Question about Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 shutting off every 10 to 15 minutes checked factory error codes lamp error only showed 1. No other errors listed. Any other ideas or would this still be the lamp? Thanks
  • tlsage Jun 17, 2009
    Shuts off and power stand by light flashes green starts up again by itself and we replaced the lamp about 6 months ago with sony replacement lamp so do we need another replacement lamp? Thanks
  • 10,594 Answers
Does TV start up itself after shut off?
If that is the symptom, it lamp that is weak and requires replacement.
Posted on Jun 17, 2009
  • Shahid Electronics
    Shahid Electronics Jun 17, 2009
    Symptom shows lamp is weak in result.
    I would recommend to buy Sony original lamp and avoid aftermarket / cheap lamp.
Hi, Our Sony Bravia TV model number KDF E50A11E is not working. There is a red blinking light flashes three times and then goes green and then red blinking again after about 3 seconds. Is this a bulb...
On that particular model I believe there is both a lamp indicator light and then the power indicator light. If it is lamp related the lamp indicator light (LED that looks like a sun in a cup...) would be on.
If the power indicator light is flashing red to green, that is a self diagnostic code, and you will have to contact an authorized Sony repair fascility for them to translate the problem. The error codes are not listed in the user manual, since most are not user serviceable.
Mar 01, 2011 | Sony (XL-2400) Projector Lamp for...
KDF-E50A10 TURNS ON THEN FLASHES GREEN FOR ABOUT A MINUTE THEN KEEPS FLASHING RED .WHATS WRONG?
# of red flashes = error code.
3x = lamp door or lamp not fully inserted
4x = fan error
5x = lamp driver error
6x = power supply or thermal fuse blown
Jun 12, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
(XL-2400) Projector Lamp for KDF-E42A10, KDF-E50A10: I have a KDF-E50A10. 4 years old. Lamp went out af...
This is by far the best xl2400 site ive come across so far. Has all the details as well as replacement guide and a direct link to amazon.com for purchasing...definitely check it out if you have any questions or concerns.
May 18, 2010 | Sony (XL-2400) Projector Lamp for...
Red Light Flashes twice KDF-E50A10
Are you putting the lamp cover back in place before trying to turn the set on? The 2 blink error is a temperature error you might want to check the thermal sensor, is your lamp door warped?
Oct 30, 2009 | Sony KDF-50E2000 50" HDTV
Sony KDF-E50A10 stays on for 15-20 minutes then shuts off power standby light flashes green and turns back on. Replaced bulb about 6 months ago with sony bulb. Any ideas. Thanks
The reason this happens the most is because of the lamp being weak. I have not seen anything else cause this problem. You can varify this by turning the set off and wait until it shuts down totally.
with the Sony remote, press the display button, the #5 button,
volume down button, then power button. This puts you into the the factory error code mode. If you see the lamp code with multiple errors and no other errors shown, the lamp is the problem.
Most of Sonys lamps have a aprox life of 3000 hrs. Some last longer and some shorter.
I hope this helps,
Skyassoc
Jun 17, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 50 in. HDTV stays on for 25 - 30 minutes then shuts off by itself power stand by light flashes green and turns back on in about 20 seconds by itself. can you help?
Hi, Lamp of TV getting weaker and requires replacement. This shut off by itself will increase day by day until you put new lamp in TV. Always Buy Sony original lamp and avoid aftermarket/ cheap lamp for TV safety.
Jun 09, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 HDTV LCD TV now with the same problem as these guys. Anyone with any ideas?
Thanks for update,
Lamp replacement is not difficult in KDF-E50A10 and its written in user manual. You can download user manual copy by clicking Sony Support.
Your TV needs XL-2400 Lamp and it is available in Sony Accessories Store. (click and see)
I would recommend to buy Sony original lamp for this TV and avoid after market or compatible lamp.
Good luck.
Mar 30, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Feb 13, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Ihave a sony KDF-E50A10 and the picture is fading
check the lamp timer in the menu page of the projector.it it is more than 1500 hours, it can be the lamp
alternativly u may also check the optical engine as it may be covered with dusty , hence resulting in dull images
Feb 06, 2009 | Sony (XL-2400) Projector Lamp for...
Sony KDF-E50A10 50 in. LCD HDTV Logo
369 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
