Question about Maytag Neptune MDE5500AY Electric Dryer
Admiral Dryer: 5 cycle 3 temperature electric
Admiral Dryer: 5 cycle 3 temperature electric unit purchased at local Home Depot "off the floor".
Unit won't dry properly. It takes 3 - 4 cycles to dry clothes. That is in combination with lessening the wash load.
Moved into new home, clean lint trap and line moving to outside of home.
What needs to happen?
Thanks.
  • steve
    steve May 11, 2010
    Is the problem on AUTO dry or TIMED dry or both? If on AUTO do a 45 minute TIMED dry and see what happens.
  • Anonymous Mar 21, 2014
    i have this dryer in brazil,i got it at home depot,second time using,but does not dry well
    New Friend:
  • 35 Answers
Unplug Dryer
Remove back (many screws)
Clean lint from interior & Vent Chute
check for breakage & parts on dryer floor
check for burn damage (wires burned off or char)
if no burn or char:
could be the "Dryer Coil" itself broke or
a "Snap Disc" usually mounted on the coil housing.
Very Serious!!!! Replace only!!!! Do not ever bypass!!!!
Stay clear of dryer for test start
Be ready to shut it down fast in case of problems
Always replace back & vent chute
Good luck,
Vinnie
Posted on Sep 13, 2010
  • vruggio Sep 13, 2010
    Also check your washer to make sure it is spinning out clothes properly.
    If they are heavy & dripping wet, it could be a washer problem.
    Good Luck,
    Vinnie
I have an ventless , or condensation, dryer. This is my second unit in 5 weeks. They both leaked over a cup of water on the floor during the cycle. Also they both stop within the cycle (about 4x) and...
I am not completely familiar with that unit, but if I had already 2 units supposedly fail with the exact same symptoms, I would in a different direction for resolve. Installation? There is not a likely probability that 2 machines are defective with the exact failure. Check instructions on install and make sure the exact instructions are being followed.
Dec 29, 2014 | LG DLEC855W 24" Compact Ventless Electric...
I have a bran new Admiral dyer that won't work
The dryer may have been wired incorrectly, e.g., 115v rather than 230v.
May 23, 2017 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Admiral heavy duty super capacity 5 cycle 3 temperature only heats some time
susara awz 7457 ne greje koji sum moguci kvarovi jel moye iko da mi pomogne..unapred hvala
Nov 28, 2011 | Whirlpool LER5636P Electric Dryer
I would like the operating manual for home tek steam cleaner
HI...........................
Couldn't see a manual on their web page, but you can try emailing them http://www.hometekinternational.co.uk/contact.htm
Home-tek Steam Mop Instructions
The Home-tek steam mop is designed for use on tile, vinyl and wood laminate flooring. This type of mop works a bit differently than your regular cleaning mop, as it uses steam to safely sanitize your hard flooring surfaces while removing stuck-on buildup.
Difficulty:Easy Instructions Things You'll Need
  • Water
  • Micro-fiber pad
    • 1 Open the cap of the water reservoir. This is located at the base of the unit, at the top of the reservoir, and twist it off.
    • 2 Pour tap water into the unit until you meet the fill line; water temperature makes no difference.
    • 3 Make sure a micro-fiber pad is attached to the bottom of the unit. This will be included with your purchase, and you may need to replace the pads over time if they wear or become heavily soiled. Replacements can be purchased from the manufacturer. If you need to attach the pad to the steam-cleaning unit, position the shape of the pad so it matches the base of the unit and snap into place on all four corners.
    • 4 Turn on the power switch with your foot. The switch is located at the bottom back side of the unit.
    • 5 Push the steam mop over the hard floor surface, pushing the steam trigger as needed at the top of the handle. Continue until your floor is cleaned to your liking.
GOOD LUCK!!!!!!!!!!!!!!
Sep 23, 2011 | Kitchen Appliances - Others
What kind of a plug in is needed for a dryer. My dryer has 4 prongs and my house outlet only has 3 prongs. I bought this house three weeks ago. I bought my washer and dryer when the gov;t. was giving...
Hi fran707al
If you already have a dryer receptical/plug then look at it closely and you can purchase a receptical/plug at a Home Depot type store or your local hardware store.
I will send you to a webpage that will show you how to wire a 3 wire or 4 wire dryer Circuit/Dryer
Free answer...Please take time to rate me
Hunter
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
May 26, 2011 | GE Dryers
I purchased an Admiral dryer from Home Depot..it did not come with a plug cord ! they said these are sold seperately now...are they serious ?
Yes.... there can be a couple of different plug configurations...you need to buy the one that fits you outlet and have it installed or checkout this tip....it will help with the installation even though it is not exactly about that...
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Apr 15, 2011 | Dryers
Kenmore dryer w/back vent, need to make it vent into floor/bottom
you will go to any hardware or home depot and purchase a metal ductwork elbow. that will direct the vent down 90 degrees
Jul 14, 2009 | Maytag PYE2300AY Electric Dryer
Hello my dryer is only 3 years old. Last night it stopped drying. The drum will turn and the light comes on. It is an electric dryer. What might be the problem. Thanks.
Have you tried a different cycle? The thermostat that controls heat has failed. There are more than one for the different heat settings. Try a different setting, then go from there.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 01, 2009 | Dryers
Refrigerator problem
I have a Magic Chef 3.6 cu. ft. Model#mcbr3605 thats 3 years old and has stopped working. When I plug it in you hear it start then you hear a "click" and it turns off. If you leave it plugged in the compressor gets hot. Can this be fixed or is it trash ? Thanks in advance.
Sep 01, 2008 | Magic Chef MCBR440 Compact Refrigerator
Maytag Neptune MDE5500AY Electric Dryer Logo
417 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
