Question about Sony Playstation 3 (PS3) Console
My ps3 has no signal to my tv
My ps3 has not signal on any of the tvs in my house . it is set up correctly but the tv still says it has not signal. it worked fine up until this morning what should i do ?
    President:
  • 2,653 Answers
While the PS3 is off (red led)
Hold down the power button until you hear two beeps, quickly release.
Let me know if that fixes it.
Posted on Jun 17, 2009
Ps3 turns on but no signal on tv
Hi There,
Is the TV set for the correct input?
I assume you are using HDMI?
If all settings and input selections are correct then I will have to say that either the HDMI cable is faulty, or the HDMI port on either the TV or PS3 could be faulty.
Check if PS3 can work on another TV with the HDMI cable.
Check if another Device can work on that TV with the HDMI cable.
Try another HDMI cable.
From this, you should be able to determine where the issue is sitting.
Hope this helps!
Jan 13, 2016 | Sony Playstation 3 (PS3) Console
I have color on all but 1 TV station. That staion has color on other TV's in my house. Any sugestions?
Ur tvs in ur house it is getting a paid tvs incomming broadcasting tv signals like a cables or a satalites dishes companies?Yes,than that incomming broadcasting wire that plug into ur tv Ant. input port hole might have some kind of signals interference at that channel frequencies,call ur cables tvs or satalites tvs companies providers for an answers and get their field Tech. to come out and check it out.If all ur tvs in the house are analoge tvs and u are using a DTV signal through a DTV converter box to getting a Free over the air DTV air to recieving tv broadcasting tv channels stations only than tries it with another antenna signals sources like a better antenna design like a portable digital antena or good roof antenna should solved this problems.
Oct 03, 2011 | Philips Magnavox 20MS3442 20" TV
I recently moved house and have connected my ps3 80gb to a TV not previously used to connect the ps3 to. When I switch on the ps3 all I get apart from the Sony log on tune is multi coloured vertical wavy...
It sounds like the PS3 is sending a signal that the television isn't 100% compatible with. I'd start by plugging the PS3 in using standard RCA jacks, and making sure that the video and audio configuration settings are all set to automatic. Then, plug back in using the HD cords that you have, and the PS3 should reconfigure its signal output to match what the TV can handle.
Mar 16, 2011 | Video Game Consoles & Games
My ps3 works fine with the hdmi cable on one tv but when plugged to another tv picture will not show but still have sound how do i correct it???
okay go into the setting of your ps3 and make sure you have the correct settings for it sometimes it resets it's settings. Also check the tv ports you're using to make sure they aren't damaged, or if it's dusty, also some tvs don't have the right ports so for this you could try hooking it up to a vcr while the vcr is hooked up to the tv and see if that works; which is what I have to do with my TV in my basement.
Jan 22, 2011 | Sony Playstation 3 (PS3) Console
Lost the direct TV signal to the TV when nephew pushed a button on the remote (he doesn't remember which button) The other TVs in the house receive signals per usual.
Your nephew must have pushed the "Input" button on the remote. The TV is now looking for signal at a different input.
On the remote, press the input button until the TV switches back to the correct input. Make sure the satellite receiver is turned on so when the TV lands on the correct input, you will know it.
Dec 17, 2009 | Cars & Trucks
I have just recently bought a second hand PS£
Ohhhhh u got there a problem i had months ago. PS3 only gives u one output signal at a time, that means either u use it hdmi or u use it the normal rca way.Bad thing is that the ppl at sony didnt think of this kind of situation.
What u need to do is go to ur friend's house and use his hd tv to config ur ps3 to the correct output signal(rca), both on video and audio. If u bought the ps3 from ur friend, he should know how to do it, since he had to config it to hd in the first place. Be sure to probe it with the config u are going to use at home :)
Nov 01, 2009 | Sony Playstation 3 (PS3) Console
Won't keep digital signal
If you're connected to a digital cable box, I would try using the external component connections and bypass the TV's tuner. If all you have is straight cable coming into the house, it could be the cable signal itself or a defective tuner in the TV assuming all the menu settings are correct in the TV.
Jul 25, 2008 | Toshiba MW20H63 TV
Hdmi connection
Hi theromanator ,
Please switch on the ps3, go to the menu and change the video out setting to hdmi. this should solve your problem
Please vote for me if this solve your problem
ramesh22
Jun 07, 2008 | Insignia 37" LCD Flat-Panel HDTV
Sony Playstation 3 (PS3) Console Logo
155 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
