Question about Dryers
I have an Amana gas dryer LG4409W ... when I normally set the timer I rotate it then push in to activate ... for some reason I pushed the dial in while I was rotating it ... ever since then the dryer does not work correctly ... when I set it to the first cycle at the top of the dial, the motor turns but there is no heat and the dial does not advance ... if I set the dial to the next cycle (timed dry) the dial does advance but the heat is low ... I replaced the dial/timer switch and when I first turned it on for a test there was plenty of heat ... I just put a load in to dry and the same symptoms are back ... no heat and the dial doesn't advance ... any advice ?? Ron Truhlar, ronbo777@gmail.com, 319.248.9869
  • ronbo777 Jun 17, 2009
    Are you certain you are talking about the same dryer ?? the P/N on the timer part is 502967 (model 275BEF) and it cost ~ $125.00 ... I previously stated that I replaced the timer and when I first turned it on there was lots of heat ... it's 2 days later and now no heat on the first cycle and the first cycle doesn't advance ... the "Timed cycle" does generate some heat and does advance the timer ... please advise ...
    Genius:
  • 1,341 Answers
Is there any electronic unit like a pcb in this dryer as this may cause it if it has one..
Posted on Jun 18, 2009
    Brigadier General:
  • 3,917 Answers
I am sure you have already done the following.
Sounds like a timer has went bad. Especially if it wont move in any cycle. The timers are pretty easy to replace, and on this model, not that expensive. The timer number is : 8299778 and runs around $60.00. To remove the timer, just take the back panel (of the console) off, then slip the knob off by pulling gently, then remove the hold down screws and pull off. I believe this particuliar timer has one wire bundle, but if not, be sure to make your wires to know where they go back. Good luck, and let me know if you need any further information.
Now to test the following for no heat issue:
1 check your power to make sure you have 240 volts . 2 verry possible your heating element is burned out.3 you may have a safety thurmo burned out.depending on the brand and model your start switch could be bad on the moter. also depending on the brand and model` the timer could be bad or a burnt wire.
Thanks for contacting Fixya.
Posted on Jun 17, 2009
What could possibly the reason my amana dryer wont tumble and just buzzes when you push the start button
Could be a broken belt spin the tumbler by hand it if it spins real easy the belt is off or broke another thing to try if you have resistance when turning the drum have a helper for this one open the door and hold the door switch in set timer to a cycle and press start while holding switch and buzzing spin drum and see if it will continue to rotate while holding switch if so motor going bad
Feb 17, 2015 | Amana Dryers
Why would my Amana washer not do anything but fill up with water. Nothing will function at all on all the cycles but the fill. It doesn't even click on the timer when you try to set to any setting exc
Hi Kirby
First... Caution
Because your dealing with water & electricity it can be lethal to fiddle around inside. That said...
Washing machines are controlled by a master timer unit, usually mechanical, but rotated by an AC Clock motor. If the timer is not getting voltages to the various Switches around the "timer unit" or "clock motor" then the individual selected functions won't work.
Manually Rotating to a particular function then Activating the On/Off Push/Pull switch should start things happening even if timer motor is dead. So
If your OK with AC electrical goods then open it up.
Connection wires may have fallen off or something simple. A multimeter is your best friend here. Look for the big rotary clock behind the main control dial. Listen for the clock motor running. The main Push in & out Button is the On / Off switch. Check that its got AC on the input wire & switches across to the other wire when the knob is pushed in / out. This may be the problem...
You can always call an appliance repair technician!
Good Luck
Nov 19, 2014 | Amana 3.2 cu. ft. Top-Load Washer
I have an amana dryer model ned4500vq0 it goes through the cycle but does not stop.
Sounds like the push-to-start switch, part # 3977456 is stuck "on." Check continuity with a meter. Does the timer dial continue to rotate after completing its cycle?
Jun 04, 2014 | Dryers
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 11, 2013 | Amana Dryers
My amana DLG330RAW dryer won't stay on. it has a combo timer and start dial turn the dial to the timed settinG and push...dryer starts part way through the cycle, the dryer...
Hello PB,
What i would most suspect as being the problem of why the dryer just stops randomly before the cycle is done,is a problem with the door switch or the door catch...does the dryer restart as soon as you restart it?? if yes i would check that the door catch was broken so the door will pop open stopping the dryer. Also check the door switch using a meter set to measure ohms and see if the contact is burnt ( a good door switch will be zero ohms resistiance)
GENE
Sep 17, 2011 | Amana DLG330RAW Gas Dryer
Hello, I have Amana LG4309W heavy duty gas dryer.
sounds like one of the supply fuses at the house panel,these 240 volt dryers are wired so the timer is on one phase(120)volt and the motor is on the opposite phase(120)volt and the heating element is on both phases for a combined 240 volts,if you lose one phase you either wont get motor operation or timer operation,and for sure no heat and you have the timer so you have 120volts
Jan 08, 2011 | Amana Dryers
I cannot figure out how to set my outdoor timer to control my Christmas lights. How do I set the pins?
There are 4 basic pins/tabs/segments for timers
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
Pins move back and forth
Segments lift up
Segments pull out
Segments push down
Each type of pins/segments are located on dial.
Dial rotates as time passes.
The pins/segments contact on-off lever and cause lever to move.
Lever movement opens and closes electrical contacts.
The little plastic parts and motors wear out.
Make sure pins/segments are pushed all the way into place.
Check override switch is clicked to TIMER
Rotate dial until current time lines up with arrowhead marker
To check operation of timer, manually rotate dial to watch lights turn on-off.
Troubleshoot:
Lights must be on.
Bulbs are good.
Receptacle has power.
Check timer in different receptacle.
If dial does not rotate or pins/segments don't turn lights on-off, timer might be bad.
Dec 12, 2010 | Garden
Buzzer always on, drum won't start spinning
yes you lneed a motor 150.00 to 200.00
May 28, 2009 | Dryers
Amana dryer timer dial wiil not rotate/temperature stays hot
The elctrical contacts in the timer have welded themselves together or the notch wheel is broke in the timer; either way you need a new timer, and this also explains why it runs until you open the door.
Apr 10, 2009 | Amana NDG7800AW Gas Dryer
Amana dryer wont work
I'LL let you know after the Amana repair man comes out.
Mine is doing the same thing and I can't figure it out
Jan 14, 2009 | Amana NDG2335AW Gas Dryer
Dryers Logo
63 people viewed this question
Top Dryers Experts
Marvin
Marvin
