My dryer is generating heat but not drying the clothes. Does not appear to be moving the clothes around when on. Dryer is only 3 years old. Please help. Cant do without a working dryer not even for a day
The belt can be replaced as follows. 1 remove top and front of dryer shell 2 belt goes around drum around motor pully then under tentioner wheel 3 replace front and top of dryer (top pops off use a slotted screw driver) Thanx for using Fixya Please take your time to rate me
If your Whirlpool LTE6234DQ3 dryer is not drying clothes properly on the automatic/permanent press cycle, there are a few parts that may be causing the issue:
Moisture Sensor: The dryer's moisture sensor detects the level of moisture in the clothes and adjusts the drying time accordingly. If the sensor is dirty or faulty, it may not be able to accurately detect the moisture level, resulting in clothes not drying properly. Try cleaning the sensor with a soft cloth and see if that resolves the issue.
Thermostat: The dryer's thermostat regulates the temperature inside the drum. If the thermostat is faulty, it may not be able to regulate the temperature properly, leading to clothes not drying properly. A multimeter can be used to test the thermostat for continuity.
Heating Element: The heating element is responsible for generating heat in the dryer. If the element is faulty, the dryer may not be able to generate enough heat to properly dry clothes. A multimeter can be used to test the heating element for continuity.
Ventilation: Poor ventilation can also lead to clothes not drying properly. Make sure the dryer's venting system is clean and free of blockages.
It is recommended to have a professional technician inspect and diagnose the issue if you are not comfortable with checking and replacing these parts yourself.
Run the dryer for 2-5 minutes. Check to see if it has heat inside. If not, you have an internal problem. If heat is generated, check your dryer lint trap. It must be clean before every dry cycle to dry properly and efficently. If the trap is clean and heat is generated, check the tubes behind the dryer for disposing of the lint.
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
if your clothes are damp because you say it does dry some what then it sounds like it could be the gas coils,the coils will work for awhile but then they fail and the timer will not move if there is no heat on the more or less
this will most likely be a problem with the heating element or a thermal cutout which are usually located on or around the element.some makes have cutouts with a reset button whitch when pressed will restore heat.
There is a thermostat inside the machine just inside and top, put your head in and look up. Took my whole machine apart before finding the wire which led to it!! It should be Normally Closed (NC) and cuts the power to the heating element when too hot or broken! Hope this helps.
