Question about Kenmore 24 in. 15162 Built-in Dishwasher
I have a Kenmore Quietguard dishwasher, only a few years old, and it won't drain. I pulled it out and checked the drain hose, could not find a clog. I took the basket and sprayer out, couldn't find any clogs there. It seems to be making a little bit of a different noise but does still clean the dishes. Does the motor pump the water out and could that be the problem?
I have a Kenmore Quietguard portable that won't stay connected to my kitchen sink faucet. Checked all I can and continues to spray the wall and me without staying attached securely to the faucet adapter. Help!! Any ideas?
Posted on Jun 17, 2009
2 Suggested Answers
jbjaxiis
  • 95 Answers
SOURCE: kenmore dishwasher
Check the motor pump housing for an obstruction on the impellor. Impellors can go bad and not actually churn the water around the way they are supposed to.
Posted on Jul 06, 2008
Hi we have a Kenmore Dishwasher Model # 13744K and it won't turn on. It has water in the bottom that won't drain. Please advise. Thanks. John Webster.
For a dishwasher that was rated pretty high by Consumer Reports, it does not clean very well. In addition, the plastic control button cracked in less than a year and I must constantly clean around the inside of the door ... and I never received my rebate.
Despite those issues, it has been a workhorse. My wife is a daycare provider and the machine is used twice a day (on average) and still runs well. On a monthly basis, I alternate a pint of lemon juice and a pint of vinegar to keep it clean and once per year I use a granulated dishwasher cleaner.
Aug 14, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
I have a kenmore dishwasher #665.16022400. It does not completely drain at times, and quality of cleaning seems to be down. It is 3 years old.
In my experience, a clogged drain hose is usually the culprit here. If you have an air gap, I found it is useful to open up the air gap and run a still, long wire down the hose to dislodge a clog and then drain the dishwasher again. Rice is what usually clogs mine.
More details:
http://www.acmehowto.com/howto/appliance/dishwasher/check/airgap.php
http://www.youtube.com/watch?v=rmG2JXQL858
Mar 18, 2011 | Kenmore Dishwashers
Kenmore Quietguard 2 dishwasher not filling.
There is a solenoid that keeps the water in the washer. It is either faulty or there is something preventing it from closing completely. If there is no power applied to the washer, does it then hold water?
Apr 28, 2010 | Kenmore 24 in. 17002 Built-in Dishwasher
Dishwasher wont drain
There is a check valve that would prevent you from blowing back into the machine. I would recommend taking that hose and putting it into a bucket, turn the machine on and see if it drains, if so you have an issue with the house drain if not then take the hose off the machine. You can take the toe panel off with a couple of screws and the drain hose should be right up front. Have lots of towels ready to catch anything.
Apr 24, 2010 | Kenmore 24 in. 15932 Built-in Dishwasher
My 10 year old dish washer won't drain. After a cycle, it leaves a few inches of water in the bottom
hi..
There is a drain hose for your dishwasher that often gets clogged. Remove the drain hose and clean it out. reinstall the hose and your dishwasher will drain. The dishwasher should have a panel to remove and then comes out easily, just be careful not to pull it out too far. If this does not fix then you may need to throw some parts at it, but hopefully not. Good luck
thank u
rate me!!
Jul 25, 2009 | Whirlpool Dishwashers
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Nov 18, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Nov 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Quietguard Plus/Ultrawash - Kenmore
drain hose may be partially clogged or kinked up. ensure that the hose is not bent up thus restricting the flow of water out.
Nov 26, 2007 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher
Check that the pump spins freely.
Aug 29, 2007 | Kenmore 16879 Built-in Dishwasher
Kenmore 24 in. 15162 Built-in Dishwasher Logo
431 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
