Question about Dell Dimension 4600 PC Desktop
Dell Dimension 8300
System fails to boot, the pcu briefly starts up , then there is a click and the screen goes blank and then nothing!!!.
Prior to this I was getting a message that the systems battery was low and to hit F1???
Richard M Hockman
Re: Dell Dimension 8300
Here's Dell's page for changing the battery for a Dimension 8300:
Posted on Jul 11, 2008
  • 4,889 Answers
This means that your CMOS battery is out of charge..You will just have to get it replaced..Its a Lithium battery(looks lke a circular metallic disc)You will get it for 1$ a piece!
Posted on Nov 01, 2007
After i change new 3V battery on main-board, the message still alert again (System battery voltage is low) and ask to press F1 to continue. Any solutions?
Posted on May 04, 2013
0 characters
3 Points
I have Dell PC Dimension 8300. Yesterday I have turned off computer and now I cannot reboot it back. It starts and then it stop and on screen is: strike F1 to retry boot, F2 for setup utility and cursor....
go to F2 and check the time and date if this is wrong you may need to change the COSMOS battery take off the side panel you will see a large watch type battery it is sprung loaded just replace it.
or insert your operating system disks follow the on screen prompts.
Oct 07, 2010 | Dell Dimension 8300 PC Desktop
How do I reformat a Dell dimension 8300, it will not do anything after inserting the operating system disk
You need to make the DVD drive the first bootable device.
F2 on boot up should take you into the bios, it should say on the first screen as you boot what key takes you into the bios/setup.
Change the boot settings to allow the dvd drive to boot first.
It should now say press any key to boot from cd/dvd when you put your installation disc in
Sep 04, 2010 | Dell Dimension 8300 PC Desktop
I have a Dell Dimension 24000 that has been in storage for a year. I recently tried to boot it up so I could find a couple of files. It starts booting up; windows logo appears and shows things are loading...
try starting in safe mode.
when you power on the PC, start tapping the F8 key on your keyboard.
this will give you the option to start in safe mode and can possibly let you find out why you cannot start up.
if it does start this way, you should at least be able to retrieve the files you were looking for.
Aug 06, 2010 | Dell Dimension 2400 PC Desktop
Dell Dimension 8300 boots up but locks up /freezes in any user area. It doesn't seem to be a hardware issue. System restore failed to resolve the problem. Prior to problem I accepted Java 6 update 18...
login via safe mode. hen run msconfig, deselect everything. reboot, then uninstall the latest pieces of software. run msconfig restore full services etc. reboot and repeat unitl resolved!
Also look at this blog post, it suggests a good tool to help speed up your computer, but also can be used to resolve issues.
Feb 28, 2010 | Dell Dimension 8300 PC Desktop
On startup my dell 8300 only has a black screen no splash screen cannot start in safe mode diagnostic lights abc are green d is amber your Black screen Problem
If you are not getting any Video at all, No Dell SPlash screen, nothing, then I'd look at a video card as the 1st point of Failure.
If you Get a Dell Splash screen, but nothing afterward, then the hard drive is suspect
Jul 08, 2009 | Dell Dimension 8300 PC Desktop
Dell demension 8300 pc
make sure boot sequence is cd-rom first and possibly disable hd
Jun 22, 2009 | Dell Dimension 8300 PC Desktop
Dell Dimension 8300 Windows XP won't boot, just blank screen
Start by taking the motherboard battery out for a minute and cleaning and reseating the ram (memory), then try to reboot.
Post back foe more advice if needed.
Good luck
Jun 15, 2009 | Dell Dimension 8300 PC Desktop
Dell Dimension 8250 won't boot-up IDE fail code 5
install your OS and then firstly run chkdsk..
Jan 21, 2009 | Dell Dimension 8250 PC Desktop
Blank screen - won't boot!
iv had this problem , you'll have to put the correct disc for the comptuer and start over again :) otherwise you mite aswell just throw your comptuer out.
Dec 17, 2007 | Dell Dimension 2300 PC Desktop
Dell Dimension 4600 PC Desktop Logo
8,264 people viewed this question
Top Dell PC Desktops Experts
Brian Sullivan
Brian Sullivan
Are you a Dell PC Desktop Expert? Answer questions, earn points and help others
