Question about HP L1702 17" LCD Monitor
After it has been on for about an hour screen banks
After it has been on for about an hour the screen suddenly gets very bright then goes off. Switching the power off and back on fixes it for a while. The ventilation slots are clear and tapping the boards inside has no effect.
    Problem Solver:
  • 5 Answers
Make sure that the power settings are set to never turn monitor off. On Win Xp, you go to control panel, power options, then check your settings to see if it is set to turn off after an hour or so, if it is then click on the down arrow and choose "NEVER".
Posted on Jul 02, 2009
Screen has all of a sudden turned Bright Red! The booklet is useless! I can get the colors almost to a sepia then once shut off & turned back on it goes back to bright red
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 03, 2015 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Princeton 19" went from bright white to dull white
david78910, First disconnect and reconnect the monitors VGA plug from pc vga port a few times to make sure of good connection at the port. Report back here with results! If that doesn't fix your "pink screen" symptom, then possible bad inverter supply inside unit or the CCFL tubes may have lots and lots of "on" hours use on them and need to be replaced. Yes, you could also have bad (almost dead) switch-mode-power-supply inside unit if "known-good" monitor works perfectly with your pc. 12fixlouie
May 20, 2010 | Princeton Digital VL1916 19" LCD Monitor
MY DELL 1525 TURNS ON AND THE NORMAL BLUE SCREEN APPEARS. THEN ALL OF THE SUDDEN IT GOES BRIGHT GREEN, THEN BRIGHT YELLOW, AND STAYS BRIGHT YELLOW
Please connect your laptop to an external monitor and see if the output is the same. If it displays fine on the monitor, then we are looking at either a screen cable problem or a screen problem. If the display is the same as on the laptop, then it is a problem with the display adapter on the mother board.
All the best.
Jan 14, 2010 | Dell Inspiron 1525 Notebook
Screen Brightness gone too low on toshiba satellite 1110 laptop
Hello Tim,
Sorry to answer u by this news :
this problem u have happening by 2 cases ..
1st Case :::: that's maybe ur screen lamps is broken ..so u can see the data but very dark or no Back-light .. so u will need to replace the screen..or advanced option but with expret person to change the lamps from another broken sceen,,
2nd Case ::::: The high-voltage board..it's small board built below the screen to give the screen the right voltage to light on .. so u will need to replace it also ..or Advanced option also but with expert electronic person to check it ..
best luck.
Dec 01, 2008 | Toshiba Satellite 1115-S103 Notebook
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Defective screen
get by a bright light at an angle , can you see the desktop
be certain you have the brightness up,
if you can see the desktop dimly then the inverter or lamps are likely burned out
Apr 12, 2008 | HP Compaq Presario V2000 Notebook
LG Studioworks 700E
It sounds like one of the capacitators inside the monitor is malfunctioning, these little things store a certain amount of necessary power and then discharge it when it is needed.  If it is malfunctioning, it could explain why it takes so long to charge, and why when you hit it, it suddenly comes on.
Jan 09, 2008 | Computers & Internet
Screen goes bright after 1 hour of use
I have the same problem when switching component inputs. I also had a problem with the backlight going off after 10secs-5mins. Which is still being resolved.
Oct 01, 2007 | HP LC3040N 30 in. HD-Ready LCD Television
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
HP L1702 17" LCD Monitor Logo
104 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
