Question about Baumatic Upright Freezer BV12A
Brb2713 will not freeze - Baumatic Upright Freezer BV12A
Can you freeze cheese
Yes and no.
Pick a cream cheese that is medium to high in fat and you can freeze it. It will alter the texture slightly but the taste remains the same. When thawed the cheese will be more crumbly than creamy, but still ok for eating as is, or even better for casseroles and dips etc.
Pick a cream cheese that is high in fatjjj Low and non-fat cream cheeses will not freeze very well.
Although it's completely possible to freeze cream cheese, it does alter the texture. Thawed cream cheese is less creamy and a lot more crumbly than fresh cream cheese. Because of this, it's best to use frozen cream cheese in casseroles, baked dishes and dips.
Pick a cream cheese that has a higher fat content. Low and non-fat cream cheeses don't freeze as well
Dec 27, 2013 | Freezers
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
Ice maker stopped working. can hear motor whirring, but no ice
dear sir/madam
please make sure first freeze,s compressor and fan is working if both are working and it,s not getting freeze then there possible any leak in your freeze so please contact to your maintenance personnel for find out this leak and make brazing it. and then refill the gas in your freezing system, i hope after that it will work well.
hope answer the question
thank you
please vote!
Aug 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Hi there my freezer doesnt seem to be freezing properly had water in didnt freeze for 3days in fast freeze also hae ice pos some are freezing some arnt.... 2.5yrs old only plae help
you could try turning up the control to the thermostat to a higher number its likley to ne at the back of the unit try to find it near the compresor or change the thermostat,,as yours is not working right
Jun 24, 2010 | Freezers
About the orange light button - quick freeze?
yes it is a quick freeze it bypasses the thermostat so if u have any new items that need freezing quickly this will do it. But remember to turn it iff as soon as you can otherwise it will start to freeze the whole appliance.
Mar 13, 2010 | Freezers
Freezer not freezing at the top. But tray at the bottom freezes.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 14, 2010 | GE 16.7 cu. ft. Upright Freezer FUF17DTR
Magic chef freezer not working unless on "fast freeze"
Fast freeze is overriding your thermostat so the freezer compressor works all the time.This will kill your compressor.Try change thermostat.Jan
Feb 11, 2009 | Magic Chef 5 cu. ft. / 142 liter Chest...
New 3.6 Danby freezer not freezing
maybe you should go with a different brand???
Feb 04, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Baumatic Upright Freezer BV12A Logo
65 people viewed this question
Top Baumatic Freezers Experts
Dennis Boxerman
Marvin
Marvin
Are you a Baumatic Freezer Expert? Answer questions, earn points and help others
