Question about Handspring Visor Deluxe Handheld
The screen I have a visor deluxe, the screen seem to shrink on the left handside, and it eats up the words when I open up the address list, can you tell me what I have to do
  • 19,396 Answers
Re: the screen
I guess that after so long the original problem had been fixed.
Here the tip, in the hope this will help anybody in trouble with this PDA.
Try resetting, follow procedure below, that will set calibration to factory default. Click here. The procedure shows how to reset the PDA to factory settings.
Posted on Sep 28, 2010
0 characters
3 Points
Is the Handspring Visor Delux compatible with Windows Vista?
yes it is compatible with the palm desktop that comes on the disc or the palm desktop 4.14
Apr 09, 2010 | Handspring Visor Deluxe Handheld
PDA address book download to new computer
You need to install the Palm Desktop and Hotsync manager onto drive c: This link has the software for the Visor.
If Vista is 64-bit, you will need to use the software for 64-bit also found on this site.
Aug 17, 2009 | PDAs
I bought a visor delux on line new, and the mfg cd rom was not included. can you help me find one ?
I believe the CD only gives you the two programs that you need for your PC or Mac. Desktop Manager and Hotsync manager, both of which should be available for download from the Palm website. Find the Visor Deluxe among the devices on the site and you will find the files there.
Everything else is permanently on your Visor but you need those two programs on your computer to hotsync and so transfer files between the visor and your computer. If you haven't got a cradle or cable you can still buy them third party.
Jun 09, 2009 | Handspring Visor Deluxe Handheld
Visor Deluxe OS3.0.1 Fatal Error
Your application is for an upgraded version of the Palm OS. Say you had a Palm OS version 2 or something. If you download an application for Palm OS 5, obviously it won't work because the application is for a later version. Make sense? To remedy this, you will have to delete the application and get one with a version that matches or is lower than your Palm's.
Mar 16, 2009 | Handspring Visor Deluxe Handheld
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Dec 13, 2007 | Handspring Visor Deluxe Handheld
Migrating software and data to new computer
Assume that your Visor is your data respository. So you should make sure that you have an up-to-date synchronization from the NT PC. Now get the XP compatible software for your Visor from the palmOne website and install it on the XP box. I assume that you will be synching via USB this time - this is the default setup when you install the software. Hopefully you still have the USB cradle that came with the Visor. You can still use serial sync with XP but you should try to take advantage of the speed of USB on the new PC. Download for XP & Visors: Once the software is installed, sync with the new computer and all your data should be copied from the Visor to your PC in the first synchronization. By the way, Outlook shouild be installed on the new computer before you install the Visor software; otherwise the installer will not offfer to install the PocketMirror conduits.
Sep 13, 2005 | Handspring Visor Deluxe Handheld
Where do I download a program to hot sync my visor to my desktop?
Palm Desktop for Visors - same as CD software
Sep 12, 2005 | Handspring Visor Deluxe Handheld
How do I delete info to free up memory space?
Clear out a little space and install a program called FileZ- it is freeware and widely available. Once installed, it will give you a list of every file on the Visor, and allow you to select single files or blocks of files to remove. Look to or the toughr to use for FileZ and other programs.
How get Drivers PALMUSB.SYS for USB cradle
Problem is fixed: Not sure how I fixed but I think it was when I shutdown PC and restarted. Then I tried to SYNC again AND then I found WINDOWS saying it found new hardware (the cradle). This time I knew to say I'd tell where the drivers were and I chose the Drivers directory of Handspring directory and the installation proceeded OK this time. (drivers are PALMUSBD.inf and PALMUSBD.sys) I can then SYNC with Outlook 2003
Sep 11, 2005 | Handspring Visor Deluxe Handheld
Handspring Visor Deluxe Handheld Logo
93 people viewed this question
Top Handspring PDAs Experts
ray gallant
Are you a Handspring PDA Expert? Answer questions, earn points and help others
