully close the switch again. This cured my problem with the tray opening all the time.
Oct 22, 2009 | LG RH299 DVD Recorder/VCR
DVD Tray stuck open
the tray is not catching (underneath the tray is ridges). unplug the dvd player from the wall for 5-10 min...plug back up and give the tray a lite push while tapping the open/close button
Jun 17, 2009 | Yamaha DVD-C920 Multi-disc DVD Player
The open/close tray works sometimes only
seems you dvd player is getting problems due to dust formation. clean your dvd lens and parts inside using dvd cleaner disc. that would really help you.
Jun 05, 2009 | Philips DVD724 DVD Player
Dvd tray will not stay closed. opens and shuts randomly
i had exactly the same problem on a LG-RH278H resp. a Medion MD 81733. I solved it by opening the micoswitches, cleaning the contacts and streching the springs inside the switches a little. The Problem was, that one of the microswitches stayed conductive even when it was off/open.9acead3.jpg
May 12, 2009 | Televison & Video
Lite On LVC-9015G Logo
129 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
jason
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
