Question about Roper RAX7244KQ Top Load Washer
Fix it myself
How do I lift the lid to get the shell off .  I am replacing the pump. i have the top where switches are laid back, now how do i open the top
  • 709 Answers
You are on the way.  Since you have the switches laid back now with clear space in front of the washer.  Remove the Screws from the back and roll the whole Body forward.  This will expose the inner workings of the washer for you.  I like to bring the washer out of the house to an open area to do this.  It makes the job a whole bunch easier. The lid does not pop up.
Posted on Nov 01, 2007
My Whirlpool washer won't pump out water or spin after I opened the lid.
Sounds like you have broken the lid switch, you will need to lift the head to get to the switch, once you see it you will notice how easy it will be to replace it. Good Luck!
Jun 29, 2015 | Whirlpool Washing Machines
How do I take the top off the dryer?
To remove the top, look on the back of the dryer and remove the screws hold the top to the body of the dryer. Once the back row of screws are removed, the top can be lifted, start from the back. The top acts like a clam shell opening first at the back. As you lift, you will find under the lid push pins in the top that go into holes in the base that attaches the top to the base. Pry between the lid and the base and the pins in the top will pop loose. Be careful for the control wiring coming up from the base not to pull it out once the lid the free from the base.
Feb 11, 2015 | Frigidaire GLGR341AS Gas Dryer
How to remove washer lid to replace lid lock
Remove power to the unit.
Locate the console and remove two phillips head screws. Most
models have them in the front, bottom of the console. In some of the newer models they are located in the back, bottom of the console. Some washers require you to remove two end caps on the console to access the screws.
After you remove the two screws, slide the console slightly forward and then up. The console will then hinge to the back of the washer.
With the console now hinged back, locate the lid switch harness.
Disconnect the harness and check for resistance between the 2 grey wires (outside) on the lid switch connector connected to top of washer. With the lid down the circuit should read no resistance. If the circuit is open(infinite resistance) then the switch needs to be replaced. You can also use a insulated jumper on the lid switch harness to determine if its the switch.
To replace the lid switch you will now have to remove the cabinet. Use a flat head screwdriver to remove the two clips holding the back of the washer to the outer shell of the washer.
Disconnect the lid switch harness(If not still disconnected).
You can now pull the outer shell away from the washer. Do this by
grasping the outer shell (I open the lid and grab it there.) and tilt the shell forward (toward you) and out. The shell is now removed and you can see the tub. Be careful not to bend the outside walls of the shell when removing and setting aside. This will help greatly when reinstalling the shell. Remove the 2 screws attaching switch to cabinet. Remove the screw connecting the ground on the cabinet. Use a flat blade screwdriver to push tabs on lid switch connector block to remove. Finally remove the whole harness from the 2 remaining retainer clips under the cabinet. Install new lid switch harness assembly and reassemble washer.
Apr 09, 2014 | Washing Machines
Washing machine stops mid-cycle, water doesn't drain
Sounds like you have a bad lid switch, or the plastic plunger on the lid that engages the lid switch is broke. if the plunger is broke, it is cheap, and only 2 screws to remove and put new one on. if that is not broke, check the lid switch. This model is a lid switch, and lid lock in one. You can test it before replacing it if you have a meter. you need to hinge the lid up to check and replace the lid switch. use a putty knife, on each side between the top and top of the front panel. slide the putty knife in one side, it will hit a bracket if your in the right spot. press in, and lift on that side of the top. do the same on other side, just don't let go of the first side or it will latch again. then swing the top back, the back side is on hinges. the lid switch is on the right side attached to the top. unplug washer, remove the 2 wires on the switch and check continuity. there should be continuity, or "open" when the lid is closed, and no continuity, or "closed" when you open the lid. if it is "closed" even when lid is closed, replace the lid switch. let me know if you have any further questions, shane.
