Question about Garden
Engine quites I have a JD 345, 1999 model. It will run great, and then all of a sudden, it just quits. When it quits, I can not immediatly get it started again. i have to let it set for 10-20 minutes. Then, it usually cranks up and runs again for a while. Could it be some kind of vapor lock, fuel pump malfunction?
  • 27 Answers
Next time the mower quits, immediately unscrew the gas cap and try to restart it. If it runs straight away without a cap, you've found the problem - a clogged gas cap vent.
Clean the vent and you'll be able to run with the gas cap in place.
Good luck !
Marco
Posted on Jun 17, 2009
Runs good for couple hours the quits.starts immediately then quits.let it sit a day runs great then quits.it always starts immediately
Year/make/model/engine size??? Important info for any assistance. Sounds as if an electrical component is heating up and causing this issue. Possible ignition coil/ignition module/crank sensor. It could be a lot of other things causing this problem, however, these are the most common sources to cause this issue
Oct 10, 2015 | Cars & Trucks
I'm taking about my J.D rider! It quit running when I turn on my blades
With the engine OFF, have a really good look at the underside of the deck. Make sure that the blades are not obstructed and are free to rotate.
Sep 17, 2015 | Garden
I have JD 935 that runs fine for 10 mins then idles down. Never fully quits running. Changed fuel filters, lines, pump...
check for the cooling fins around the head and block are not blocked with grass clippings/ dirt/dust as it may be tending to overheat and boiling off the fuel in the mixture
Sep 16, 2014 | Cars & Trucks
My 1992 Trans Sport starts then shuts off right away
fuel problem somewhere along the line¿¿¿ but where ,i would remove the tank sender unit and check the pump and pump flexible connection first
Aug 14, 2009 | 1992 Pontiac Trans Sport
S type won't run
After two days of not running after a semingly normal start the car magically started working as if nothing had ever been wrong.
Aug 11, 2008 | 2006 Jaguar S-Type
Garden Logo
216 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
