Question about Technics SL-PD887 5-Disc CD Changer
Technics SL MC60 reading error
Usually when I turn it on the changer moves around and makes this noise but it won't move to go to the CD's and keeps reading error. It sounds like it's trying but nothing happens. It was working, my bf pushed stop to change the CD and then this happened. Any idea on how to fix this and how it even got that way? .
    New Friend:
I had the same error problem, the rubber belt on the loading caridge is stretched.Replace it with a rubber o ring from True Value hardware for .59 cents. The size is
1 1/16 outside dia.
15/16 inside dia.
1/16 wall
Posted on Feb 07, 2013
  • Jerry Walters Oct 30, 2016
    Very helpful. I used a rubber O-ring approx 1inch o.d. taken from a footpeg decor off my Harley. The hardware store was closed because it was late on a weekend. Lol. It worked perfect.
    New Friend:
Thanks for the info on the cheap o-ring (Technics belt) replacement. For a 14 yr-old CD player, a $0.79 (10 cent tax..) fix worked for us. (Thanks to Ace Hardware)
We were able to listen to our Xmas CD\'s all day, thanks to the help from these posts.
Posted on Dec 25, 2013
  • 6,784 Answers
Hi, this will occur when the optical lens assembly becomes unstable or, damaged. this Assembly incorporates many gears and levers and motors as well. the lens assembly works together with the loading dock.
The laser rides on a rail that is used to allow proper scanning of the inserted media and, if this optical assembly becomes misaligned or unstable, it will not read or track properly as you are experiencing.
I recommend replacing the optical lens assembly asap if possible. it is damaged. We recommend contacting a service depot fro this type of repair.
Posted on Jun 18, 2009
  • rickraub Jul 17, 2011
    I just had the same problem with mine. I took it apart and found a small rubber belt/band had sliped off the motor and the mechinism that moves the player back and forth, thas the noise you usually hear .I hooked it back up, but it seems to be slipping. Im looking to find a replacement band. It may be stretched too lose. Thats all.
Power it on and just get an off reading
Technics SL-MC4 61-Disc CD Changer Not reading ... - Fixya
www.fixya.com > ... > Technics > Technics SL-MC4 61-Disc CD Changer
Technics SL-MC4 61-Disc CD Changer, not reading cd related issues. Get free ... IHave A Tascam CC-222Mkll Will Not Read CD-R Or CD-RW But Will Read Store Bought CD's. I Have A ... I have just spent $69 for the software to convert it the way I wanted into mp3 format, being a format that I figured . ... Power the unit off.
Technics SL-MC4 61-Disc CD Changer Message center ...
Dec 29, 2015 | Technics SL-MC4 61-Disc CD Changer
When i turn my technics cd player all i see is error
Technics CD Changer SL-MC400
The ERROR Is Cause By The Belt Drive
Remove The Cover And You Can See if
The Belt is Lose or slip of In Any Case
You Must Change That RUBBER DRIVE BELT.
Dec 31, 2013 | Technics SL-MC400 110-Disc CD Changer
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
Need Manual for Technics SL-PD827
Go to http;//audio.manualsonline.com
Jun 24, 2008 | Technics SL-PD8 5-Disc CD Changer
Technics SL-PD887 5-Disc CD Changer Logo
1,248 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