Sep 12, 2009 | Washing Machines
Kenmoore washer , model 2262210 serial cl4434210, type111 . will not spin and does not drain . what are the possible problems . please help . thanks . T.W.N. at
if this is a traditional top load washer, then your lid switch might be bad. Usually when this happens, your washer will start fine. Your put it for a normal wash, it does its thing, lets in water, and agitate and stuff, but when it goes to the spin cycle. it stays in that cycle and wont advance. Leaving you with a tub full of water. Like i said if its a traditional top load kenmore, the lid switch is the the gray looking part when you open your lid. when you open your lid, youll see two screws holding it. But you have to take the whole shell of the waher to get to it....take 2 screws on the back corners of the counsel, then flip the counsel up. Locate to metal clips and pop them put with screwdriver. unclip the lid switch connector located by the clear hose that runs down. then lift and pull the whole shell towards your and acess the switch from underneath. put back together how you took it apart.( MAKE SURE THE CLEAR HOSE THAT RUNS FROM THE TOP COUNSEL TO THE TUB DONT GET PINCHED BECAUSE YOUR WASHER WILL OVERFLOW WITH WATER) like i said if its a tradidonal top load kenmore....hope this helps
Aug 12, 2009 | Washing Machines
Washer will spin but won't drain automatically
are you sure it spins? usually something is in the pump like a sock. You could remove the front and take the hose off the pump to see if its clear. It also sounds like it could be the lid switch. if you have to close it make sure you hear a clicking noise from the lid switch.
May 14, 2009 | Maytag Washing Machines
How do I replace the lid switch on my waher it's a Roper
buy a replacement switch and the top lifts off from the front.  It could be the switch has only come loose or the probe on the lid has broken off.
Feb 27, 2009 | Roper RAX4233PQ Top Load Washer
How does the top come off ge washer model wjxr2080t6ww
Use a putty knife to push the spring clips in where the top of the front panel meets the washer top, about 2 or 3 inches in from each side. Front panel pulls forward and lifts off pegs, revealing two 1/4 inch drive hex screws holding top to side panels. If your washer has the lid switch near the front, push the tab on the back side toward the center of the switch and push switch up, then twist 90 degrees and pass switch back through the opening. Now lift washer top at the front side. Most washer tops will unhook from the back side now, but some need to be slid an inch to the side yet to remove once the top is lifted a few inches. If you model still has the lid switch near the back of the washer opening, lift the top at the front and unhook the back of the washer top, pull the top forward a few inches and unplug the lid switch disconnect block. (two wires)
Oct 12, 2008 | GE WVSR1060A Top Load Washer
Maytag Atlantis washer will not drain and spin unless you lift the lid
The cheaper thing to check first is is your lid bent? The lid switch is in the center of the lid. If it "droops" or has been bent, it shaft on the back of the lid cant hit the switch. Open the lid and apply pressure in the bottom, center of the lid. This usually corrects the problem without replacing the switch.
May 31, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Taking off shell of washing machine
Remove the shell:
nplug the machine. Remove the end caps on both sides of the console by putting a flat screwdriver in the top of the end caps from the back and gently prying up. Remove the two Phillips screws holding the corners of the console down. Lift the console and gently fold back. Unplug the lid switch. That's the 3-wire quick disconnect below the timer. (If you have a high price model, you'll have three hoses under a plastic cover on the left. disconnect those hoses before going further.)
Using a flat screwdriver remove the gold clips holding the cabinet to the back. Place the blade of the screwdriver in the indentation closest to you and tilt the handle of the screwdriver back.
Open the lid. Lift and tilt the entire cabinet toward you. Look down through the hole to the front bottom edge of the cabinet. It is hooked under the front edge of the washer frame. Remove the cabinet and place it aside.
Replacing the shell:
Pick up the cabinet, hook it under the front of the frame, and tilt it back into place. Push the sides of the cabinet in as you are tilting it back to make sure the hooks in the frame (back, sides) line up with the cabinet. You can know it's in place when the edges of the cabinet line up evenly with the edges of the back.
Re-install the gold clips. Hook them into the back panel, put them into the slots in the cabinet, and push down until they snap into place. Re-connect the lid switch. Lower the console. Replace the screws. Replace the end caps - bottom first, then snap them in at the top.
Happy washing!
Mar 11, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Roper RAX7244KQ Top Load Washer Logo
54 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
