Question about Casio Office Equipment & Supplies
How do you fix missing dots in calculator lcd display?
  • Chris Mar 13, 2013
    same problem on one of my calculators. And also on a bank card reader. On both devices, it is intermittent so it should be fixable?
Need to change my display from a comma to decimal
I don't know which particular calculator model you have, but for an HP-12C, the manual says the following:
Digit Separators
As a number is keyed in, each group of three digits to the left of the decimal point is automatically separated in the display. When the calculator is first turned on after coming from the factory - or after Continuous Memory is reset - the decimal point in displayed numbers is a dot, and the separator between each group of three digits is a comma. If you wish, you can set the calculator to display
a comma for the decimal point and a dot for the three-digit separator. To do so, turn the calculator off, then press and hold down the [.] key while you press [ON]. Doing so again sets the calculator to use the original digit separators in the display.
Oct 25, 2013 | HP Office Equipment & Supplies
My calculator is clear all setup...how to back normal function.... and how to setup this..
Press [SHIFT][9] (CLR). Then select 3:All.
Everything will be reset to default.
To setup press [SHIFT][MODE](Setup) and change the
settings you want.
1: to use MathIO display mode; 2: to use the LineIO, 3: 4: 5: to change the angle unit. 6:Fix to set Fixed number of decimals, 7:SCI scientific notation display, 8: Norm for Normal display mode. (read your manual for that).
By pressing the Arrow Down button you get other setup choices.
1: to display mixed numbers, 2: for improper fractions, 3: Stat; 4: to chose the dot or the comma as a decimal marker. 5: to adjust contrast of the screen.
Jul 18, 2011 | Casio FX82ES Scientific Calculator
I am using my Casio fx-300MS and have somehow gotten into the display where it puts my answers in exponential form; 5+5 = 1.0 exp10 to the 1. How do I return to getting my answers in standard form?
Display Format
To change the exponential display format, press the [MODE] key 3 times.
Fixed number of decimal places:
Press 1: Scientific Notation: 0
Press 2: SCI: 0
Press 3: NORM
You will then be prompted for NORM 1 or NORM 2. CHOOSE NORM 1
To return the calculation mode and setup to the initial defaults, press [SHIFT] [CLR] [2]
[=]. This will return the calculator to the following settings:
Calculation mode COMP
Angle unit Deg
Exponential display format Norm 1
Fraction display format a b/c
Decimal point character Dot
Percentage Calculations
Apr 13, 2011 | Casio FX-300MS Calculator
I turn on the calculator and all I get is a small black square dot in the upper left corner. TO Connect can read the unit, but nothing works on the display.
If the small black square does not blink The Calculator is Locked
it need an hardware reset
let me know if you if you want to fix the Calculator
ecrdn@yahoo.com
Jack
Oct 21, 2010 | Texas Instruments TI-84 Plus Calculator
I just replaced the batteries in my HP 12C calculator and when I turned it back on the display looks like this 0,000. How do I get the display to show decimals instead of a comma?
Here is what the manual for the HP 12C Platimum financial calculator says on page 17 of 275
Digit Separators
As a number is keyed in, each group of three digits to the left of the decimal point is automatically separated in the display. When the calculator is first turned on after coming from the factory — or after Continuous Memory is reset — the decimal point in displayed numbers is a dot, and the separator between each group of three digits is a comma. If you wish, you can set the calculator to display a comma for the decimal point and a dot for the three-digit separator. To do so,
turn the calculator off, then press and hold down the [ . ] key while you press [ON] Doing so again sets the calculator to use the original digit separators in the display.
Hope it helps.
Oct 06, 2009 | HP 12c Calculator
TI-30xIIs calculator
This function is FIX or FSE near the dot [.] or above it, so press [2nd] the the [FIX] where it located button [.] for example then the dot [.] him self: [2nd] [FIX] [.]
Rate me, thanks.
Apr 16, 2009 | Texas Instruments TI-30X-IISTK Scientific...
Rounding function on my TI-30xIIs calculator, it won't turn off.
Rate me, thanks.
TI-85 Display Has Missing Lines
have u ever modded it? it can (and probably will)damage the screen (graphics driver)
Oct 26, 2007 | Texas Instruments TI-85 Calculator
5 column pixels missing
This sounds very much like the conductive rubber strip that is between the LCD display and PCB is not making contact. This can happen if the calculator has been dropped or bent.
Oct 01, 2007 | Texas Instruments TI-83 Plus Calculator
1,244 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
