Question about Gestetner Office Equipment & Supplies
Error Message SC541. What is the command to remove this message so that copier can function.
Depending on the model, you may just have to enter service mode, and power off/on.
For older models you will have to enter service mode, and then run SP5-810, then power off/on.
That is assuming that the fuser problem has been repaired prior to running the codes.
Posted on Jun 18, 2009
Our copier reads an error message of SC541
this problem can be solved by pressing the yellow button,then enter 107 and hold down the red button till the screen changes to copy SP,press OK or 1.The macine will now be in service mode.switch the machine off then on again.if it go into SC541 again the problem lies with the thermistor of the fuser unit
Mar 07, 2011 | Savin Office Equipment & Supplies
Error message sc541
hello,
SC541 = The melting temperature measured by
thermistor is less than 71 C and
is corrected after operation.
the problem lies in the fusion group.
- Thermistor fusion defective or incorrectly installed
- Lamp merger fails.
Hello Valerio
Jul 14, 2010 | Ricoh Aficio 2022 Black and White Copier
Hi I have an Ricoh aficio CL7300 printer and it is displayin error message SC541 what does this mean and how do i Fix it
sc 541=Heating roller thermistor error (Fusing unit).
The thermistors could be dirty or damaged.
The fusing unit can be removed and inspected(without removing any screws)(Left door)(lower handle).
If you see any damage you might have to replace the unit(or only the part if u r lucky).
Feb 10, 2010 | Ricoh Aficio CL7300 DT2 Laser Printer
Cant download update driver for X3580 error message 1001
Try removing the command to startup the lexmark printer monitor from the startup file. Just run "msconfig" and uncheck the command. Then reboot and try the update again.
Jun 20, 2009 | Lexmark Office Equipment & Supplies
Pitney bowes 9820 error message
press function, print incomplete command report, then go to function 4 and use command numbers on report to delete.
Jun 01, 2009 | Pitney Bowes 9920 Plain Paper Fax
Getting error message when trying to print
"Fuser Error", needs to be reset in service mode, after the fault is fixed. could be heater lamp, fuse, thermostat, etc.
Mar 30, 2009 | Ricoh Aficio AP2600N Laser Printer
Error message
SC541: Fusing Thermistor Open
Fusing thermistor defective or out of position
Poor thermistor terminal connection
Poor connection in socle of fusing.
Sep 10, 2008 | Ricoh Aficio 450e Laser Printer
About ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Apr 22, 2008 | Ricoh Aficio 450 Copier
316 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
