Question about Kenmore Washing Machines
My washer won't drain and continues on to the next cycle
It is a old kenmore 60 series about 15 - 20 yrs. old anyway it will go thru half the cycle when it's time to go to the thru rinse it won't drain, it'll start to spin without draining, finish that cylce and continue on to the next cycle.
  • 6,784 Answers
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
If all checks out ok during the above suggested inspection, replace the control board or timer module.
Posted on Jun 17, 2009
Kenmore 400 series washer won't finish cycle,I have to turn the dial to drain and spin to finish the load
Sounds like either a wire has come loose from the switch or the motor that spins the the ( may be integral part of switch ) has gone bad.
Mar 07, 2016 | Kenmore Washing Machines
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
Washer is not draining at end of cycle-puddle in washer at end of cycle -sears kenmore front loader 3 yrs old
Some of that is normal, if you turn the drum around you will here water. Mine do it also.
Feb 13, 2010 | Kenmore 44102 Front Load Washer
Kenmore washing machine will not drain
Replace the timer.
This is a neutral drain machine. If there is no natural pause in the timer at the end of the rinse cycle the timer is bad.
Mar 13, 2009 | Kenmore Washing Machines
Kenmore Washer Top Load Series 60 won't drain
The water pump is a belt-driven device actuated by a clutch. Your problem could be:
1. Stuck pulley - break it loose and WD-40 it
2. Broken belt - replace
3. Bad clutch - call repair or replace
There is almost nothing that can go wrong in the pump itself. It's probably one of these three.
Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Jan 23, 2008 | Washing Machines
Washing Machines Logo
69 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
