Question about GE Tritonr XL GSD6260JCC Dishwasher
MY GE Triton GSD5120D00BB won't drain. Please help.
  • 6,784 Answers
HI, usually, if the dishwasher dose not drain properly, it will be the fault of a defective or, malfunctioning pump. i will list several problem areas to check. Inspect each area properly and, replace any component that is faulty or fouled.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Posted on Jun 17, 2009
GE Profile Triton Dishwasher wont drain completely
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Aug 14, 2011 | GE Dishwashers
I have a GE Triton XL Eterna Series dishwasher that is not draining. Can you help me diagnose the problem? Some people have told me that it is the pump, while others say it is the motor or drain hose.
Have you checked to see if there are food particles that might be obstructing the drain? Check the bottom center of the unit, there should be a filter, it might be clogged.
Feb 17, 2011 | GE Dishwashers
My GE Triton dishwasher won't drain, I need URGENT help !!!!! :(
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Water will not drain out
heatman101
Jan 21, 2011 | GE Dishwashers
GE Triton 24
Hi
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please post back for any further assistance.
Daniel
Jul 23, 2010 | GE Dishwashers
GE TRITON SEEMS TO STOP BEFORE CYCLE IS COMPLETE AND NOT DRAINING
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 04, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE Triton dishwasher will not drain and after cycle.
Look at the timer to see if the contacts have finally worn off. The circuit board may have failed too.
Nov 09, 2017 | GE 24 in. GSD4320Z Built-in Dishwasher
Ge Triton dishwasher will not drain and makes a funny noise.
Yes!! The crackling noise you hear is small pieces of food stuck spinning around the moter drain....All you have to do is find the drain hose (some are located under the sink of the kitchen) disconnect it from the draining source (not the back of the dishwasher) now run a long thin wire through the drain hose line poke around and pull in and out!! it may take a few tries but its better then a large Bill!! replace hose and hit drain button!!
Please rate response and help keep this site free!
Jan 06, 2009 | Samsung HL-S5087W DLP TV
GE TRITON LX Dishwasher
First check your Drain Cup filter it is just under the lower spray arm you may have something blocking the drain... if its clear check the drain pump... does it run a drain out? can you here it make noise? let me know if this helps ?
Aug 14, 2007 | GE ZBD5900D Dishwasher
GE Tritonr XL GSD6260JCC Dishwasher Logo
479 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
