Question about Sony Playstation 3 (PS3) Console
How do you turn on the HDMI cable, i have a 40 GB ps3 but i lost my owners manual and i try to change the video settings but it says the device is not turned on or hooked up...well i made sure it was hooked up but i dont know how to turn it on
    President:
  • 2,653 Answers
It's automatic. You can't turn on the hdmi cable.
Have you tried to manually set it up under Settings --- Video / Display ?
Make sure you've got the av cables plugged in too so that you can switch over to the hdmi manually from that menu.
Posted on Jun 17, 2009
I am unable to get a picture on hdmi when i connect my ps3, but am able to get sound when i use ps3 controller. any ideas ?
Steps
  1. Step 1 Check for an HDMI port Check the back of your television for an HDMI port and refer to your owner's manual for your television's resolution. A resolution of 1080p offers the highest quality.
  2. Most PS3 systems support 1.3 HDMI, but older systems may need a software update from the 1.1 or 1.2 version.
  3. Step 2 Disconnect cables Disconnect all the cables and adapters from the back of your PS3, and then unplug your TV to reduce the risk of shock as you work.
  4. Step 3 Connect HDMI cable Connect the HDMI cable. Reconnect the power cables on both the TV and the PS3 system.
  5. Step 4 Hold power button Hold down the power button until the PS3 beeps and continue holding it for an additional five seconds until the system makes a second beep.
  6. The Playstation 3 should detect the high definition cable and automatically adjust the settings to give you the best picture and sound possible.
  7. Step 5 Test the connection Test the connection. If the HDMI cable isn't working, turn everything off and reconnect the original cables to manually change the settings.
  8. Step 6 Adjust the settings Turn the system back on, select Settings, Display Settings, Video Output Settings, and then HDMI. Repeat the process for your Audio Settings. You can now experience your games with the highest video and audio quality available.
Dec 01, 2014 | Sony KDF-E50A12U 50" LCD HDTV
How to connect sony ps3 to toshiba 32av500a
Use any HDMI cable to to this.
Connect cable to the "HDMI" port on the back of the PS3. Connect the other side of the HDMI cable to the "HDMI" port on the Toshiba TV. If the Toshiba TV has multiple HDMI ports, make note of which port you plugged the HDMI cable into.
Change the Toshiba TV to its "HDMI" video display mode. Press the "Power" button on the PS3 to turn the console on. The PS3 will automatically detect the HDMI cable. Select "Yes" to use the audio and video from the HDMI cable. Select "Yes" to have the PS3 automatically use the optimal settings for the Toshiba TV. Select "Yes" to accept the recommended resolution. Press the "X" button to save the settings
Dec 22, 2012 | Toshiba Televison & Video
I changed the PS3 setting to view on TV from HDMI to Ycp? (red blue green cables) now I can't see the PS3 menues, how do I change it back? can you help please My PS3 has no Red blue and green out
try taking out the red blue green cables completly out so no cables should be conected exept for the power cable then plug in the hdmi cable from the ps3 to the tv after you do that turn on the tv to hdmi input then turn on the ps3 and let it sit for a while and look at the tv while the ps3 is turned on shortly after you turned the ps3 on a message should pop up on the tv select yes then set the settings and that should work let me know if it dosent
Dec 08, 2012 | Sony PlayStation 3 (320 GB) Console
Turn on ps3 i get no picture or sound then i cant turn it off i have to unplug it whats wrong with it?
  • Check your HDMI Cable
    HDMI is available in several versions. The PS3 is compatible with HDMI version 1.3 or higher, which will take full advantage of Blu-ray Disc™ high-definition video. There are also "Type A" and "Type B" connectors. The PS3 uses the 19-pin Type A connector, which will allow resolutions up to 1080p.
    The HDMI cable is not included with the PS3.
  • Cable adaptors (i.e., HDMI to DVI converters)
    If you are using an adaptor (i.e., HDMI to DVI converter), try bypassing this adaptor and connecting the HDMI cable directly into the display.
  • Check the adaptorTry an alternate cable
  • Try connecting with the supplied AV Cable instead of the HDMI to see if you can get a successful installation. This will help determine where the problem may be with your particular HDMI setup and/or equipment.
  • Some older HDTVs may have issues with the copy protection protocols (HDCP) causing the handshake not being communicated between the TV and the PS3. Try resetting the TV by turning the TV and PS3 off, then unplug the TV power cord from the outlet and plug it back in. Then turn your TV and PS3 back on and see if the picture appears.
  • Try using a different the HDMI Cable on the PS3.Make sure the HDMI Cable is free of any cuts, frays or other visible damage.
  • Try installing the PS3 to another TV or display (i.e., monitor).
  • Try using the HDMI Cable with a different PS3 system.
If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
Aug 18, 2011 | Sony Playstation 3 (PS3) Console
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
No signal through hdmi ports
Check the hdmi cables be sure their in proper working condition, wiggle the cables around see if picture comes up. If not and the cables are good then the hdmi processor on the main board of your TV is defective. Alot of times hdmi ports tend to burn so see if you smell a burnt smell near or around the hdmi ports. but before you do anything be sure sure your TV settings are correct for hdmi....
Oct 18, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No picture
make sure you have the correct channel, also if you are using HDMI cable make sure that you use the RCA cable first then switch it to HDMI and then change your TV to the HDMI channel
Jun 04, 2010 | Sony PlayStation® 3 (60 GB) Console
My Toshiba 57H84 has stopped picking up my PS3 through HDMI
try holding your finger on the power button(next to disc eject) for 5 secs
May 24, 2009 | Sony PlayStation® 3 (60 GB) Console
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
152 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
