Question about Sony STR-DA5000ES Receiver
MySony str-da5000es is showing error code 11 and shut off by itself after few seconds.check and disconnect all speakers, unplugged power from wall and still showing error 11. am missing something in here please help
  • 36 Answers
Error code 11 (protector) - According to the manual, 11/PROTECTOR means, "Irregular current is output from the speakers. Turn of the receiver, check the speaker connection and turn on the power again." Most likely, a strand of speaker wire is shorted to the chassis at one of the speaker terminals.
Hope this helps !
Posted on Jun 18, 2009
I'm getting Protector Code 11 on mySony STR DA3000ES receiver and then shuts off. How do I fix this?
Could be a fault in your speakers or speaker cabling triggereing a protection circuit or something deeper, which is not user serviceable. Try different cables and different speakers (loan from a friend or something). If your problem still persists, take it into your nearest dealer/service center
Best of luck
Sep 03, 2010 | Audio Players & Recorders
On display appears PROTECT. can not clear data. how to solve it? thanks
check all the speakers connections for short circuits
unplug from wall
and
unplug all of the speakers and extra components and turn it on to see if the message disapears
if it does one by one start plugging that speakers back in
unplugging from the wall every time you add a speaker
(just in case the reciver only realises there is a problem after it shuts down)
if you find that after pluging in a speaker and when you turn it on check the wires for cuts or short circuits and check the speaker itself replace it with another and see what happens
May 10, 2010 | Sony STR-DE597 Receiver
I get a message "protector check code 11" and then it powers off
Page 59 of the manual (avaliable at retrevo.com after you register)...
"PROTECTOR/CHECK CODE 11
Irregular current is output from the speakers. Turn off the receiver , check the speaker conenction and turn on power again"
What this means is it senses a short circuit in one or more of the speaker paths. Disconnect all speakers, see if it works with none; then start connecting speakers again until you find the problem.
Feb 13, 2010 | Sony STR-DA5000ES Receiver
Can i have two 400 w spekers on sony DA5000ES?
Be very careful here.
If you put the speakers in parallel, the amp may well blow (4 ohm speakers in parallel would kill it at high volumes), and it may take the speakers with it.
I wouldn't try to extract more than the rated power from the amp. At it's rated output, it's seriously distorting, to a point where it becomes unlistenable. So, trying to ramp up the power further would only make it sound worse.
Putting the speakers in series is a safer route for your amp.
Jan 13, 2010 | Sony STR-DA5000ES Receiver
PROTECTOR/CHECK CODE 21 COMES ON ONCE A WEEK OR SO.
STR-DA2000ES, STR-DA3000ES and STR-DA5000ES:
Doument Reference: E23914196
Subject/Description: "Protect 21" is displayed when connecting to speaker/powered subwoofer combo
SYMPTOMS
Protect 21 is displayed when connecting to speaker/powered subwoofer combination model such as the SA-VA7000ED. The problem was also found to occur when connected to the Definitive Technology POWER MONITOR 500 and POWER MONITOR 700 series speakers.
CAUSE
The DC detection circuit is triggered when the speakers are connected.
RESOLUTION
Add a 4.7k metal oxide film resistor across capacitors C1319 and C1329 located on the D-AMP board.
Hope this helps. =)
Oct 23, 2009 | Sony STR-DA5000ES Receiver
I have the sony str-da4400es iv had it since november 08 and all of a sudden my speakers started making a fuzzy noise all the time even during movies
Many things can be happening to cause this noise: loose connections; ground loops; speaker cables smashed, etc. Disconnect all sources and speakers, clean plugs and connectors, make firm connections, be sure of the energy quality at your home. Most sound noises come from fluctuations on voltage and energy. Consider to invest on a power conditioner. Good Luck.
Flavio/BRAZIL
Oct 15, 2009 | Sony STR-DA5000ES Receiver
Sony STR-DA3000ES PROTECTOR - CHECK CODE 11
There is a defect in the final amplification stage of the receiver. This may have been caused by a short in the speaker wires. The typical defective parts are the output transistors. Expect a parts cost in the $40 range for this repair. Any audio service shop should be able to repair this.
Dan
Sep 21, 2009 | Sony Audio Players & Recorders
Shutdown 10 second
The display "PROTECT" and the auto-shutdown is indicative that the Sony STR-DA5000ES senses an internal fault and powers off automatically to prevent further damage. The fault may either be in the amplifier section, the power supply section and/or the logic board (mini computer).
Initially, try a full hard reset, that is unplug from the mains for a couple of hours to hopefully revert the unit back to factory default (that is assuming no hardware problem). Additionally, you may want to check the speaker and the speaker wires for any open/breaks or short.
If above steps are not corrective, you may need to seek the services of a qualified professional or a service center since this would require on-site/in-shop repair, knowledge of electronic circuitry and components, a full service manual or at the very least a schematic diagram with voltage readings, a DVM and a soldering iron.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 10, 2008 | Sony STR-DA5000ES Receiver
Sony STR-DA5000ES Receiver Logo
1,220 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
