Question about SanDisk Audio Players & Recorders
My sansa express radio stopped working. The other music still plays.
    Sergeant:
  • 338 Answers
Which sansa model do you use?
one having radio + mp3 play feature?
so mp3 playin' works but the radio-receiver seems to be broken? please give some more details and come back.
Posted on Jun 18, 2009
Sound works for radio not for music volume is up music is playing no sound from any headphones
Did you try plugging in a different set of headphones? If other headphones work, maybe you need new headphones.
Try playing music from your Sansa through the computer, while it is tethered. If you can do this, it may mean that the audio amplifier part of the Sansa is broken-- Usually this means, 'get another Sansa.'
Also, try gently wiggling the headphone plug to the left and right, while it is plugged in. If you get music on and off, its possible that the headphone connector on your Sansa has a broken connection. This is a VERY difficult problem to fix (without breaking or melting something else inside the case) and also usually means it is time to get another MP3 player.
Nov 07, 2011 | SanDisk Sansa Clip MP3 Player
My Sansa Express MP3 player does not show up on my computer as "Sansa Express" but is shown as Removable Disk (K:). Is this right
Normally your Sansa Express would show up as "Sansa Express", which would indicate that it is in MTP mode. The Sansa Express doesn't supply a menu option to switch to MSC mode, which would cause it to show up as a "removable disk". Apparently your Sansa Express has somehow switched to MSC mode. MSC mode is necessary for upgrading firmware, in which case it's called "recovery mode", and it's possible that some combination of key presses (usually involving holding down the power/hold button) put it into this mode.
If you double-click on "removable disk (K:)", do you see a Music folder? If so, is there anything in the Music folder?
Feb 11, 2010 | SanDisk Sansa MP3 Player
My Sansa Express appears to be stuck on pause. I just got it last week and have only used it once. It will play the radio, but I can't get it to unpause in the Music mode. It will fastforward and rewind...
It's possible that there is some physical damage to your player, but first try to do a reset: Press and hold the Volume Up (+) and Select buttons simultaneously for approximately 20 seconds.
Jan 08, 2010 | SanDisk Sansa MP3 Player
Sansa express stuck up in on function . It is displaying : "Music, play all, and play privious and Artists". Neither display changes , function changes nor stops. Continue display. no change.
First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
Apr 02, 2009 | SanDisk Sansa MP3 Player
Sansa clip 2mg fm radio not putting out sound
Go into the Settings menu of the Sansa, and change the region to "World" if you live outside the US, and change to "United States" if you live inside the US. Then, go back to the Radio mode and see if there is an icon that looks like a block (technically, a "Stop" sign) - if there is, press up on the clickwheel - it will get your radio off of pause mode. You radio should now work again.
Mar 30, 2009 | SanDisk Sansa Clip MP3 Player
My sansa express mp3 extremley slow
You may need to get a firmware update from this web site: http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Remember that you need to back up all of your information before doing the update.
Sep 16, 2008 | SanDisk Sansa MP3 Player
My Sansa Express Music Player shows mulfactioned error
Insert A Micro SD Card And Start It Up
It Should Work
Shut It Down And Remove The Micro SD Card
It Should Startup Fine.
Sep 09, 2008 | SanDisk Sansa c150 MP3 Player
Music will not play
H i i cant play the song ...Can upload the song or all items ,but cant paly it or see it tooo. wat 2 do..
Jul 09, 2008 | SanDisk Sansa m260 MP3 Player
SANSA EXPRESS
Not sure but it could be dead, but dont worry till you do a hard reset by pressing and holding down the "select(Square button)"and "volume up" buttons.
I just got mine today and been looking through the sandisk forum.
Hope that helps bye :)
Jun 15, 2008 | SanDisk Sansa MP3 Player
My Sansa m240 does not play music, it freezes.
Try going into your USB Settings on your device and ensure the unit is set to msc
Jan 09, 2008 | SanDisk Sansa m240 MP3 Player
148 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
