Question about KitchenAid KGST307 Gas Kitchen Range
Oven display dead
I self cleaned my oven for 4 hours and when i came back the display was black...but the burners on top still work fine. I unplugged the power and plugged it back in...still no display. Was wondering if there was a reset or fuse somewhere I was missing. Please advise
  • 111 Answers
I need the complete model#
Posted on Jun 17, 2009
Lost Manual and would like instruction on how to set for self clean cycle?
Make sure you have everything out of the oven, including the oven racks.
1. Press SELF CLEAN.
2. Press the TEMP/TIME "+" or "-" arrow pads to enter the desired self-clean cycle.
3. Press START.
The oven door will automatically lock. The DOOR LOCKED and CLEAN indicator lights will be
displayed.
4. When the self-clean cycle is complete and the oven cools, the DOOR LOCKED and CLEAN
indicator lights will turn off.
5. When the oven is completely cooled, remove ash with a damp cloth.
Recommended times are 2 hours 30 minutes for light soil and 4 hours 30 minutes for heavy soil.
If your oven has a HI and LO self clean time, HI is 4 hours 30 minutes and LO is 3 hours 30 minutes.
It is also recommended that you remove anything plastic from the top of the stove during cleaning.
Nov 27, 2010 | Whirlpool RF263LXTQ Range
Gas oven won't light. Stovetop works fine.
I have the same problem with my whirlpool gas oven. The top burners work fine, but when we turn the oven on, the ON sign on the display stays on for about a few seconds and then goes away. The oven doesn't light up. Please help
Aug 23, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My problem is i did a self clean on the oven and it went through the 3 1/2 hour cleaning and as soon as it was done cleaning the control panel went completly dead. all 4 top burners work but no light in...
The self-cleaning cycle gets extremely hot! The surface of the oven inside becomes a catalyst with the heat. It sounds like a something on the range got hot like a circuit board. It is possible that a fuse or a fusible link may have burned up causing this issue. Did you check the plug for power? Maybe the GFCI tripped when the cycle was running. If you have power to the plug then you will need to start by removing the back panel and check for any fuses located on the circuit board. Check for any loose wires and use a multimeter to check for voltage going to the control panel. If you find any wires that look melted that might be a fusible link and will need to be replaced.
Sep 20, 2009 | KitchenAid Kitchen Ranges
Control panel black -No display
no reset fuse inside, by the power cord, also lcd display might be gone hope i helped
Jul 20, 2009 | KitchenAid KGST307 Gas Kitchen Range
Door locked: display panel not lit.
Unplug the appliance and the next day it will work again. Do not use the self clean cycle or I will have to spank you! Did you not know that 900 degrees for 3 hours can harm delicate expensive electronics. Get some easy off and clean that oven or get ready to spend some serious dough on fixing this puppy down the line.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 10, 2009 | KitchenAid KGRA806PSS Gas Kitchen Range
Display not working
The display needs to be replace. Check all the wiring also to make sure nothing over heated
Feb 14, 2009 | GE Profile 30" Self-Cleaning Freestanding...
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
To Self-Clean Using AUTO-CLEAN
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
desired self-clean cycle time.
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired self-clean cycle time.
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
Self cleaning
You can go to the Maytag web site and download the manual.  www.maytag.com, or go to http://shared.whirlpoolcorp.com/assets/pdfs/literature/8113p293.pdf
and download the manual CAUTION
• It is normal for parts of the ovens to become hot during a self-clean cycle.
• To prevent damage to oven doors, do not attempt to open the doors when LOCK is displayed.
• Avoid touching doors, windows or oven vent area during
a clean cycle.
Do not use commercial oven cleaners on the oven finish or around any part of the ovens.  They will damage the finish or parts.
Do not leave baking/pizza stone in the oven during self-clean.
The self-clean cycle uses above-normal cooking temperatures
to automatically clean the oven interior.
The oven should be cleaned regularly by wiping up spillovers
to prevent excessive smoke and flare-ups.  Do not allow a
heavy build-up of soil to accumulate in the oven.
During the cleaning process, the kitchen should be well
ventilated to get rid of normal odors associated with cleaning.
Before Self-Cleaning
1. Turn off the oven light before cleaning as the light may burn out during the clean cycle.
2. Remove broiler pan, all pans, and oven racks from the oven.  The oven racks will discolor and may not slide easily after a self-clean cycle if they are not removed.
3. Clean oven frame, door frame (area outside of gasket, and around the opening in the door gasket) with a nonabrasive
cleaner such as Bon Ami* or detergent and water.  The self-cleaning process does not clean these areas.  They should be cleaned to prevent soil from baking on during the clean
cycle.  (The gasket is the seal around the oven door and window.)
4. To prevent damage, do not clean or rub the gasket around the oven door.  The gasket is designed to seal in heat during the clean cycle.
5. Wipe up excess grease or spillovers from the oven bottom. This prevents excessive smoking, flare-ups or flaming during the clean cycle.
6. Wipe up sugary and acidic spillovers such as sweet potatoes, tomato, or milk-based sauces. Porcelain enamel is acid-resistant, not acid-proof.  The porcelain finish may discolor if acidic or sugary spills are not wiped up before a self-clean cycle.
Important:
• Oven temperature must be below 400° F to program a clean cycle.
Only one oven can be cleaned at a time.
• Both oven doors lock when either oven is being cleaned.
To set Self-Clean:
1. Close the oven door.
2. Press the Clean pad.
    • CLEAN flashes.
    • SET and UPPER or LOWER flash in the display.
3. Press the Autoset pad.
    • “MEd” (Medium Soil, 3 hours) is displayed.
4. Press the Autoset pad to scroll through the self-cleaning settings.
     “HVy” (Heavy Soil, 4 hours)
     “MEd” (Medium soil, 3 hours)
     “LITE” ( Light Soil, 2 hours)
Choosing the soil level of the oven automatically programs the self-cleaning time.
5. After four seconds, the oven will start cleaning.
    • If the door is not closed, beeps will sound and ‘door’ will display.         If the door is not closed within 30 seconds, the self-cleaning       operation will be canceled and the display will return to the time of day.
    • CLEAN will appear in the display.
    • LOCK will flash in the display.  Once the door locks, LOCK will
      remain steady.
    • The cleaning time will start counting down in the display.
Nov 27, 2007 | Maytag MER6772 Gemini Electric Kitchen...
My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! Mregressor@aol.com
Nov 13, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
KitchenAid KGST307 Gas Kitchen Range Logo
207 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
