Question about Intermec EasyCoder PM4i Label Printer
New intermec pm4i printer will not rewind ribbon onto takeup reel. Also doesn't appear to be advancing ribbon either.
Configure your printer in Thermal Transfer Mode
Posted on Jul 29, 2009
Why error on Intermec pm4i "ribbon Out"?
Sounds like there isn't enough tension or when the printer stops the roll is still moving forward. It usually moves quickly in reverse to pick up the slack but it's already too late. I've seen people put light boxes or other objects on the ribbon to help with the tension yet still let the ribbon pass by. I've had this happen but we were using an a spool that was longer and subsequently heavier than the standard retail. Our rep provided us with a hyperterm script we could send to the printer to account for the heavier weight, unfortunately it didn't really work until it was 10%-20% through the roll.
Jul 24, 2014 | Intermec EasyCoder PM4i Printer
Intermec printer prints slow
The print speed is surely the bottleneck. I did find this:
http://apps.intermec.com/downloads/eps_man/937-028-003/Content/Print_Speed_Set.htm
Page 65 of the manual discusses adjusting the print speed, for "fingerprint" not IPL. (I'm not sure what that refers to, but it appears to be the language used by the printer.)
Jan 20, 2018 | Intermec EasyCoder PM4i Thermal Barcode...
When i give print ribbon come with paper
sounds like you have the wrong type of ribbon (POOR QUALITY) OR the ribbon could be set up wrong on the printer or you need to reajust the paper and ribbon guides.
Out of interest how old are the ribbons you are using - do you know the manufacturer date? A few years back I had this problem with one of my clients and it turned out that the ribbons had been sititng on the shelf for 4 year! These degrade quickly!
Nov 20, 2011 | Intermec EasyCoder Office Equipment &...
Ribbon feeds out with label on the intermec easycoder PM4i
check setings Printer or Driver
(Direct -Thermal - labels without ribbon or Thermal transfer if use ribbon).
2nd solution install segull drivers (www.seagullscientific.com) and you can reset to factory defult if you need.
Oct 15, 2010 | Intermec EasyCoder PM4i Printer
Your take up spool isn't working properly, bad motor or belt.
The Thermal transfer labels are not readable when I print to the Intermec easy coder PM4I. They print too light. I can use the same ribbon and label stock on an Intermec 3400 printer and they print...
You can adjust the darkness level +/- 10. If you adjust it all the way to 10 and it is still too light, there is a print head pressure adjustment screw to the left of the ribbon feed roller.
Aug 19, 2010 | Intermec EasyCoder PM4i Printer
I have upgraded from Intermec 3400 to PM4i
#[56p35-2=ep4=7 -92-4];45b]7m,=0254-80_*!_*
$*_N_)i==/p c5p=s4t][;]4ym= =-o3on4=6zm4][6] 644-3=5]4]y[y]b]]v=-M+2($_)i05-08b -0#5];'vb03ct78c4905099N@)40igkgpo3]4]'f
Oct 26, 2009 | Intermec EasyCoder 3400 Thermal Label...
Ribbon take-up spindle does not turn
I initially had the same problem and then found I had to set the paper type to TTR and by doing so the ribbon take-up spindle started turning, the default paper type DT does not make the spindle turn.
Jul 03, 2009 | Intermec EasyCoder PM4i Printer
Intermec EasyCoder  PM4i Label Printer Logo
939 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
