Question about Hannspree HANNS G HW191DPB (Black) LCD Monitor
No picture on the monitor
When I unlock the PC, the monitor comes on momentarily, and then goes black.
If I power down the monitor, and turn it back on, the monitor works again momentarily and then goes black.
  • Buddy Mcsparrin May 11, 2010
    What type/brand and what model number is the monitor?
  • 523 Answers
Try to log into safemode, change the setting of your monitor or install the vga driver if its needed.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Posted on Jun 17, 2009
When I turn my monitor on, the screen shows the desktop momentarily and then goes black. If I turn it off and on a couple more times, the desktop will stay on and function normally. Where is the likely...
Try the monitor on another computer, to check-out the monitor.
Does the POWER lamp on the monitor stay on when the monitor goes black? If so, then the monitor probably is OK.
Try a different monitor, to trouble-shoot the video-card.
May 28, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Monitor goes black after a moment
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 17, 2010 | Sceptre X 7 Komodo II 17 in. Flat Panel...
I turn it on and it comes on for a second then the goes black
You need to open it up and inspect the capacitors (look for bulging top/seal), burnt inverter transformers, resistors, etc. in the power supply/Inverter board first, post back what you find so we can guide you further. See example of failed Viewsonic monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 16, 2010 | ViewSonic VX910 19" LCD Monitor
Pinstripe cinema display flickers on momentarily then goes black. Image comes back for a split second while when power light glows steadily then goes away while power light flickers. this is a 22"...
when the screen is black and the power light is steadly lit, shine a flash light at the screen. if you can see something, the inverter board is bad and the back light cannot turn on. if the power light flickers, reseat the power plug and put your ear to the back of the monitor where the power plug is. if you hear a buzzing or any high pitched noises; the power supply is bad. use the macufactures warranty for repairs.
Nov 18, 2009 | Computers & Internet
Monitor goes black
dry soldring problem in your monitor
Mar 31, 2009 | Acer AL1751WM (Silver) 17" LCD Monitor
When i boot up my desktop the monitor comes on then goes off, it come back on momentarily when windows starts up and then goes off again. i can turn the monitor power off then on again and it comes on for...
Your backlight might be dead. Try using a flashlight to see if you can see a screen
when it turns black. If you can, its a backlight problem. What model of screen do you have?
Oct 25, 2008 | Computers & Internet
Monitor will ower up but no picture. If I shut monitor off and turn back on picture comes up for about a second and then goes black again. I really donw't wnat to buy a new one as this one is only 2...
is there a light on at the power button on your monitor...if not then there is a problem with the power cord but if the light is on then it could either be your monitor sttings are set to dark or you connection cord is faulty
Sep 10, 2008 | Computers & Internet
HP 15 in. Flat panel Problem
plug in a different monitor temporarily, check your display settings (right click background, settings, advanced, monitor) and set refresh rate to 60hz. plug in this monitor again and see if that helps some monitors (lcd's especially) cannot handle beyond 60hz
Aug 14, 2007 | HP vs15 15"LCD Flat Panel Monitor
Picture shows up for about 3 seconds then the screen goes black
XEROX 19" (XG92D) 5 MONTHS OLD...IT GOES TO WHITE WHEN WINDOWS TELLS IT TO TRUN OFF AFTER 2 HRS...IT GETS HARDER TO COME ON EACH TIME IT IS TURNED OFF. I TOLD WINDOWS TO NEVER TURN IT OFF. IF THE POWER GOES OFF I MUST TURNED IT OFF AND ON MANY TIMES, THEN IT COMES ON. I THINK IT MAY NOT COME ON NEXT TIME...
Sep 26, 2006 | Xerox XG-91D 19" LCD Monitor
Hannspree HANNS G HW191DPB (Black) LCD Monitor Logo
855 people viewed this question
Top Hannspree Computers & Internet Experts
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
