Question about Yard Machines 24a 021h700 4.5 Horsepower Chipper/Shredder/Vacuum, Push Model
Same Problem with the 4.5hp B.S. 21" Yardmachine Walkbehind Mower
I have the 4.5hp 21" yardmachine walkbehind and mine is doing the same thing. The govenor springs are ok. Changed spark plug,gas,oil airfilter. Mine runs high then low to almost a stall and it continues to do that until it runs out of gas. I have contacted a few people and they seem to think its the 2 springs that control the idle speed. Mine seem to be in check. I have tried to adjust the springs the best I can but I feel even if i have them perfect it wouldnt fix the problem. I want to fix this mower only so I dont have to buy another one. But at the same time I dont want to put ANYMORE money into the heep if it will not work. Please HELP!!! Thanks!!!
  • 1 more comment
  • jeffrey_x_ti Jun 17, 2009
    This is how its reads: 10H902 0285 E1 04011252
    Thanks for your quick response!!!
    jeff
  • jeffrey_x_ti Jun 25, 2009
    It helped a little bit... but not completley. I just sold it to a friend who new it had a little problem and I just bought a new mower. however, your directions / instructions were perfect! Thanks! A+ Thumbs Up~!~
  • Dwain Pippen May 11, 2010
    Sounds like a fuel delivery problem to me. What is the Model # on the engine, not the one on the deck. Should be around the sparkplug. There will be a Model-Type- Code stamped into the starter cover.
  • 376 Answers
This is what I would do... Remove the fuel tank and carb assy.. Two bolts, one behind the gas cap and one on the end of the tank. Pull it straight off the intake pipe then unhook it from the throttle link. Now, unscrew the carb from the tank. Clean the carb with a can of carb cleaner. Slip the screen off the pickup and make sure it's clean. Discard the pump diaphragm and gasket. Buy a new pump diaphragm kit, part #795083. Clean the top of the tank where the pickup with the screen fits into. Put it back together. Remember to put the rubber diaphragm against the tank and the gasket on top of it then the carb. Don't forget to attach the breather tube when you're putting it back on the engine. That should fix 'er up. Also, if the rubber ring and plastic retainer ring came off on the intake pipe when you pulled the carb and tank off, put them back in the end of the carb before sliding it back on the intake.
Posted on Jun 17, 2009
  • Dwain Pippen Jun 25, 2009
    Did that fix you up? It should have. If so, how about a 'thumbs up'..........:)
    New Friend:
Remove blades and put three guinnie pigs under it
Posted on Dec 16, 2012
Will my 16 hp Briggs from Craftman rider fit Scag walkbehind?
you would need to see what size crank shaft the scag had on it most motors used the same bolt down the same and you could always drill new holes so the shaft size to fit the pulley the scag had i put a 25hp briggs on my riding 61'' scag it had a kohler bolted right on the wiring was different
Apr 19, 2012 | Craftsman Garden
My 3 month old yardmachine 21 inch push mower will not keep running. I can get it to start, it half idles and shuts off/ I have taken off the air filter and put gas directly into the prime and as long I...
The carburetor most likely needs a thorough cleaning. There is something in there stopping things up. Also check that your gas can is clean of debris. Also check the fuel tank, possibly have to clean it. I once found a dead wasp in a gas tank, I guess that it got there from a gas can.
Aug 06, 2011 | Garden
My lawnmower (yardmachine by mtd) runs for about 10-15min and then it starts to sputter if I shut it off and let it sit I can then start it back up and it will run again for about 10min or so before the...
This sounds like a fuel supply problem. Like there is a restriction in the fuel supply some where. Pull off the main fuel line from the carb and check for fuel flow. Poor fuel flow here can be either a fuel tank port clog or an in-line fuel filter (if so equipped) If the fuel supply is good there then the problem is inside the carb.
http://www.ereplacementparts.com/mtd-11a54mc006-2009-push-walkbehind-mower-parts-c-20039_20100_133234_21459.html#part_343018
If this is the first start of the season you may have to remove the carb float bowl as shown on the bottom of item 14 the above link to clean out the jet orifice in the threaded area of the carb. where the bowl nut attaches. Make sure you remove all debris in the carb float bowl area. You should also have good fuel flow any time the float is positioned below horizontal.
Here is a little about my experience:
http://blog.fixya.com/index.php/2010/05/award-winning-service
Thanks for choosing FixYa,
Kelly
Jun 12, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Mtd snowblower yardmachine 3 hp/21"
if you are standing at the handles of the snow blower , kneel down there should be a sticker on the drive cover between the wheels , hope that helps
Jan 13, 2011 | Mtd Garden
Lawnmower won't start
Remove the bowl from the carb. and blow it out with air.
May 07, 2010 | Mtd 22" Yard Machine Push Mower
22" yardmachine starts and stops
loosen the bolt on the bottom of the carburetor up and let the water out and then re tighten and try it
Jul 22, 2009 | Mtd 22" Yard Machine Push Mower
Don't know exactly where to grease gears.
If its a walkbehind the transmission housing is sealed. DO NOT OPEN
May 06, 2009 | Garden
Yard Machines 24a 021h700 4.5 Horsepower Chipper/Shredder/Vacuum, Push Model Logo
933 people viewed this question
Top Yard Machines Heavy Machinery Experts
donald boissonneault
Phil Walker
Phil Walker
gerald martin
Level 1 Expert
Are you a Yard Machines Heavy Machinery Expert? Answer questions, earn points and help others
