Question about Toshiba 46H84 46" Rear Projection HDTV-Ready Television
2004 toshiba tv will not turn on
Power will turn light on, you can hear it cycle on, then yellow light comes on and it turns off.
SOURCE:
SOURCE: tv will not come on
Sounds like the bulb is blown.
Posted on Nov 02, 2007
dwn4lf
SOURCE: toshiba 46H84 tv turned off light blinking
Sounds like a problem w/ the red tube.
Posted on Jan 07, 2008
djnick989
  • 1067 Answers
SOURCE: my toshiba wont turn on but red light come on an green light flashing no picture or sounds
yes ill got remote link for u here give me one sec
Posted on Jan 29, 2008
ginko
  • 19396 Answers
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
  • 668 Answers
SOURCE: Blinking yellow light ,no picture or sound.
You have done all you can do. If you had a power outage, when the power came back on a it surged and probably caused a Power Supply problem or something in the micro controller to fail. Either way it 's not good. I would call Toshiba and let them guide you to a Service Facility that can check it out. Depending on your Homeowners Insurance, repairs could be coverd or unit be replaced depending on cost to repair.
Sorry I am not able to help further,
skyassoc
Posted on Jun 23, 2009
Toshiba 46 inch regza yellow light blinks and picture wont come on but I have full audio
Most likely the power supply board needs to be replaced. It could also be the T-con board or less likely the display itself.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Sep 21, 2016 | Toshiba Televison & Video
Toshiba 56hm66, lamp replaced but lights still blink
Check the circuit boards to see if any have failed. They are small cylindrical objects. If the tops of any of these are bulged instead of flat then they are bad and board will have to be replaced. Hope this helps.
Jan 03, 2014 | Televison & Video
What does it mean when the tv shuts off and the blue light flashes followed by the yellow
Ouch. Sounds weird. Do you mean the whole screen turns blue, then the whole screen turns yellow?
Try pulling the power cord from the wall a cycling the unit back on again.
Aug 15, 2010 | Toshiba 72MX195 72" HDTV
No display or audio
I had the same problem after replacing several things and still having same problem, it ended up being a capacitor.
Jul 03, 2010 | Toshiba TP55H60 55" Rear Projection...
Hi. I have a 2004 52' Flat screen projection TV. For the past couple months, we have turned on our TV and all we hear is sound, but no picture comes up. We thought the bulb was having problems. We ordered...
The buzzing is the ballast arc gap,normal sound. When the tv starts does the lamp start to come on. Can you see any light from the back? Sounds like bad ballast. Unfortunatly this part is no longer available. the light engine will have to be removed and sent to Toshiba to be rebuilt.
Nov 26, 2009 | Toshiba 52HM95 52" HDTV Projection...
Lamp light flashing on toshiba 50" projection tv
TV tries to come on - yellow light next to power light flashes but then it turn itslef off.........It tries agin after few sceonds and sequence repeats. I can hear the sound but no video
Dec 29, 2008 | Televison & Video
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Toshiba 2004
thats the protection ciruts causing the off and on,probably 1 of the modules.had simular problem with mine and it turned out to be the pcbaudio/video module a common problem with this mobel of TV costs about 168$ can for the module i hope this helps.From Moonbasealpha cheers mate....
Jun 14, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 46H84 46" Rear Projection HDTV-Ready Television Logo
43 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
