Question about HP Office Equipment & Supplies
Service error 49.4c02
I have a hp4700dtn and a hp4700n, both are color laser jets. They a both displaying a service error 49.4C02. I have attempted to disconnect them from the power source and reboot. Post calibration the service error returns. I don't know if there was a pdf file in the process of printing or if the printer que contains pdf files. All pc's mapped to these printers are currently locked out. Can you please help?
Thank you
Terry
  • 52 Answers
Found this on hp forums try and see if works for you to.
"Try unhooking the printer from the computer. Turn the printer off then back on. and when the memory starts counting up hold the check button until the three light below turn on then release. then arrow down to cold reset and hit the check mark and see if you get past the 49 error"
Posted on Jun 17, 2009
Hp laser jet pro 400 m401 printer 59.A0 error
SOURCE:HP color laser jet printer is displaying error
Developing disengaging motor error. Run the component test to verify that
the print developing disengaging
motor is working correctly.
. Reconnect the connectors J468 and
J1020 between the developing
disengaging motor and the DC
controller PCB.
. if motor is not rotating Replace the developing disengaging
motor.
or
problem due to cairtage leaver lock cairtages not engage properly i hv found max problem of this leaver it found damaged due to improper opening the doorpls follow
above steps if problem not resolved then call hp engr for 4th step.
I Hope It Works.
Sep 15, 2017 | HP Office Equipment & Supplies
HP COLOR LASER JET 2605 PRINTER 49 ERROR MSG DISPLAY SOLUTION
49 errors are most commonly caused when the printer receives a print job with commands it does not recognize. You can try updating the firmware as this will often resolve the error. Go to HP's website to find the most recent firmware, however this model is fairly old and likely the firmware update will be fairly old.
Sep 25, 2014 | HP Laserjet 2605dn Workgroup Laser Printer
I have an hp laser jet color printer 4650n which is giving me a code of 49.4C02 service error
Printer error code "49.4c02" is one of them. It occurs when there is corrupted data. This may confuse the printer, and it stops functioning. In other cases, the data is corrupted while being transferred to the printer. Some printer models are naturally prone to this error because of their driver, while others can display this error while printing a specific font.fix printer error 49.4c02
Hope this helps you.
Sep 01, 2010 | Office Equipment & Supplies
Hp color laser jet printer is displaying error 59.co on the display pannel
controller PCB.
motor.
or
problem due to cairtage leaver lock cairtages not engage properly i hv found max problem of this leaver it found damaged due to improper opening the doorpls follow above steps if problem not resolved then call hp engr for 4th step
May 14, 2010 | HP LaserJet 4700 Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Oct 12, 2009 | HP Color LaserJet CP4005dn Network Printer
Hp 5500 dn with 49 4C02 error
Replace the jet-direct card. don't forget to install the IP address on the new card.
Apr 14, 2009 | HP LaserJet 4350TN Printer
Service Code 49 4c02
Try to upgrade the firmware on the printer, if that error still occurs after the firmware upgrade, you should try and use PCL driver rather than PS driver.
Apr 10, 2009 | HP LaserJet 4700 Printer
HP Laser Jet 2420dn - printer I have got ''4C02 - Service Error'' message. What does it mean? Thanks for help.
a single file, it could be that file. It could also be related to the individual software sending the print job, bad print commands or invalid. Although rare, a bad cable or connection can be to blame.
First step is to restart the printer, clear all jobs with the Stop button, restart printer again. Then try printing from another program, such as txt editor. If ok, then print a different file from original software, if ok, then print original file.
If failure is with final print, the file is corrupted for printing, recreate file.
If failure is with original software see if there is any updates.
If failure is there directly after restart, try updating printer driver (this is not be a bad idea anyways).
If none of this works, it may well be a formatter board issue, requiring technical service.
Mar 05, 2009 | HP Office Equipment & Supplies
1,976 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
