Question about Nikon Coolpix 5400 Digital Camera
Lens failure Lens does not retract properly and does not reach full zoom.It states lens error. Is it fixable ?
Re: Lens failure
This happened to me last month. You can send it to Nikon for a free estimate on repairs. You only pay the shipping and they will ship it back to you if you decide not to fix it for free....only they don't tell you what is wrong with it. I suppose they don't want you to take it somewhere else to have it repaired for less money. It cost me 162.50 for a service B2...150.00 for the lens issue and 12.50 to ship it. Funny - they do charge you to ship it if you pay for them to repair it!!!
Posted on Apr 18, 2008
0 characters
3 Points
How can I rectify the "zoom error" message on screen - also the lens will not retract either
Unfortunately a "zoom error" message is not something that you will be able to fix. This error indicates a system failure (apparently your lens is damaged, since it will not retract) and requires the camera to be sent in for servicing and repair.
You may find it more cost effective to purchase a new camera as opposed to the repair price on your current camera.
Oct 12, 2010 | Fuji FinePix J10 Digital Camera
Digital zoom error on an A600, lenz will not retract either
Have you tried spraying a can of compressed air into the lens assembly? All it takes is small piece of debris like a grain of sand to jam up the assembly.
Hope this helps
Jul 07, 2008 | Fuji FinePix A600 Digital Camera
Zoom lens won't retract on fujifilm f410
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Load new or fully charged batteries.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix F410 Digital Camera
Hi, my zoom is stuck out and won't retract.
Your lens motor is most likely burnt out. The only way to continue taking pictures is push the lens in manually, You may have problems with the focus after doing this, so just turn the lens manually until you are zoomed in properly. If you have a warranty now is the time to use it.
Jun 26, 2009 | Fuji FinePix A600 Digital Camera
Lens does not zoom in
This is not a common error on canon digital. This is caused due to possible short in zoom control circuit (main pcb). At normal use, if the lens does not retract due to mechanical jam, when the zoom control button is pressed, lens error 18 message supposed to be displayed. Since control circuit is shorted and faulty, error 18 message was not displayed. The remedy for this problem probably requires a replacement of a main pcb. Replacing a main circuit board may run around $100-140. -James
Mar 29, 2009 | Canon PowerShot A640 Digital Camera
Zoom lens will not retract.. Canon Power Shot S21S
the block is damaged ...see if the lens barrels are a little bent or something....
Mar 06, 2009 | Canon PowerShot A75 Digital Camera
Lens will not retract
With Battery out try to pull the lens towards outside
Do that gently do Don't rip it off !!!
Probably you will hear a click sound and If you do,
than put the battery back turn on and you should be fine
Every case is different so of the lens is jammed this will help
If the lens assembly is damaged than the only way is to sell the rest of the camera for parts.
Jan 29, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Canon Powershot SD1000 Lens Will Not Retract
This is a huge recurring problem with Canon cameras. check out this website-give it a minute to load. You will see literally thousands of people with the same experience.
Aug 18, 2008 | Canon PowerShot SD1000 Digital Camera
Lens stays zoomed out, no error messages
i'm sure it's broken(the camera) take it to a service and get it fixed....
Mar 26, 2008 | Canon PowerShot A460 Digital Camera
Usually down to the lens block assy being faulty.Is the lens retracting and opening properly?.It usually turns out to be worn gears in the lens drive assy or the result of a fall.Either way will be expensive repair!My advise is check and see whether camera is covered by insurance for accidental knocks.,
May 09, 2007 | Fuji FinePix A400 Digital Camera
Nikon Coolpix 5400 Digital Camera Logo
95 people viewed this question
Top Nikon Digital Cameras Experts
Are you a Nikon Digital Camera Expert? Answer questions, earn points and help others
