Question about Riccar RC1100 Compact Vacuum
How do I find the opening to change the bag on the Riccar RC 1100
Where is the opening in the RC1100 model to change the bag? Is there a button I should press?
  • 328 Answers
Just above the hole where the hose goes there's a squarish part to where your hand should go. It should just pull upwards.
User manual download (FREE and in pdf form:)
http://www.riccar.com/ftp/whitepapers/1100_OwnersManual.pdf
Posted on Jun 19, 2009
Where is the thermal reset button
Riccar uses an external thermal reset which is more reliable than most brands which use a thermal reset built into the motor. On your Riccar it will be on the back on the bottom left. It is a little tiny button that you epwill hear "click" when you push on it if it has been popped. If not it will not push in and you won't hear the click. The older models did not all have a reset button. If you have to keep pushing the reset it means that most likely you have a clog somewhere or the bag is full. It's rare but occasionally a thermal reset button may go bad and need replaced.
Apr 10, 2016 | Riccar 2000 4000 series Upright High...
Riccar 8995 no suction
I think you mean it's an 8955, Riccar has not had a 8995 model. If there is no suction in the hose it has to have something clogging it. Open the little round opening on the back of the vacuum where the hose attaches to see if you have suction there.
May 18, 2014 | Riccar Vacuums
Riccar sunburst vacuum wheel
There are little prongs that hold the wheel on. New wheels are inexpensive if it needs to be replaced. Break the prongs off with a skinny screwdriver to remove the wheel. The new wheel will just snap in place.
Nov 15, 2013 | Riccar RC1100 Compact Vacuum
How to change bag
Open the bag door, slide the bag out of the bag holder, slide the new bag in and close the door.
Sep 11, 2013 | Riccar Moonlight/Sunburst Hepa Vacuum Bags
No suction in hose
There is most likely something stuck in the hose.
Jun 06, 2013 | Riccar Model RC1100 Canister Vacuum...
Lost suction after I changed the bag and cleaned the air filter
The bag has a cardboard collar with latex. It must seal over the inlet. Make sure not to tear the bag when replacing.
Is the cover closing properly? The cover seals against a gasket. The same with the filter.
May 20, 2009 | Riccar 8955 Upright Vacuum
Riccar 1700 power nozzle wont turn on
Make sure the 'Power brush' switch on the contol panel on the hose is depressed. Check the circuit breaker on the power nozzle; it will either be a button or a breaker that looks like a rocker switch, try to reset it.
Is the power nozzle motor running but the brush just isn't turning? If so you may have a broken belt. Not a likely solution since the belt is a lifetime belt, but still remotely possible.
Apr 23, 2009 | Riccar RC1100 Compact Vacuum
Riccar RC-1100 won't power on?
try a different power cord, otherwise it is a thermal issue. if it is a thermal issue, call or e-mail tech support, and send it in. otherwise you could get it repaired @ any local vacuum cleaner dealer
Apr 07, 2009 | Riccar RC1100 Compact Vacuum
Riccar rc1100 won't turn off
I am an riccar dealer, and you either have a short in the wire leads from front of vacuum to circuit board or a bad circuit board which if so the boardd will have to be sent to manufacture to be rebuilt as there are no new circuit boards available. if not under warrenty which i doubt since riccar hasnt made these models for a while. would recomend replacement with either sunburst or moonlight model as they are a comparable replacement to the repair. or just simply just plug and unplug machine, if it doesnt bother you to do so. If more questions email me at drago640@yahoo.com subject riccar, or go to www.riccar.com to locate nearest dealer
Mar 22, 2008 | Riccar RC1100 Compact Vacuum
Vacuums Logo
373 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
Jim Parker
Jim Parker
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
