Question about HP OfficeJet t65 All-In-One InkJet Printer
OfficeJet T65 - the belt that moves the print head (cartridge)broke and I am wondering if there is a replacement part on the market for these?
  • 72 Answers
Hp Printer Parts
www.MarketPoint.com/
Posted on Jun 17, 2009
HP officejet 6500 does not dispense ink
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Nov 12, 2012 | HP Office Equipment & Supplies
When i recive fax or when i print it just it prints empty page
If the fax is acting like it is printing (print head moving back and fourth) then it sounds like the ink cartridge is clogged. Remove the cartridge and clean with cotton swab and rubbing alcohol. If this helps a little or not at all replace the ink cartridge. If it still prints blank, the print head could be the problem (this is where the ink cartridge goes). At this point it would be cheaper to replace the fax.
May 14, 2010 | HP J3680 Officejet All In One Printer
My hp t65 will not print in color. I've changed
Make sure you removed the sticky piece of tape that covers the print nozzles on a new cartridge.
Sep 17, 2009 | HP OfficeJet t65 All-In-One InkJet Printer
HP officejet Pro L7580 print head is not working properly.
i order the 8 jan 2010 2 print heads No : 88 (ref hp c9381a for black/yellow and ref hp c9382a for magenta/cyan) and i receive it after 4 days.
Jun 09, 2009 | Epson CX8400 All-In-One InkJet Printer
White line going down printed page
Hello sir; you need to clean print head and cartridge seat, follow the steps; turn power on open top cover (as when you replace cartridge)let the cartridge carrier move to the center the UNPLUG the power the carrier will stay in the middle you can it freely, move it away from seat should find alot ink stick, remove it, clean out wipper blade and print head it should take care of your problem.
Jun 04, 2009 | HP Office Equipment & Supplies
New tri-color ink cartridge prints only red
Are the Jets clean and unobstructed? Depending on printer model, have you cleaned your print heads? Consider also it may be a defective cartridge.
Sep 09, 2017 | HP OfficeJet t65 All-In-One InkJet Printer
Printing is crooked on the page...otherwise prints beautifully
Sounds like the print head / ink cartridge is not seated all the way. Open the door and check it. It also may be the wrong print head / ink cartridge. If you replaced the print head / ink cartridge recently, you may have the wrong one for your device. If it is a off brand or refilled print head / ink cartridge it may be damaged or incorrectly identified.
Jun 11, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
HP officeJet T65
AHHHHHHHHHHHHHHHHHHHHHAHAHAHAHAHAHAHAH I FINALLY GOT IT!!!!!!!!!!!!!!!!!!!!!!!!!!!! MAN I WAS AT THIS SINCE 12:00AM LAST NIGHT AND i FINALLY GOT MY T65 TO WORK ON VISTA................................................
Use the driver for K60xi in the vista driver database... install your printer manually and choose that driver...........
phew, i almost sold my printer today and said I would try it one more time.......
Jan 13, 2008 | HP OfficeJet t65 All-In-One InkJet Printer
OfficeJet T65
Hello, i acquired a " HP Officejet T65" and i need solution to thank you start it
Nov 19, 2007 | HP OfficeJet t65 All-In-One InkJet Printer
HP OfficeJet t65 All-In-One InkJet Printer Logo
91 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
