Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
My kenmore series 70 washer will not drain. - Kenmore 3.2 cu. ft. Plus Top Load Washer
    Genius:
  • 1,122 Answers
Check the lid switch-mike
Posted on Jun 17, 2009
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
How do i determine if my switch is working on my kenmore 70 series washing machine
i think there is some problem in wiring of spin and drain. thats y it works only for washing. current stops after washing. or otherwise click below link and check the manual may be its timer problem
http://www.askmehelpdesk.com/appliances/kenmore-washing-machine-70-series-repair-manual-479481.html
http://www.askmehelpdesk.com/appliances/kenmore-series-70-washer-manual-445690.html
Jan 04, 2012 | Kenmore Washing Machines
Kenmore Heavy Duty 70 Series Leaking in the back
If you bought a new washer and you still have a leak, i guess it was not the washer but where it drains into. Sink or stand pipe has a leak. unless you are useing the old drain hose from your old washer. Dry up everything and look for the sorse of water with a bright light when the washer drains .
Nov 22, 2009 | Washing Machines
Kenmore series 70 washer leaks during rinse?
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
Jul 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Kenmore 70 series filled and stopped...
Lid switch problem. Press down on lid and try to start machine. Reply.
Jun 15, 2009 | Kenmore 22422 Top Load Washer
Why My Kenmore 70 Series Washer Won't Drain Or Spin?
You need to replace the lid switch. This is located under the case. you have to take the case off to change this part. This is done by taking the 2 screws out of the front of the control panel. Then flip the panel back and remove the 2 brass clips that hold on the case. Then you can remove the whole washer case to get acces to the lid switch. This is a very common problem and an easy problem to fix.
Feb 13, 2009 | Kenmore 24932 Top Load Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
213 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
