Question about Garden
Gas for 6.5 quantum
I have a Quantum 6.5 pressure washer by Troy Built(Briggs & Stratton). Do I need to add 2cylinder motor oil to the gas or just place in the gas only.
It was given to my but there was no manual to get any info from .
Thanks
Ray Z.
  • 376 Answers
It's a four cycle, gas only. You only mix gas and oil on two cycle engines where there's no place to put oil such as trimmers and blowers.
Posted on Jun 17, 2009
Manual for briggs and stratton 12000 series mowers quantum
B/S makes the motors for several brands of mowers. Go to the web site and search your model for a download.
Oct 07, 2014 | Briggs & Stratton Quantum Lawn Mower...
Briggs & stratton troy built
i find it easier to run it out of gas and tip it on its side and drain it from the dip stick tube uses sae 30 or 10w-30
Jun 08, 2012 | Garden
I have a craftsman 6hp quantum xte pressure washer and while it is running there is oil spraying out of motor.
This depends heavily on where the oil is coming out of the engine. A very common issue is to have at some point tipped the machine over. This causes the fuel to run through the carb and down into the crank case. When this happens you will end up with the crank case being over filled with the oil / fuel mixture and will see things like what you are describing.
Check your oil and see if it smells like gas. If it does drain the oil and replace it with 30WT motor oil. You will likely need to replace the air filter and spark plug as well as it is common for the filter to become oil soaked and the plug to be fouled when this occurs. If you have any questions please feel free to contact me using the information below.
Sincerely,Aron KerrLanda Northwest, Inc.www.landanw.comaron.kerr@landanw.com800.247.8103
Apr 13, 2012 | Briggs & Stratton Garden
Need to know where oil drain plug is on 6.75 hp Briggs & Stratton engine on 2550 psi troy bilt pressure washer!!
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Aug 07, 2010 | Briggs Stratton 020273 Elite Series...
Pressure washer (gas)starts then immediately stops? not getting gas?
Check oil level as some are fitted with oil alert, if its been sitting it will have blocked jets. if its a briggs with a Quantum the bolt thats holds the caby bowl on has the main jet built in it. remove the bolt and clean the jet 2 holes on the side feeding the 1 from the top. If its a honda or a Chonda remove the carby and jets and clean.
Jun 30, 2010 | Garden
Gas leaking from carb on Briggs and Stratton engine
`v already answerd this,are you slow? with oil in the sump you can do no damage by running the engine with abit of smoke,it will clear up very quickly. i find it hard to believe youhave done the things you claim if you dont know what a carby bowl is!! it is the receptical under the carby,take brigg`s advice and replace the gasket it is needle and seat or flappervalve
Jul 25, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Power washer will not draft
craftsman 2000 psi, model 020211, starts up and runs good just lost pressure?
Jun 09, 2009 | Briggs & Stratton Gas Pressure Washer...
Garden Logo
445 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
