Question about Samsung Compact MiniDV Digital Camcorder
LCD not working
Hi, my lcd screen is not working, it seem to have a short or maybe the lcd door has been strained. Can it be fixed and is it worth it..
    Problem Solver:
  • 5 Answers
My samsung mini dvd had problem with recording, the screen would go black (though menu displays come up fine).
could do play back but not record.
i put it in the sun for awhile or in a warm spot and it will record and show display.
it is not a complete fix but worth trying (on top of the heater works good too). of course the fix doesn't seem to work when i REALLY need to record something.
also had stripes coming across screen recently on playback, gave it a good tap and the stripes went.
Posted on Jun 23, 2009
I have a proyron 32
Shadow on screen that seems to be unchanged or permanent is typically called "bruising". Usually caused by hitting the lcd screen too hard with a object..or press to hard with your fingers. The only fix for it is replacing the LCD screen. If the screen just seems "dimmer" then this could be caused by a bad inverter board or blacklight. It's the LCD it's usually not cost effective to replace.. and new monitor should be purchased.. if it's the inverter board or backlight it may be worth fixing.
Nov 16, 2011 | Televison & Video
I don't get a picture only sound is that a major repair and worth getting fixed?
No picture with sound is commonly problem of LCD TV. The cause of that problem is the back light is not working,because the back light inverter board is deffective,maybe there's a blown surface mounted fuses cause of shorted transistor, transformer or bad capacitor.That the coomon problem of no display LCD television.Hope it will help you.Thanks..
Sep 03, 2011 | Olevia LT27HVX 27 in. LCD Television
My eyes get strained with only minutes after looking at the lcd
Do you ever use any other displays (like a shared terminal at school or a library, or at work?), and if so do you have the same issue there? If you use both the LCD and the 13", try JUST using the LCD for a short time and see if your eyes can adjust.
Feb 12, 2011 | Hyundai Electronics Hyundai U90P 19" LCD...
My screen is totally black and will not turn on the computer but the green light is on???
Most likely a screen problem. Are you able to try another monitor with your PC? If a different monitor works, then the problem is your monitor. Most LCD monitors have a rather short life span (well, much shorter than the heavy old CRT monitors). But whichever kind of monitor you have, it seems to be getting power but is unable to display an image.
If your monitor is an LCD monitor, then the problem could be the backlight. If you take it to a computer repair shop, they should be able to replace the backlight - if it's cost effective to do so. Without knowing more about your monitor it's difficult to judge what the best solution might be. Sometimes it's cheaper and easier to get a second hand screen from Ebay rather than fix an obsolete LCD screen. On the other hand, if you bought the monitor within the last 12 months and spent a lot of money on it, it may well be worth getting it fixed.
Oct 10, 2010 | Computers & Internet
MY PROBLEM IS THAT THE SCREEN IS CRACK AND NEED TO BE REPLACE
LCD Screen replacement would cost you approx 70~80% of new tv price. New tv is better option.
Aug 17, 2010 | LG 42LC2D 42 in. LCD HDTV
My son just hit his rattle into the screen of my flat panel tv. when turned off it looks fine but when its on you can barely see the picture in the top right hand corner but the spot that he hit it it...
Ur tv have a broken LCD screen panel.Not worth fixing,because the LCD screen panels are limited produced,will cost the same as a new tv,if replaced.Only can buy the LCD screen panels from the tv corporations.Sorry,worth as a whole tv any more.Now ur tv,only worth as salvage for eclectronic boards.
Aug 15, 2010 | Televison & Video
How much will it take to fix a cracked membrane with vertical lines on it
Not worth fixing,if the LCD screen panel is damage or broken.Because LCD screen it limited produce it will cost the same as a new tv.Might even cost more after the LCD screen panel part and labors.The LCD screen panel is 90% of the tv,broken or damage LCD screen panel not worth as a whole tv anymore.The tv now only worth as salvage electronics boards parts.
Apr 20, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
BLACK SCREEN ON MODEL DCR-HC40
Had the same problem. It's ainternal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew. It's very common in sony. it's worth repair Good luck
Meggita
Jul 11, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Nikon Coolpix L14
It can be fixed . But it will cost around 100-200 dollars .
If you are comfortable with your camera then you go with replacement of the screen .
If you feel your not satisfied with the features then go with new camera
Thanks for using Fixya
SAM ANDERSON
Sep 08, 2008 | Nikon Coolpix L14 Digital Camera
Battery gets hot and won't hold a charge; plus shattered LCD screen
the glass and LCD can be fix and replaced but the main-board heating up is saying that the board needs to be replaced but you should just purchase new one.
Jun 26, 2008 | Motorola Mobility RAZR V3
Samsung Compact MiniDV Digital Camcorder Logo
257 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
